Mesa 7i96 system planning-How Supported is Supported?
06 Apr 2019 07:12 #130385 by tommylight
www.gnipsel.com/linuxcnc/7i96/index.html
That is a tool made by JT for 7i96.
The following user(s) said Thank You: jools
18 Apr 2019 09:05 #131133 by ikkuh
if it has support from pncconf yet (or if this is planned)
Jools
There is a working 7i96 config tool made by JT, gnipsel.com/linuxcnc/7i96/index.html Pncconf does not support the 7i96.
Some say that you can use the 7i76e in pncconf, but I found that to be a lot of work and very mediocre results.
Btw, the 7i76e card has some advantages over the 7i96 and is only a third more expensive.
18 Apr 2019 13:51 #131160 by pl7i92
a tool like that woudt be good for the 7i92 also
reding the pins in and provideng the user a full pinout on the given Bitfile flashed to the 7i92
23 Nov 2019 01:42 #150996 by persei8
Simple question: The 7i96 has an RS-485 interface, which according to the manual, "is intended for I/O expansion with Mesa SSERIAL devices". So can it be used to control a VFD or not?
23 Nov 2019 02:39 #151000 by tommylight
That should be an RS422, not 485. So far i am not aware of anyone using it for that, they just use an USB to RS485 converter.
The following user(s) said Thank You: Leon82
23 Nov 2019 02:52 #151002 by persei8
Not trying to be contrary, but the manual calls is "RS-422/RS-485 INTERFACE"
Well that's disappointing. Seems like it would be an important function to include in the FPGA.
23 Nov 2019 03:04 #151004 by tommylight
Well, maybe PCW can do something about it, or at least tell us for sure if it is possible or not.
I just know that Mesa has two pairs of wires for that, RS485 use only a single set of wires.
Never liked RS485 much, and i utterly hated RS232 back in the days of modems and stuff.
  • rodw
  • rodw's Avatar
  • Platinum Member
  • Platinum Member
23 Nov 2019 03:36 #151006 by rodw
With the correct bit file, it is possible to expose the Mesa UART and you can use this for serial communication.
See the hostmot2 docs linuxcnc.org/docs/devel/html/man/man9/hostmot2.9.html#UART
There are some examples on how to use this but to use it for your own purposes, you would need to write your own driver.
I also picked up on the RS485 with the 7i96.
23 Nov 2019 15:41 #151052 by persei8
I guess I will at least investigate a little further. I've done a lot of work with serial IO and once even implemented a 16550 type UART on a Spartan FPGA in VHDL, but I don't know if any of that will help now.
23 Nov 2019 16:45 #151065 by PCW
There is UART support in the firmware (PktUART) and minimal LinuxCNC driver support
There is another thread on where someone is using the PktUART to communicate with custom hardware:
forum.linuxcnc.org/27-driver-boards/3751...80hd?start=30#150357
Moderators: PCW, jmelson
Time to create page: 0.589 seconds
