HAL Driver for Raspberry PI GPIOs
20 Dec 2020 14:58 #192542 by Markyd
Replied by Markyd on topic HAL Driver for Raspberry PI GPIOs
still no luck, regardless of what syntax i use. I've tried all the variations below without success. I've even tried the xdir pin but the result is the same. Does the hal_pi_gpio accept invert?
#setp hal_pi_gpio.pin-29-invert true
#setp hal_pi_gpio.pin-29-out-invert true
#setp hal_pi_gpio.pin-29.invert true
#setp hal_pi_gpio.pin-29.invert-output true
#setp hal_pi_gpio.pin-29.invert_output true
#setp hal_pi_gpio.pin-29-out.invert-output TRUE
#setp hal_pi_gpio.pin-29-out.invert_output TRUE
net xenable => hal_pi_gpio.pin-29-out
20 Dec 2020 15:01 #192543 by PCW
Replied by PCW on topic HAL Driver for Raspberry PI GPIOs
Rather than guessing, why don't you look at all available pins/parameters?
halcmd show all hal_pi
20 Dec 2020 15:15 - 20 Dec 2020 15:17 #192546 by Markyd
I'm new to linuxcnc so the 'obvious' isn't yet obvious to me, so thanks for the suggestion. I get the following, which seems to recognise "hal_pi_gpio.pin-29-out <== xenable" but says Dir is "IN" which i don't understand ??
pi@linuxcnc:~ $ halcmd show all hal_pi
Loaded HAL Components:
ID Type Name PID State
31 RT hal_pi_gpio ready
Component Pins:
Owner Type Dir Value Name
31 bit OUT FALSE hal_pi_gpio.pin-03-in ==> limit-z-switch
31 bit OUT FALSE hal_pi_gpio.pin-11-in
31 bit OUT FALSE hal_pi_gpio.pin-12-in
31 bit OUT FALSE hal_pi_gpio.pin-13-in ==> limit-x-switch
31 bit IN FALSE hal_pi_gpio.pin-15-out
31 bit OUT FALSE hal_pi_gpio.pin-16-in ==> limit-y-switch
31 bit OUT FALSE hal_pi_gpio.pin-18-in ==> not-1-in
31 bit IN FALSE hal_pi_gpio.pin-19-out <== ydir
31 bit IN FALSE hal_pi_gpio.pin-21-out
31 bit IN FALSE hal_pi_gpio.pin-22-out
31 bit IN FALSE hal_pi_gpio.pin-23-out <== ystep
31 bit IN FALSE hal_pi_gpio.pin-24-out <== xdir
31 bit IN FALSE hal_pi_gpio.pin-26-out <== spindle-on
31 bit IN FALSE hal_pi_gpio.pin-29-out <== xenable
31 bit IN FALSE hal_pi_gpio.pin-31-out
31 bit IN FALSE hal_pi_gpio.pin-32-out <== xstep
31 bit IN FALSE hal_pi_gpio.pin-33-out
31 bit IN FALSE hal_pi_gpio.pin-35-out
31 bit IN FALSE hal_pi_gpio.pin-36-out <== zstep
31 bit IN FALSE hal_pi_gpio.pin-37-out
31 bit IN FALSE hal_pi_gpio.pin-38-out
31 bit IN FALSE hal_pi_gpio.pin-40-out <== zdir
31 s32 OUT 1093 hal_pi_gpio.read.time
31 s32 OUT 833 hal_pi_gpio.write.time
Last edit: 20 Dec 2020 15:17 by Markyd.
20 Dec 2020 15:23 #192547 by Markyd
There is no mention of the word "Invert" in github.com/LinuxCNC/linuxcnc/blob/master...rivers/hal_pi_gpio.c, is that likely to be significant ?
20 Dec 2020 15:26 - 20 Dec 2020 15:28 #192548 by PCW
Right, so the hal_pi_gpio driver is pretty bare bones
and doesn't have invert capability on inputs or outputs
(the pin/parameter listing would show these if the driver provided them)
You could use the hal "not" component to invert the desired signals
(or bug the hal_pi_gpio writer to add invert capability)
Last edit: 20 Dec 2020 15:28 by PCW.
