Controller interfacing for dummies
10 Jun 2019 16:24 #136487 by PCW
Replied by PCW on topic Controller interfacing for dummies
I would also encourage first time LinuxCNC users to try the parallel port.
If it has sufficient performance for your needs, you wont require any additional
hardware except maybe a low cost BOB.
Its also simpler to setup than many other options
Note that its also usually better to use a motherboard with a built-in parallel port
to avoid possible issues with plug in board chipset support
The following user(s) said Thank You: andypugh
Moderators: PCW, jmelson
Time to create page: 0.335 seconds
