Retrofit of Precix 5x10 CNC
5 years 4 months ago #212933 by randypetersen
I am sorry I missed this, I swear I have subscribed to this thread and hoped to get notifications but I don't.
If you still need them I will send whatever I have when I get to my shop tomorrow. I remember poking around that big plug finding them.
5 years 4 months ago - 5 years 4 months ago #212954 by bevins
Replied by bevins on topic Retrofit of Precix 5x10 CNC
randypetersen wrote: I am sorry I missed this, I swear I have subscribed to this thread and hoped to get notifications but I don't.
I dont need them now. I got most of the pinouts from Precix themselves.
I do have one question, there is a pair of wires coming out of the control box motor connector for the Z axis. I assume that is the brake for the Z motor. You have the polarity handy? It is just two grey wires. I ask because I am not near the machine and I am rebuilding the control remotely and will send it to him. I have all the pionouts of the other connectors.
also, is your configs online for your machine? What are the mechanics? rack and pinion?
Last edit: 5 years 4 months ago by bevins.
5 years 4 months ago #212955 by bevins
RandyPeterson,
What did you do for the copely drives? Did your redo the connectors or solder, cowboy splice them?
5 years 4 months ago - 5 years 4 months ago #212965 by randypetersen
not sure if this helps, but right or wrong, I put wire on the black side to the negative and the wire on the red side to the output pin on the 7i77 card... it's working... :)
No idea... it's kinda like this: www.precix.com/CNC_signmaker_10500.htm but I am guessing it's been modified with better spindle and some other things. It's got a belt which I planned on switching to rack&pinion, but haven't messed with it. Belts have been working ok actually. As far as I know...
Ya, I guess cowboy/splice them? Took the existing wires, and then soldered on my own wires to connect to the mesa card and other components. I am meaning to redo it, I kinda left it as it for testing, but since it's been working I haven't redone it yet. I bought a nice controller box but haven't done it yet.
Last edit: 5 years 4 months ago by randypetersen. Reason: added more info
5 years 4 months ago #213014 by bevins
The original control only has three drives and connections for three motors. I know thi is a gantry router.
Do you only have three motors also? Must be some kind of belt that drives both sides?
5 years 4 months ago - 5 years 4 months ago #213036 by randypetersen
Yes, you are correct, there is a shaft that goes through the Y axis gantry and drives the other sprocket/belt. The X axis motor (the one I just replaced) couples to that shaft, and that shaft has gear to another belt/gear on both sides to long belt/gear.
Yep, 3 servo motors on mine with columbo spindle.
The new magmotor I just added had a different shaft size, so I changed the coupler to a reducing coupler. Seems decent.
Please when they put your new controller in place and tune it to share the PID values. I am having an issue getting things behaving properly. It'd be nice to see some value of similar machines. Thanks.
Last edit: 5 years 4 months ago by randypetersen. Reason: added photos
The following user(s) said Thank You: bevins
Moderators: PCW, jmelson
Time to create page: 0.429 seconds
