7i96 Configuration Tool
5 years 7 months ago #201999 by PCW
Replied by PCW on topic 7i96 Configuration Tool
The I/O is in io.hal
The following user(s) said Thank You: Markyd
5 years 7 months ago #202004 by Markyd
Replied by Markyd on topic 7i96 Configuration Tool
OK, I'll have to go fetch it from the shed!
5 years 7 months ago #202328 by BigJohnT
Replied by BigJohnT on topic 7i96 Configuration Tool
tommylight wrote: Can they be modified with the tool? Should have "inverted" or "invert" besides every IO pin.
I'm working on adding the invert check box for I/O. Been side tracked by fighting with building the deb.
JT
5 years 7 months ago - 5 years 7 months ago #202330 by BigJohnT
Markyd wrote:
tommylight wrote: Just add:
_not
or
-not
at the end of the 7i96_something_input.000 etc.
tommylight - ref your answer above, the issue i have is the ini and hal files that JohnT's tool produces don't appear to follow 'normal' syntax. for example my ini includes this
[INPUTS] # DO NOT change the input text INPUT_0 = Min Limit & Home INPUT_JOINT_0 = 0 INPUT_1 = Max Limit INPUT_JOINT_1 = 0 INPUT_2 = Min Limit & Home INPUT_JOINT_2 = 1 INPUT_3 = Max Limit INPUT_JOINT_3 = 1 INPUT_4 = Min Limit & Home INPUT_JOINT_4 = 2 INPUT_5 = Max Limit
but none of this seems to be mentioned in the HAL. I've searched for "INPUT_" and for "Limit" and neither appear in the .hal file. The syntax used (above) in does seem to be conducive to the addition of "_not" or "-not", in fact it specifically says "DO NOT change the input text". I'm at a loss as to how I do something that I thought should be relatively simple. I understand that your answer works in ini.hal files produced by pncconf,
Those are only used by my configuration tool when you load the ini back up. They are used to set up the tool. I'll add a note saying what those are.
JT
Last edit: 5 years 7 months ago by BigJohnT.
5 years 7 months ago - 5 years 7 months ago #202654 by Markyd
As soon as pete pointed to to the existence of the io.hal file i fixed it in minutes. Thanks.
While I remember, I cant get the external estop to work. The estop signal toggles with the pin. The axis gui seems to make a signal called estop-loop toggle, my external switch does nothing to that. Is that part of the issue?
Last edit: 5 years 7 months ago by Markyd.
5 years 7 months ago #202723 by BigJohnT
Markyd wrote: As soon as pete pointed to to the existence of the io.hal file i fixed it in minutes. Thanks.
What did you have to change in io.hal?
Seems the E-Stop input is not being built so I'll fix that.
Remind me of the issue...
JT
Moderators: PCW, jmelson
Time to create page: 0.148 seconds
