Retrofit of Precix 5x10 CNC
6 years 7 months ago #159049 by randypetersen
Yep, replacing a motor might be less work. Actually I checked the spare parts box the guy gave me when I got the machine and he had a replacement "astromech" motor which has a post-it note saying "Good" on it. So I can replace that and switch the X and Y wires then if the Y fails I'll know it's a bad cable.
I hate losing control of the machine though, I might just buy the cable and replace the encoder cables as well.
6 years 7 months ago #159254 by andypugh
It's a lot of posts to go back through, so forgive me if this has been mentioned, but it might be worth hooking up the quadrature-error outputs (if you are using a Mesa card) to give a chance of detecting _some_ cabling or encoder errors.
6 years 7 months ago #159255 by randypetersen
Thanks Andy!
Why didn't I think of that? I am using the Mesa 7i77 and 7i92m boards.
Give me a minute while I look up what "quadrature-error outputs" are. :)
thanks,
Randy
6 years 7 months ago #159257 by andypugh
Note that it won't detect a single missing channel, and in that case a fast-moving axis will look like a static dithering axis, so might still run away.
You could also look at connecting the pid,N.saturated output, which will catch another class of problems.
6 years 7 months ago #159258 by andypugh
randypetersen wrote: Give me a minute while I look up what "quadrature-error outputs" are.
I am not sure that they are mentioned in the docs, but they exist in the code:
github.com/LinuxCNC/linuxcnc/blob/2.7/sr...tmot2/encoder.c#L509
So you need to set the "error-enable" bit in the HAL, and then you can monitor the outputs.
6 years 1 week ago #186589 by randypetersen
In case someone has similar problem wanted to report back.
After changing out the cables, CNC has not had any issues. So must have been encoder cables that I replaced. Used CNC a lot since then and been acting perfect [knock on wood].
Thanks for everyone's help as always.
Moderators: PCW, jmelson
Time to create page: 0.073 seconds
