Mesa 7i90 in SPI mode
10 years 3 weeks ago #81339 by andypugh
Replied by andypugh on topic Mesa 7i90 in SPI mode
It would probably be useful to have your changes incorporated into Mesaflash. But I am not sure who looks after that code. I don't _think_ is is part of LinuxCNC as such.
10 years 3 weeks ago #81345 by kaklik
Replied by kaklik on topic Mesa 7i90 in SPI mode
I think, the only possible solution is - fix RPi3 spidev driver to support 32 bit transfers. The 32-bit word transfers are deeply integrated in linuxcnc modules. I have the same problem with ODROID-C1, which uses driver similar to RPi3 therefore it also does not support more than 8bit transfer..
  • jepler
  • Administrator
  • Administrator
10 years 3 weeks ago #81348 by jepler
Replied by jepler on topic Mesa 7i90 in SPI mode
mesaflash makes its home at github.com/micges/mesaflash — I hope a pull request to make it work on a wider range of hardware would be welcomed.
My experience with /dev/spidev so far is that the drivers are typically low quality. Which is sad. Problems seem to include
  • limited transfer width support (rpi3, odroid-c1)
  • incorrect byte order handling (odroid xu4, byte order is fixed in devicetree, not by ioctl)
  • poor latency (u3, xu4, rpi3 without kernel patches)
This really stinks, because on the surface SPI is a perfect bus for LinuxCNC on SBCs, owing to its near-ubiquity and having a standard location on pi-like 40-pin headers to boot.
10 years 3 weeks ago - 9 years 8 months ago #81488 by tinkerer
Replied by tinkerer on topic Mesa 7i90 in SPI mode
Last edit: 9 years 8 months ago by tinkerer.
10 years 2 weeks ago #81678 by jtheath
Replied by jtheath on topic Mesa 7i90 in SPI mode
Yes, I have looked at the hm2_rpspi option and not been successful (yet). Tried on two RPi3s and an RPi2 but haven't pulled it together.
I forked mesaflash and posted my 8-bit word fallback solution. Please take look at the spi_boards.c modification. I cleaned up my original work. github.com/resojoe/mesaflash
The port of this functionality to LinuxCNC itself (similar modification to src/hal/drivers/mesa-hostmot2/hm2_spi.c) seems to be working for me. If you take a close look at the RPi3 SPI driver (drivers/spi/spi-bcm2835.c) you'll find transfers handled three different ways: if a transfer is calculated to take < 30us polling logic is used; if a transfer is >96 bytes DMA is used; if neither of the first two an IRQ-based method. I don't see any sleeps or obvious slow-downs in the various paths. That said I do get an occasional "unexpected RT delay" message. Any guidance as to what to look for would be appreciated. Jepler - I did look at your SPI driver patch addressing the dynamic DMA allocation. Perhaps there is something similar in this bcm2835 module and I haven't recognized it.
Necessary config file changes:
7i90.ini - change DRIVER attribute to hm2_spi
hm2-stepper.hal - append "spi_path=/dev/spidev0.0" to the loadrt [HOSTMOT2](DRIVER) config=[HOSTMOT2](CONFIG) line.
- Joe
  • jepler
  • Administrator
  • Administrator
10 years 2 weeks ago #81701 by jepler
The changes on github look good to me in general. My ARM hardware is all put away so I can't test it right now, though.
I did go ahead and create a pull request on github, so that hopefully micges will incorporate your change.
Thanks!
Moderators: PCW, jmelson
