7i96 Configuration Tool
6 years 7 months ago #161866 by tommylight
Replied by tommylight on topic 7i96 Configuration Tool
Again,
./testcnc.hal:99: parameter or pin 'hm2_7i96.0.pwmgen.00.output-type' not found
Check what PCW said, and if there is a PWM check the line where the card is loaded...............
or just upload your hal and ini files.
6 years 7 months ago #161867 by tommylight
6 years 5 months ago - 6 years 5 months ago #167096 by Project_Hopeless
I'm trying to setup a simple output to turn the spindle (router) on/off.
I have all the PWM references commented out...
# Spindle #setp hm2_7i96.0.pwmgen.00.output-type 0 #setp hm2_7i96.0.pwmgen.00.scale [SPINDLE]MAX_RPM #setp hm2_7i96.0.pwmgen.pwm_frequency [SPINDLE]PWM_FREQUENCY
The 7i96 tool created an output for it..
[OUTPUTS]
# DO NOT change the output text
OUTPUT_0 = Spindle On
OUTPUT_1 = Select
OUTPUT_2 = Select
OUTPUT_3 = Select
OUTPUT_4 = Select
The io.hal setup like this...
net spindle-on motion.spindle-on => hm2_7i96.0.ssr.00.out-00
But i still get an error.
Debug file information: Note: Using POSIX realtime ./io.hal:16: Pin 'motion.spindle-on' does not exist 5159
What am I missing?
Last edit: 6 years 5 months ago by Project_Hopeless.
6 years 5 months ago #167097 by PCW
Replied by PCW on topic 7i96 Configuration Tool
Spindle names changed at some point in the LinuxCNC 2.8 release
motion.spindle-on changed to spindle.0.on
The following user(s) said Thank You: Project_Hopeless
6 years 4 months ago #170099 by jools
Replied by jools on topic 7i96 Configuration Tool
Project_Hopeless wrote:
BigJohnT wrote: The home/user/.bin in Debian is not in the path by default. Try $PATH and see if local/.bin is there. If not then do step 3 in the install instructions.
JT
That was part of it. I had to create the file "xsessionrc" not ".xsessionrc" :pinch: That catches me every time. But it still wouldn't work.
How I got it to work was downloading the python "setuptools" then follow the install instructions verbatim. I found online some issues with Mint and pip without having setuptools. I also had to use the sudo -H switch, something about not having permissions to my own home directory. Can't say I understand, but it does work now.
And a year from now I will have completely forgotten all this.
I have the same issue. Can you detail the steps you took to get setuptools in detail to help others and me please.
6 years 3 months ago #173494 by Bruedney
Replied by Bruedney on topic 7i96 Configuration Tool
Can I use this to configure a 7i76e card?
Moderators: PCW, jmelson
Time to create page: 0.350 seconds
