Retrofit of Precix 5x10 CNC
6 years 11 months ago #150972 by randypetersen
Thanks PCW, always appreciate your help!
1) Here are my hal/ini files, let me know if you'd like to see anything else.
2) Yes, LinuxCNC enables the drives. AFAIK
6 years 11 months ago - 6 years 11 months ago #150974 by Todd Zuercher
It isnt' going to fix your problem, but your FERROR and MIN_FERROR are both much too large for your X axis servo. Probably should both be some fraction of an inch. (maybe 0.1 and 0.01)
An encoder fault won't necessarily cause a following error alarm during a run-away. For example on your X axis with the 5" ferror, if you command a 4" move and Linuxcnc does not detect any movement from the encoder, you now will have a run-away at the fastest speed your drive and motor can do, until it crashes.
Last edit: 6 years 11 months ago by Todd Zuercher.
6 years 11 months ago #150977 by randypetersen
Awesome, thanks Todd, ya, probably didn't fix that from when I was first setting it up.
It's definitely an encoder problem. With LinuxCNC open and drives not powered, if I manually push the Y axis I can see the DRO change. Same on Z, but not on X, so I am guessing my X encoder lost connection mid run. I am going through trying to check connections now.
6 years 11 months ago - 6 years 11 months ago #150985 by PCW
Replied by PCW on topic Retrofit of Precix 5x10 CNC
Yes, much smaller following error limits should be used so even a small commanded
move will result in a following error if the encoder position does not "follow" the move,
this would likely have prevented your runaways
Last edit: 6 years 11 months ago by PCW.
6 years 11 months ago #151629 by wefixprecix
Do you think it may be an encoder cable seperating as it bends through the flexible raceway...have a look at my username.
6 years 10 months ago #152277 by randypetersen
Thanks PCW!
I will get those changed, but if the cable lost connection, then would anything have prevented that?
Moderators: PCW, jmelson
Time to create page: 0.069 seconds