20 Dec 2020 16:13 #192555 by Markyd
I think I'm just going to have to unplug the enable pins for now as i've just demonstrated to myself that I don't know what I'm doing with "not" and addf !
20 Dec 2020 17:06 #192556 by jmelson
Replied by jmelson on topic HAL Driver for Raspberry PI GPIOs
The # at the beginning makes the line a comment. Did you actually have the # as the first character on the line?
If so, try without the #.
Jon
20 Dec 2020 17:46 #192559 by Markyd
I'd been commenting them in and out as i tried them in turn
03 Jan 2021 08:17 - 03 Jan 2021 14:26 #193932 by nion
Replied by nion on topic HAL Driver for Raspberry PI GPIOs
Hello
I'm using RPI4 with 7i92 for the moment but I want to add one encoder for feed override using the RPI GPIO driver.
This is what I added to my hal file but I don't get reading on Hal Meter hal_pi_gpio.pin-03-in and hal_pi_gpio.pin-05-in. I also tried different pins with no success.
Can someone please point me what I'm doing wrong
loadrt hal_pi_gpio dir=67108860 exclude=0
loadrt encoder num_chan=1
addf encoder.capture-position servo-thread
addf encoder.update-counters servo-thread
setp halui.feed-override.scale .005
net feedcount halui.feed-override.counts <= encoder.0.counts
net feedup encoder.0.phase-A <= hal_pi_gpio.pin-03-in
net feeddown encoder.0.phase-B <= hal_pi_gpio.pin-05-in
_______________________________________________________
Component Pins:
29 bit OUT FALSE hal_pi_gpio.pin-03-in ==> feedup
29 bit OUT FALSE hal_pi_gpio.pin-05-in ==> feeddown
29 bit IN FALSE hal_pi_gpio.pin-07-out
29 bit IN FALSE hal_pi_gpio.pin-08-out
29 bit IN FALSE hal_pi_gpio.pin-10-out
29 bit IN FALSE hal_pi_gpio.pin-11-out
29 bit IN FALSE hal_pi_gpio.pin-12-out
29 bit IN FALSE hal_pi_gpio.pin-13-out
29 bit IN FALSE hal_pi_gpio.pin-15-out
29 bit IN FALSE hal_pi_gpio.pin-16-out
29 bit IN FALSE hal_pi_gpio.pin-18-out
29 bit IN FALSE hal_pi_gpio.pin-19-out
29 bit IN FALSE hal_pi_gpio.pin-21-out
29 bit IN FALSE hal_pi_gpio.pin-22-out
29 bit IN FALSE hal_pi_gpio.pin-23-out
29 bit IN FALSE hal_pi_gpio.pin-24-out
29 bit IN FALSE hal_pi_gpio.pin-26-out
29 bit IN FALSE hal_pi_gpio.pin-29-out
29 bit IN FALSE hal_pi_gpio.pin-31-out
29 bit IN FALSE hal_pi_gpio.pin-32-out
29 bit IN FALSE hal_pi_gpio.pin-33-out
29 bit IN FALSE hal_pi_gpio.pin-35-out
29 bit IN FALSE hal_pi_gpio.pin-36-out
29 bit IN FALSE hal_pi_gpio.pin-37-out
29 bit IN FALSE hal_pi_gpio.pin-38-out
29 bit IN FALSE hal_pi_gpio.pin-40-out
29 s32 OUT 0 hal_pi_gpio.read.time
29 s32 OUT 0 hal_pi_gpio.write.time
Last edit: 03 Jan 2021 14:26 by nion. Reason: Incomplete question
03 Jan 2021 13:35 #193952 by tommylight
Replied by tommylight on topic HAL Driver for Raspberry PI GPIOs
Is the encoder wired to 7i92 or RPI?
Moderators: PCW, jmelson
Time to create page: 0.154 seconds
