Mesa 7i90 in SPI mode
9 years 7 months ago #90030 by PKM
Replied by PKM on topic Mesa 7i90 in SPI mode
Right, I did not enable SPI in config.txt before, thanks for the hint!
Now mesaflash works (at least readhmid is OK).
And yes, loading hm2_spi breaks it. Mesaflash shows something about wrong cookie FFFF FFFF FFFF. Not a big deal, of course.
9 years 7 months ago #90031 by jtheath
Replied by jtheath on topic Mesa 7i90 in SPI mode
If interested there is an updated hm2_spi.c which allows for 8-bit words here,
github.com/resojoe/linuxcnc/tree/master/...rivers/mesa-hostmot2
9 years 7 months ago #90032 by PKM
Thanks, I'll try that!
Why wouldn't you send a PR against the main repo?
BTW I noticed that mesaflash says something about 32-bit failing, using 8-bit...
9 years 7 months ago #90035 by jtheath
Have personally seen a few SPI timeout messages when running. Likely need to update standard RPi spidev driver code to provide better determinism.
Also need to completely comment these changes prior to submission.
The 7i90 expects 32-bit transfers and was originally developed using hardware which provides 32-bit words when using SPI. Thus mesaflash configures the hardware for 32-bit words. The RPi, Pine and others only allow for 8-bit SPI "word" sizes. These SBCs reject the 32-bit request. Instead of failing and exiting mesaflash now sets 8-bit words and orders the bytes for correct transmission.
9 years 5 months ago #93278 by PKM
OK I connected a stepper drive (with optocoupled input) to 7i90 pins and now watchdog bites shortly after the start. Pretty unusable setup...
9 years 5 months ago #93279 by PCW
Replied by PCW on topic Mesa 7i90 in SPI mode
The SPI interface is quite susceptible to noise
This can be improved by:
1. Keeping the SPI cable short (a few inches max)
2. Using all the 26 pin cable grounds
(to lower inductance so stray HF currents dont generate much ground bumping)
Its probably possible to improve the noise situation (at the expense of speed) on the
FPGA RX side by digital filtering the RX data and clock
and on the RSPI RX side with a RC filter on the data from the 7I90
Moderators: PCW, jmelson
Time to create page: 0.444 seconds
