Mesa 7i95
6 years 9 months ago #155390 by PCW
Replied by PCW on topic Mesa 7i95
Here they are:
The following user(s) said Thank You: dkraft, Sergiy_J_S_Automatic
6 years 9 months ago #155398 by cmorley
Replied by cmorley on topic Mesa 7i95
Thanks Peter - unfortunately it has more then 50 pins so it will require extensive code changes - may be awhile to get this one done.
Chris
The following user(s) said Thank You: Pro_El
6 years 9 months ago #155401 by sdwyer
Replied by sdwyer on topic Mesa 7i95
Hi Peter,
PCW wrote: You could use the parallel expansion port for driving that interface
Just make sure you have common grounds before you connect signals
To be clear, you're suggesting a software based PWM instead of a hardware based 'pwmgen' ? or am I missing something about setting modes on the GPIO pins on P1.
I'd prefer to use a hardware pwmgen if thats possible.
Cheers!
Shaun
6 years 9 months ago #155436 by PCW
File Name: 7i95abob.zip
File Size:129.06 KB
7I95 config with PWM on pin 1 of expansion connector
The following user(s) said Thank You: sdwyer
6 years 9 months ago #155482 by sdwyer
Thanks very much Peter!
6 years 9 months ago #155895 by 0x2102
Replied by 0x2102 on topic Mesa 7i95
I noticed a problem with the 7i95 input / input-not pins in LinuxCNC 2.9 latest version. They normally flip-flop.
input-00 low
input-00-not high
input-00 high
input-00-not low
but input-xx-not stays low all the time.
Moderators: PCW, jmelson
Time to create page: 0.343 seconds
