7i96 Configuration Tool
  • BigJohnT
  • BigJohnT's Avatar Topic Author
  • Administrator
  • Administrator
06 Aug 2018 18:22 - 23 Jan 2020 17:14 #115702 by BigJohnT
7i96 Configuration Tool was created by BigJohnT
NOTE: this tool is for Master (yet to be released 2.8) only.
I'm getting really close to having the 7i96 configuration tool working if anyone cares to look.
github.com/jethornton/7i96
Fastest thing at the moment is to open the sample ini file with the tool then make your changes to limits and axes etc.
JT
Last edit: 23 Jan 2020 17:14 by BigJohnT.
The following user(s) said Thank You: tommylight, Clive S, KCJ, TheFabricatorAG, MakingStuff, snugglylovemuffin
  • BigJohnT
  • Administrator
  • Administrator
24 Aug 2018 05:15 #116517 by BigJohnT
Replied by BigJohnT on topic 7i96 Configuration Tool
I've got most things working and checked if anyone wants to give it a test run.
The Machine Tab
The Display Tab
JT
  • BigJohnT
  • Administrator
  • Administrator
24 Aug 2018 05:50 #116519 by BigJohnT
This is the Axis tab where you configure the joints and axes. You can create a gantry configuration as well.
JT
  • BigJohnT
  • Administrator
  • Administrator
24 Aug 2018 05:51 #116520 by BigJohnT
The Spindle Tab
JT
  • BigJohnT
  • Administrator
  • Administrator
24 Aug 2018 05:52 #116521 by BigJohnT
The inputs tab.
The outputs tab
JT
  • BigJohnT
  • Administrator
  • Administrator
24 Aug 2018 05:53 #116523 by BigJohnT
The options tab
JT
  • BigJohnT
  • Administrator
  • Administrator
24 Aug 2018 05:55 #116524 by BigJohnT
The PLC tab where you can add classicladder and change the default number of items.
JT
  • BigJohnT
  • Administrator
  • Administrator
24 Aug 2018 05:58 #116525 by BigJohnT
Last but not least the important tabs for Ethernet cards a way to find out if your PC is a good candidate for an Ethernet Mesa card.
The info tab you can get the CPU information and the NIC information.
The pc tab you can get the tmax value and with the CPU speed calculate the amount of the servo period it uses.
JT
The following user(s) said Thank You: kb8wmc, tommylight, rodw, snugglylovemuffin
  • snugglylovemuffin
  • snugglylovemuffin's Avatar
  • Elite Member
  • Elite Member
04 Nov 2018 18:01 #119950 by snugglylovemuffin
Replied by snugglylovemuffin on topic 7i96 Configuration Tool
You're the best BigJohnT!
It's great to see the 7i96 board being more thoroughtly supported!
05 Nov 2018 09:31 #119994 by andypugh
Replied by andypugh on topic 7i96 Configuration Tool
I am curious, why a separate tool rather than adding the board to pncconf?
Moderators: PCW, jmelson
Time to create page: 0.349 seconds
