Retrofit of Precix 5x10 CNC
5 years 10 months ago #190981 by bevins
Replied by bevins on topic Retrofit of Precix 5x10 CNC
randypetersen wrote: In case someone has similar problem wanted to report back.
After changing out the cables, CNC has not had any issues. So must have been encoder cables that I replaced. Used CNC a lot since then and been acting perfect [knock on wood].
Thanks for everyone's help as always.
I have a Precix to retrofit for a customer. Did you end up swapping out motors and/or drives? Or did everything work ok with the 7i77?
5 years 10 months ago #190984 by randypetersen
Bevins,
No, I kept using the same motors. Same motors/drivers/power supply.
I'd be glad to help however I can, if you have any specific questions ask away! Otherwise I will record a quick video of how my machine is set up, maybe can help or anyone else with a retrofit.
Used it today worked fine.
If you do use same motors, maybe we can compare notes on servo tuning :) Which model are you retrofitting?
5 years 10 months ago #190986 by bevins
randypetersen wrote: Bevins,
It is a 2100 Series CNC Router DC3BR. 3 phase motor drives and 3 phase spindle inverter. thats all I know for now. The customer hasn't got back to me with more details. Its a Oct 2000 manufacture date. Delta VFD, Perske servo's.
thats all I got now. It kinda looks like your control box.
5 years 8 months ago #200484 by randypetersen
First off I want to say, thanks so much for all the help this forum has provided! I really appreciate it...
Trying to expand the machine a bit to make it function better for me.
It came with a touch plate, however I never thought it would work properly. It's an air cooled spindle and it was added afterwards. The tool bit is not making any connection with any of the wiring. It is sometimes grounded to the unit, but if I rotate the bit the connection goes on/off, is that normal?
Since I am having issues with my V-engraving being sometimes too deep, sometimes too shallow, I really want a reliable and accurate way to tell the surface of my material. Thanks to the forum, using my XHC-WHB04B is working great! but hard to get the Z exactly right.
I took the plate they provided and I added a clip to it, there were 2 wires going to the plate, now 1 goes to the clip and 1 goes to the plate.
I verified that I have a good connection going from that to some wires in my controller that can go to my 7i77 card, just hoping to get some help on how/where to connect them. Also, seems like I will need a new probe screen?
I also purchased a tool setter probe in hopes that during tool changes I can be more accurate.
Bought of Amazon:
www.amazon.com/gp/product/B07PRPMZKS/ref...05_s00?ie=UTF8&psc=1
Not worried about that right now, want to focus on workplace z height accuracy and whatever software I will need to do it.
Thanks for any help!
random things made on the CNC
cell holder for co-workers
apple for daughters teacher
5 years 7 months ago #202052 by GJTuck
Replied by GJTuck on topic Retrofit of Precix 5x10 CNC
Thanks for all the great information really appreciate the info. I’m hoping someone can help me out with a precix issue I’m having.
When I go to home the machine the z homes then the x but when it comes to the y it jumps about a inch then says y axis error. Any help would be greatly appreciated. I swapped the y and x encoder cables and nothing changed. I swapped the power cables nothing changed. I changed the amplifier nothing changed. I swapped the y moter with the z axis and immediately the z axis did the slight jump then a error. I ordered a new motor/encoder and just tried it out being certain that was the issue and it’s still doing the same thing. Any ideas? I thinking about changing out the limit switch wires, the lights on the board say they are working but I don’t have anything left to try. They have been repaired a few times.
5 years 7 months ago #202102 by randypetersen
Hoping a more knowledgeable person will chime in with a quick answer for you. Sounds like you did a lot of troubleshooting...
Could it just be your tuning parameters? Something in your software?
Could it be in your gears/belts? I had my Y bearing clog up with dust (before I had dust removal) and behave oddly. It was very hard to move my spindle across my Y axis. On your machine, is everything smooth physically?
I will ponder on this as well, but hoping the experts (who have helped me so much) will speak up and provide a quick answer for you.
Tell me more about your machine, post some pics...
The following user(s) said Thank You: GJTuck
Moderators: PCW, jmelson
Time to create page: 0.179 seconds
