HAL Driver for Raspberry PI GPIOs
- joao404
29 Oct 2019 00:03 #149022
by joao404
HAL Driver for Raspberry PI GPIOs was created by joao404
Hello,
I am using LinuxCNC directly on a Raspberry Pi 3B+ to control a little robotarm MK2. Because I wasn't able to find a proper driver for the gpios of the Pi, i used this Arduino based solution(github.com/dewy721/EMC-2-Arduino) to control the stepper motors and servos. But this shows as expected only poor results.
I am currently writting a HAL driver for the gpios of Pi based on the hal_parport.c and the libgpiod. Is libgpiod in this case a good solution or are there faster ways to write and read pins and of better use in case of realtime?
I put the code for free use at github.com/joao404/HAL2PI. At the moment the reset function and inverted datasignals are not finished.
If someone knows a better existing solution or has some notes about my coding it would be nice to get some feedback.
Greetings
Marcel
Greetings
Marcel
The following user(s) said Thank You: Mike_Eitel
- pl7i92
- Thank you received: 358
29 Oct 2019 14:50 #149052
by pl7i92
Replied by pl7i92 on topic HAL Driver for Raspberry PI GPIOs
there are lots of projekts alredy running so you may not need a Haldriver
look on the search field and giv it a try
Raspberry Pi
Raspberry Pi
- Mike_Eitel
- Thank you received: 183
29 Oct 2019 19:28 #149071
by Mike_Eitel
Replied by Mike_Eitel on topic HAL Driver for Raspberry PI GPIOs
I myself would love to have something like a hal_pi_gpio in standard distro. Similar to the bb version.
Not for real machine, i'm a pure fan of Mesa, but for playing with Pi4 this would be nice.
Mike
Mike
- joao404
29 Oct 2019 22:44 #149079
by joao404
Replied by joao404 on topic HAL Driver for Raspberry PI GPIOs
I found one project at erste.de/linuxCNC_raspberry_PI4.html (bottom part) which uses WiringPi and a file called hal_gpio.c which you can download from linuxcnc.org.
Marcel
Marcel
01 Nov 2019 13:26 #149355
If you get version 2.8 / uspace then you should be able to use the hal_pi_gpio component that was recently added.
github.com/LinuxCNC/linuxcnc/commit/e0dc...52586d505f4b9bcda60d
Scroll to the last file on that page to see sample HAL-file usage.
Replied by andypugh on topic HAL Driver for Raspberry PI GPIOs
The following user(s) said Thank You: Mike_Eitel, Vector
- twoflowers
- Visitor
12 Feb 2020 15:03 - 12 Feb 2020 15:07 #157180
by twoflowers
Replied by twoflowers on topic HAL Driver for Raspberry PI GPIOs
I have made a small tool to calculate the "loadrt hal_pi_gpio dir=... exclude=..."-line. Hope it helps.
Example: hal_pi_gpio-calculator.sh 17:27:22 2:3:4:12:14:15:18
--> loadrt hal_pi_gpio dir=78855 exclude=32394232
Enjoy
Enjoy
Last edit: 12 Feb 2020 15:07 by twoflowers.
- juscious
04 May 2020 17:26 #166644
by juscious
Replied by juscious on topic HAL Driver for Raspberry PI GPIOs
I am new to this, but i badly need to make Linux cnc to work with RPI GPIO outputs. Maybe someone could share like a working example of configs?
Or maybe someone please explain step by step how to do it.
Thanks in advance.
Thanks in advance.
- twoflowers
- Visitor
04 May 2020 17:52 #166648
by twoflowers
- juscious
04 May 2020 18:21 - 04 May 2020 18:28 #166653
by juscious
Thanks very much !
I get error hal_gpio: dlopen: /usr/lib/linuxcnc/modules/hal_gpio.so cannot open shared object file.
In directory there is only closest to it hal_bb_gpio.so...
Maybe i could get that file too please?
Last edit: 04 May 2020 18:28 by juscious.
- twoflowers
- Visitor
04 May 2020 19:22 - 04 May 2020 19:24 #166662
by twoflowers
oh, sorry, please use "hal_pi_gpio" and you'll need linuxcnc 2.8, the gpio driver for rpi is included in linuxcnc since some months now.
Last edit: 04 May 2020 19:24 by twoflowers.
Time to create page: 0.954 seconds
