Hardinge super slant w/ siemens 6RB
02 Sep 2018 20:04 #116992 by PCW
Replied by PCW on topic Hardinge super slant w/ siemens 6RB
No, unfortunately the 7I84 encoder inputs are mainly for MPG use and have a maximum count rate of about 20-50 KHz and dont have an index input
02 Sep 2018 22:10 - 02 Sep 2018 22:13 #116996 by PCW
Another option would be:
5I24 -->
7I49
7I52 (6 encoders 6 sserial ports)
1x or 2x 7I84
(this leaves one 5I24 connector free and provides 6 resolver inputs, 6 encoder inputs, 6 analog outputs and the 7I84 I/O )
Last edit: 02 Sep 2018 22:13 by PCW.
  • Deckerjwd
  • Deckerjwd's Avatar Topic Author
  • Premium Member
  • Premium Member
02 Sep 2018 22:39 #116998 by Deckerjwd
Replied by Deckerjwd on topic Hardinge super slant w/ siemens 6RB
wow they really have some option with the mesa cards, going to go read them all i think
  • Deckerjwd
  • Premium Member
  • Premium Member
04 Sep 2018 15:57 #117062 by Deckerjwd
is it possible to use GPIO for encoders the 5i24-16 does not have firmware for using a 7i49 and a 7i33 together. so im thinking using the 7142TA IO card for the encoders and adding a 7I44 for the slower IO MPG.
04 Sep 2018 16:47 - 04 Sep 2018 16:47 #117063 by PCW
In general its better to use an encoder card for encoder interfaces on larger machines since they will normally use differential encoders for noise immunity
Its not a big deal to make firmware for a 7I49+7I33
How many encoder inputs do you actually need?
Last edit: 04 Sep 2018 16:47 by PCW.
  • Deckerjwd
  • Premium Member
  • Premium Member
04 Sep 2018 17:09 #117065 by Deckerjwd
think one or 2 is there a down side to turning the whole card on?
  • Deckerjwd
  • Premium Member
  • Premium Member
13 Sep 2018 01:10 #117441 by Deckerjwd
cant find to much about making a bit file do i need software? would like to do it myself but maybe beyond me. think i would turn all the encoders on but dont need the analog, inless a build a y axis for the lathe. so got the serial in, so the card order would be
5I24 -->
7I49
7I33
7I44 -->
7I84 x2
13 Sep 2018 02:58 #117442 by PCW
I'll try to get one made before the end of the week
What model of the 5I24 do you have?
  • Deckerjwd
  • Premium Member
  • Premium Member
13 Sep 2018 13:09 #117455 by Deckerjwd
i have the 5i24-16, that would be great let me know if you need anything for that.
15 Sep 2018 04:25 #117568 by PCW
The following user(s) said Thank You: andypugh, Deckerjwd
Moderators: PCW, jmelson
Time to create page: 0.364 seconds
