7i96 Configuration Tool
22 May 2019 15:43 #134585 by nbremond
Replied by nbremond on topic 7i96 Configuration Tool
THanks for your reply.
You mean linuxcnc and MEAS 7i96 is fully working in Debian9 ?
This is a good news!
  • BigJohnT
  • BigJohnT's Avatar Topic Author
  • Administrator
  • Administrator
22 May 2019 17:16 #134592 by BigJohnT
Replied by BigJohnT on topic 7i96 Configuration Tool
Andy just pointed me to thread that can possibly fix Debian 7 update issues.
forum.linuxcnc.org/10-advanced-configura...ring-whb04b-4#131331
And yes you can either use the Debian 9 LiveDVD to install LinuxCNC 2.7 or follow the instructions in my previous link to install the real time kernel, LinuxCNC version of your choice and how to setup for using an Ethernet Mesa card.
JT
The following user(s) said Thank You: TheFabricatorAG, nbremond
  • BigJohnT
  • Administrator
  • Administrator
22 May 2019 17:17 #134593 by BigJohnT
I just pushed a couple of bug fixes to the 7i96 repo to fix flashing the card from the configuration tool.
JT
22 May 2019 20:14 #134605 by nbremond
Thanks... it's currently compiling the kernel...
22 May 2019 20:21 #134608 by AgentWD40
Replied by AgentWD40 on topic 7i96 Configuration Tool
Just in case you weren't aware you can get debian stretch with rtpreempt precompiled in a live cd/usb here
www.linuxcnc.org/testing-stretch-rtpreempt/
The following user(s) said Thank You: snugglylovemuffin
22 May 2019 20:57 #134616 by nbremond
Thanks. It'll be the plan B in case the compiling process fail... compiling the kernel takes forever...
23 May 2019 19:13 #134738 by nbremond
Everything compiled and installed without issue on Mint 19.
And the 7i96 configuration tool is also working.
Thanks for your help
26 May 2019 02:12 #134946 by Project_Hopeless
Replied by Project_Hopeless on topic 7i96 Configuration Tool
Dumb question, how do I launch the tool? I think it installed correctly
anto@CNCRouter:~$ pip3 install /home/anto/Downloads/7i96-master/
Processing ./Downloads/7i96-master
Building wheels for collected packages: 7i96
Running setup.py bdist_wheel for 7i96 ... done
Stored in directory: /home/anto/.cache/pip/wheels/81/09/41/a1eb76abe81b88106144bb8fcad1e4ee4e3c6ece133634ab39
Successfully built 7i96
Installing collected packages: 7i96
Successfully installed 7i96-0.1.0
  • BigJohnT
  • Administrator
  • Administrator
26 May 2019 11:18 #134992 by BigJohnT
The install and usage instructions are in the documents
jethornton.github.io/7i96/install.html
It looks like you downloaded a zip, no idea where that might get installed. But if that way works you open a terminal and type in 7i96.
JT
30 May 2019 21:54 #135426 by Project_Hopeless
John, thanks ! those instruction were so much better, worked like a charm.
Earlier I followed a readme file on github, might have been an old repository or something. :(
FWIW I still could not launch from my home directory. I had to enable "show hidden files and folders" hunt down the install directory and setup a desktop link to the 7i96 file.
Other than that I'm good to go, thanks again!
Moderators: PCW, jmelson
