5i25 + 2 X 7i74
- terkaa
- Thank you received: 3
13 Jun 2016 08:14 #75899
by terkaa
5i25 + 2 X 7i74 was created by terkaa
I have 5i25 and 2 7i74's connected. The one on port 0 is working ok but the one on port 1 lights only green led enable led does not come on. How do I enable also this port 1 ?
Tero
Tero
- Thank you received: 4648
13 Jun 2016 10:30 #75908
Replied by andypugh on topic 5i25 + 2 X 7i74
What do you get if you type the following in a terminal window? This is a completely default startup with no options:
(You can then do things like "show pin" to see if the pins on the second 7i74 show up, etc.)
halrun
loadrt hostmot2
loadrt hm2_pci
loadrt threads
addf hm2_5i25.0.read thread1
addf hm2_5i25.0.write thread1
start(You can then do things like "show pin" to see if the pins on the second 7i74 show up, etc.)
- terkaa
13 Jun 2016 10:51 #75909
by terkaa
Replied by terkaa on topic 5i25 + 2 X 7i74
I get all io's connected to 7i74 on port 0. But no io's connected to
second 7i74 on port 1.
Tero
Tero
13 Jun 2016 10:58 #75910
Do you know which firmware is on the 5i25?
- Thank you received: 5308
13 Jun 2016 13:51 #75916
Replied by PCW on topic 5i25 + 2 X 7i74
AFAIK you must specifically enable sserial Port1 in the config line
- terkaa
13 Jun 2016 13:57 #75917
by terkaa
How do I do that?
How do I do that?
13 Jun 2016 14:03 #75919
How do I do that?
halrun
loadrt hostmot2
loadrt hm2_pci cfg="sserial_port_1=00000000"
loadrt threads
startPlease Log in or Create an account to join the conversation.
- terkaa
13 Jun 2016 14:07 - 13 Jun 2016 14:07 #75920
by terkaa
Ok, I will give it a go tomorrow. This port 1 is dedicated for user panel inputs/outputs with two 7i84's.
Tero
Tero
Last edit: 13 Jun 2016 14:07 by terkaa.
13 Jun 2016 14:16 #75922
Look for the text "sserial_port" in this page:
linuxcnc.org/docs/2.7/html/man/man9/hostmot2.9.html
- terkaa
16 Jun 2016 11:21 #76146
by terkaa
Time to create page: 0.317 seconds
