Retrofit of Precix 5x10 CNC
5 years 3 months ago #213804 by bevins
Replied by bevins on topic Retrofit of Precix 5x10 CNC
I am almost done with his control. He only paid me for redoing his control. If will no doubt need me to go there and get things going. He may try at first though.
I will let you know and share files if I end up setting it up.
Does your control have two fans in there? Are they 12vdc fans? I think they were connected to the precix controller board. I dont want top blow his fans so it would be nice knowing what voltage they are.
5 years 3 months ago #213892 by randypetersen
I took a quick look I was running a job at the time. I have just one fan in front. There is a grill on top, but no fan on mine. I believe the FAN is 12V the label was facing the grill so couldn't be for certain. I can check the wiring in a bit to find out for sure.
Do you replace the motor power supply too? or using the one that it came with?
5 years 3 months ago #213952 by bevins
I heard from PRecix and they confirmed 12v fans.
I am keeping the motor power supply. I like a transformer I can power the grid with.  This toroidal tranny is huge.
5 years 3 months ago #213962 by randypetersen
Man I tried reaching out to PRECIX before I started this project and got zero response. I figured they moved on... Glad they are getting info to you. I wanted to talk with them about several things. For one, switching to rack and pinion, but honestly the belt system is working pretty decent.
I thought about ordering replacement belts to have on hand in case of any issues. This company:
shop.polybelt.com/25AT5-Open-End-Timing-...Cords-B25AT5-MPS.htm
Seem to carry the right belt.
Ya, that's a big chunk of transformer there. I read on a forum where the capacitors often go bad after a while, and was going to replace them. Never did though.
5 years 3 months ago #213969 by bevins
I am speaking with them. They want to replace the old controls with LinuxCNC using mesa 7i77. I am discussing with them on this. But what has happened is the PRECIX controller was running QNX connecting to the control board and the guy at Precix that knew all this stuff passed away sadly. So they are looking to update the old controls when they come back defective to LinuxCNC.
5 years 2 weeks ago - 5 years 2 weeks ago #223224 by CNCMELILLA
Buenas tengo una CNC precix soy de España la maquina me da unas palpitaciones en todos los ejes X Y Z tanto al moverla como al cortar ,no puedo solucionarlo y no encuentro ningún técnico que la entienda este tipo de CNC ,serian tan amables de decirme donde puedo encontrar uno ,gracias
Last edit: 5 years 2 weeks ago by CNCMELILLA.
Moderators: PCW, jmelson
Time to create page: 0.413 seconds
