7i96 Configuration Tool
6 years 3 months ago #173495 by rodw
Replied by rodw on topic 7i96 Configuration Tool
Use pncconf which is part of the official install.
6 years 3 months ago #173497 by Bruedney
Replied by Bruedney on topic 7i96 Configuration Tool
Thanks Rod
I have used that but I thought that this looks easier to use.
Cheers
Bruce
5 years 10 months ago - 5 years 10 months ago #192301 by caa028
Replied by caa028 on topic 7i96 Configuration Tool
Not sure, if it's a known issue... or if I'm doing something completely wrong...
After following the install procedure ( jethornton.github.io/7i96/install.html ) I'm getting the "ModuleNotFoundError: No module named 'm7i96'" error message.
Any hints on how to get the 7i96 configuration tool running would be very much appreciated.
Thank you!
Here is the full error message:
=== ~$ 7i96 Traceback (most recent call last): File "/home/caa028/.local/bin/7i96", line 6, in <module> from m7i96.m7i96 import main ModuleNotFoundError: No module named 'm7i96' ===
Last edit: 5 years 10 months ago by caa028. Reason: added error message
5 years 10 months ago #192415 by rodw
Try using pncconf as your board is supported now. (And pncconf is a part of linuxcnc)
The following user(s) said Thank You: caa028
5 years 9 months ago #194518 by BigJohnT
Replied by BigJohnT on topic 7i96 Configuration Tool
I have a Debian deb now so install is super easy and the deb adds a menu item for the tool.
JT
5 years 9 months ago #194523 by PCW
Replied by PCW on topic 7i96 Configuration Tool
Did you update the spindle names?
Moderators: PCW, jmelson
Time to create page: 0.152 seconds
