connect raspberry via ehternet as IO-port - some developer help needed
  • wicki
  • wicki's Avatar Topic Author
  • Elite Member
  • Elite Member
26 Jan 2019 09:24 #124881 by wicki
Most LinuxCNC IO happens in a 1mS thread.
The exception is step-generation, and I would imagine that if your setup was generating steps on the Pi then you would be sending step-rate information rather than individual steps.
My plan is/was, to use the microstepping-generator of linuxcnc - without doing much
more on the rasPI, than the IO-pin handling.
If I need 3 motor-turns/cm in 16 micorsteps, I have to send 48 signals/cm.
With a latency of 1ms, a jog-speed of 20cm/second an with a latency of
100usec, 200cm/second should be possible.
appears as a lapse of thought.... but it seems to be right.
If so, it explains the reason why my machine is working yet ;-)
I will test it the next days.
But I still need some help in writing a configure/makefile to integrate the
driver into linuxCNC.
The rasPI-side is a standalone-thread - on the linuxCNC-side, I patched the hal_parport.c
and wrote also a standalone-thread for sharemem-exchange and raw-eth-communication.
It would be fine, to have single a hal-driver for both (simulate parport and raw-eth to rasPI)
26 Jan 2019 14:56 #124897 by andypugh
Put it in the same folder as another driver, then copy the makefile entries for that other driver.
That is all I have ever done.
Have you tried compiling and installing it with halcompile?
The following user(s) said Thank You: wicki
  • wicki
  • Elite Member
  • Elite Member
26 Jan 2019 18:05 - 26 Jan 2019 18:15 #124912 by wicki
I've tried so.... in several ways. But it does not work. :-(
Do you mean the Makefile or the Submakefile?
I never used autogen, autoconf or configure in development.
But I think, if it should be re-distributable, it is necessary, to include it in
these scripts.
Halcompile I used serveral years ago - but I think it is not the right tool
for writing a driver. (maybe I'm wrong...)
Last edit: 26 Jan 2019 18:15 by wicki.
  • wicki
  • Elite Member
  • Elite Member
26 Jan 2019 18:22 - 26 Jan 2019 18:54 #124913 by wicki
oh, of course I'm wrong....
It seems to work with halcompile!
halcompile --compile hal_rasPI.c
Compiling realtime hal_rasPI.c
Linking hal_rasPI.so
then copy it to ../rtlib
I'll test it again.....
Last edit: 26 Jan 2019 18:54 by wicki.
  • wicki
  • Elite Member
  • Elite Member
27 Jan 2019 11:36 #124955 by wicki
OK, modified parport-driver is working with halcompile.
But the next problem:
For the integration of the raw-sockets into the driver I need
raw-socket-access. But I can't find any rtai-functions for it.
And access by the standard-API results in "Operation not permitted"
any hints ?
27 Jan 2019 11:46 #124957 by andypugh
Which realtime kernel are you using?
The Mesa card Ethernet drivers need to run with preempt-rt not rtai.
  • wicki
  • Elite Member
  • Elite Member
27 Jan 2019 12:00 - 27 Jan 2019 12:03 #124958 by wicki
yes... it was a stupid lapse of thought.... a stupid one....
not 16 steps for 360 degree turn, 16 steps for 1.8 degrees!
so 3200 steps /turn --> 9600 steps/cm.
with 1ms latency it is incredible slow....
with 100usec its also slow....
at which speed are youre machines running?
(microstepping by parport?)
Last edit: 27 Jan 2019 12:03 by wicki.
  • wicki
  • Elite Member
  • Elite Member
27 Jan 2019 12:07 #124959 by wicki
I made tests with vanilla, preempt and rtai 3.5 and 5.1i.
last try with kernel 4.9.80-rtai does not start (crash at kernel-boot)
27 Jan 2019 13:34 #124964 by andypugh
preempt or preempt-rt?
  • wicki
  • Elite Member
  • Elite Member
27 Jan 2019 13:38 #124965 by wicki
now this one:
Linux desktop 4.19.15-rt12 #1 SMP PREEMPT RT Tue Jan 22 23:20:37 CET 2019 x86_64 x86_64 x86_64 GNU/Linux
Moderators: PCW, jmelson
Time to create page: 0.287 seconds
