Mesa 7i95
27 Nov 2019 11:41 #151371 by Gnevko
Mesa 7i95 was created by Gnevko
I try to run my new Mesa Board 7i95 with Linux 2.8 and get following message:
"Unrecognized ethernet board found: 7I95 -- port names will be wrong"
At this point I don't know if it's very bad or I can just ignore this message?
Thank you in advance!
27 Nov 2019 12:13 #151376 by PCW
Replied by PCW on topic Mesa 7i95
That will not interfere with basic operations but to support the isolated inputs you would need to install linuxCNC via source and apply the latest changes that provide 7I95 support
27 Nov 2019 12:18 #151377 by Gnevko
Replied by Gnevko on topic Mesa 7i95
oje, such "great news" :(
"latest changes" - are they already committed in the 2.8 head brunch?
27 Nov 2019 12:45 #151379 by PCW
Not yet but the sources are available here:
freeby.mesanet.com/newmesa.zip
( This needs to be unzipped in the src/hal/drivers/mesa-hostmot2 directory and
the included Makefile moved to src )
The following user(s) said Thank You: Gnevko
27 Nov 2019 13:31 #151384 by Gnevko
I can't believe I see it :)
27 Nov 2019 14:45 #151393 by Gnevko
At first I build linuxcnc without your patch and of course I received the same result as at start, but after I copied files -
something is going wrong hier but I can't understand what exactly:
cnc@cnc:~/linuxcnc-dev$ ./scripts/rip-environment linuxcnc
LINUXCNC - 2.9.0~pre0
Machine configuration directory is '/home/cnc/linuxcnc/configs/WabecoTest'
Machine configuration file is 'WabecoTest.ini'
Starting LinuxCNC...
Found file(REL): ./WabecoTest.hal
Note: Using POSIX realtime
hostmot2: dlopen: /home/cnc/linuxcnc-dev/rtlib/hostmot2.so: undefined symbol: hm2_inm_prepare_tram_write
./WabecoTest.hal:4: waitpid failed /home/cnc/linuxcnc-dev/bin/rtapi_app hostmot2
./WabecoTest.hal:4: /home/cnc/linuxcnc-dev/bin/rtapi_app exited without becoming ready
./WabecoTest.hal:4: insmod for hostmot2 failed, returned -1
LinuxCNC terminated with an error.  You can find more information in the log:
    /home/cnc/linuxcnc_debug.txt
and
    /home/cnc/linuxcnc_print.txt
as well as in the output of the shell command 'dmesg' and in the terminal
27 Nov 2019 14:51 #151395 by PCW
Did you copy the new Makefile to the src directory?
27 Nov 2019 14:52 - 27 Nov 2019 14:55 #151396 by Gnevko
yes, i checked it more times
copied to following directory: /home/cnc/linuxcnc-dev/src/
Last edit: 27 Nov 2019 14:55 by Gnevko.
27 Nov 2019 15:27 #151399 by PCW
Yeah the makefile was missing the latest new module
try refetching newmesa.zip, it should be fixed now
27 Nov 2019 15:39 #151400 by Gnevko
Thank you, I will try it tomorrow. Is it enough just to call "make" command again or I need begin from scratch? I never build something under Linux... till now
Moderators: PCW, jmelson
Time to create page: 0.926 seconds
