7i96 Configuration Tool
- BigJohnT
- Thank you received: 994
20 Aug 2019 15:20 #142612
by BigJohnT
I've not tried running the configuration tool on the RPi4 but it should just work as they are both debian. I may try today as I got the RPi4 going with preemt rt and LinuxCNC and was working out the details for setting up a static IP needed for the Mesa Ethernet cards.
JT
Replied by BigJohnT on topic 7i96 Configuration Tool
Does this configuration tool be setup to work with RPi4?
JT
- tecno
- Thank you received: 127
20 Aug 2019 15:25 #142613
by tecno
Replied by tecno on topic 7i96 Configuration Tool
Looking forward to your test, I am not quite yet there as I am awaiting for the 7i96 to arrive.
Cheers
Bengt
ps I have Hakan's RPi4 on a long loan to evaluate if I can get my PlasmaC to run in my rig.
Cheers
Bengt
- Clive S
- Thank you received: 486
20 Aug 2019 15:39 #142615
by Clive S
I see the .xsessionrc file in the home dir /home/ and it opens showing the file :-
if [ -d $HOME/.local/bin ]; then
export PATH="$HOME/.local/bin:$PATH"
fi
is this correct if so how do I start the configuration
Replied by Clive S on topic 7i96 Configuration Tool
To see a hidden file (one that starts with a dot) you have to select show hidden files in the file manager.
JT
fi
- BigJohnT
20 Aug 2019 15:48 #142617
by BigJohnT
If you mean start a configuration created by the configuration tool, you start LinuxCNC and pick it from the list My Configurations.
JT
JT
fi
JT
- Clive S
20 Aug 2019 16:08 - 20 Aug 2019 16:10 #142618
by Clive S
No. How do I start the config tool? I am running 2.9
JT
fi
JT
Last edit: 20 Aug 2019 16:10 by Clive S.
- BigJohnT
20 Aug 2019 18:44 - 20 Aug 2019 18:45 #142634
by BigJohnT
After fixing the path and logging out and back in or rebooting then from then on you just open a terminal and type in
With all the different OS's I never did get around to making a desktop file for it.
JT
7i96With all the different OS's I never did get around to making a desktop file for it.
JT
Last edit: 20 Aug 2019 18:45 by BigJohnT.
- Clive S
20 Aug 2019 20:05 #142640
by Clive S
I have tried putting 7i96 in a terminal and it reports back bash:7i96: command not found
How can I check if the path is correct
7i96
JT
- Thank you received: 7478
20 Aug 2019 20:39 #142642
Replied by tommylight on topic 7i96 Configuration Tool
Open a terminal where the tool is located and try :
./7i96
Or
Python 7i96
./7i96
Or
Python 7i96
- Clive S
20 Aug 2019 21:32 #142647
by Clive S
Thanks. I have tried all those in the home dir and the /home/cnc dir
I will reload linuxcnc tomorrow and start afresh
./7i96
Or
Python 7i96
- Thank you received: 5325
20 Aug 2019 21:56 #142649
Replied by PCW on topic 7i96 Configuration Tool
Umm a reload is not needed...
Can you see the 7i96 file with ls? if not, ./7i96 will not work as that means execute the 7i96 file in the current directory
