5i25 + 2 X 7i74
13 Jun 2016 08:14 #75899 by terkaa
5i25 + 2 X 7i74 was created by terkaa
I have 5i25 and 2 7i74's connected. The one on port 0 is working ok but the one on port 1 lights only green led enable led does not come on. How do I enable also this port 1 ?
Tero
13 Jun 2016 10:30 #75908 by andypugh
Replied by andypugh on topic 5i25 + 2 X 7i74
What do you get if you type the following in a terminal window? This is a completely default startup with no options:
halrun
loadrt hostmot2
loadrt hm2_pci
loadrt threads
addf hm2_5i25.0.read     thread1
addf hm2_5i25.0.write    thread1
start
(You can then do things like "show pin" to see if the pins on the second 7i74 show up, etc.)
13 Jun 2016 10:51 #75909 by terkaa
Replied by terkaa on topic 5i25 + 2 X 7i74
I get all io's connected to 7i74 on port 0. But no io's connected to
second 7i74 on port 1.
Tero
13 Jun 2016 10:58 #75910 by andypugh
Do you know which firmware is on the 5i25?
13 Jun 2016 13:51 #75916 by PCW
Replied by PCW on topic 5i25 + 2 X 7i74
AFAIK you must specifically enable sserial Port1 in the config line
13 Jun 2016 13:57 #75917 by terkaa
How do I do that?
13 Jun 2016 14:03 #75919 by andypugh
How do I do that?
halrun
loadrt hostmot2
loadrt hm2_pci cfg="sserial_port_1=00000000"
loadrt threads
start
13 Jun 2016 14:07 - 13 Jun 2016 14:07 #75920 by terkaa
Ok, I will give it a go tomorrow. This port 1 is dedicated for user panel inputs/outputs with two 7i84's.
Tero
Last edit: 13 Jun 2016 14:07 by terkaa.
13 Jun 2016 14:16 #75922 by andypugh
Look for the text "sserial_port" in this page:
linuxcnc.org/docs/2.7/html/man/man9/hostmot2.9.html
16 Jun 2016 11:21 #76146 by terkaa
Ok,
adding sserial_port_1=00000000 worked and 7i70 card connected to second 7i74 now works. But I have 7i84 connected to same 7i74 and it does not work. RS422 and field power leds are on but green activity led does not start blinking. What might cause this?
Moderators: PCWjmelson
Time to create page: 0.245 seconds
