HAL Driver for Raspberry PI GPIOs
7 years 3 days ago #149022 by joao404
Hello,
I am using LinuxCNC directly on a Raspberry Pi 3B+ to control a little robotarm MK2. Because I wasn't able to find a proper driver for the gpios of the Pi, i used this Arduino based solution( github.com/dewy721/EMC-2-Arduino ) to control the stepper motors and servos. But this shows as expected only poor results.
I am currently writting a HAL driver for the gpios of Pi based on the hal_parport.c and the libgpiod. Is libgpiod in this case a good solution or are there faster ways to write and read pins and of better use in case of realtime?
I put the code for free use at github.com/joao404/HAL2PI . At the moment the reset function and inverted datasignals are not finished.
If someone knows a better existing solution or has some notes about my coding it would be nice to get some feedback.
Greetings
Marcel
The following user(s) said Thank You: Mike_Eitel
7 years 3 days ago #149052 by pl7i92
there are lots of projekts alredy running so you may not need a Haldriver
look on the search field and giv it a try
Raspberry Pi
7 years 3 days ago #149071 by Mike_Eitel
I myself would love to have something like a hal_pi_gpio in standard distro. Similar to the bb version.
Not for real machine, i'm a pure fan of Mesa, but for playing with Pi4 this would be nice.
Mike
7 years 2 days ago #149079 by joao404
I found one project at erste.de/linuxCNC_raspberry_PI4.html (bottom part) which uses WiringPi and a file called hal_gpio.c which you can download from linuxcnc.org.
Marcel
7 years 6 hours ago #149355 by andypugh
joao404 wrote: If someone knows a better existing solution
If you get version 2.8 / uspace then you should be able to use the hal_pi_gpio component that was recently added.
github.com/LinuxCNC/linuxcnc/commit/e0dc...52586d505f4b9bcda60d
Scroll to the last file on that page to see sample HAL-file usage.
The following user(s) said Thank You: Mike_Eitel, Vector
  • twoflowers
  • New Member
  • New Member
6 years 8 months ago - 6 years 8 months ago #157180 by twoflowers
Replied by twoflowers on topic HAL Driver for Raspberry PI GPIOs
I have made a small tool to calculate the "loadrt hal_pi_gpio dir=... exclude=..."-line. Hope it helps.
Example: hal_pi_gpio-calculator.sh 17:27:22 2:3:4:12:14:15:18
--> loadrt hal_pi_gpio dir=78855 exclude=32394232
Enjoy :)
File Name: hal_pi_gpi...or.sh.gz
File Size:769 B
Last edit: 6 years 8 months ago by twoflowers.
Moderators: PCW, jmelson
Time to create page: 0.083 seconds
