Mesa 7i95
02 Feb 2023 14:36 #263523 by pingtomi
Replied by pingtomi on topic Mesa 7i95
I use stock firmware, haven't flashed yet, here is the output:
Parameters:
Owner Type Dir Value Name
30 bit RW FALSE hm2_7i95.0.inmux.00.enc0_4xmode
30 bit RW FALSE hm2_7i95.0.inmux.00.enc1_4xmode
30 bit RW FALSE hm2_7i95.0.inmux.00.enc2_4xmode
30 bit RW FALSE hm2_7i95.0.inmux.00.enc3_4xmode
30 u32 RW 0x00000005 hm2_7i95.0.inmux.00.fast_scans
30 u32 RW 0x00004E20 hm2_7i95.0.inmux.00.scan_rate
30 u32 RO 0x00000018 hm2_7i95.0.inmux.00.scan_width
30 u32 RW 0x000001F4 hm2_7i95.0.inmux.00.slow_scans
Thx a lot
Tamas
02 Feb 2023 15:04 #263528 by PCW
Replied by PCW on topic Mesa 7i95
Sounds the 7I95 has developed a defect
(It needed to pass a I/O loopback test of all I/O points before it was shipped)
Mesa can issue a RMA for evaluation, repair or replacement of the card.
Please email Mesa with the card name and serial and they will issue a RMA
04 Feb 2023 19:04 #263692 by pingtomi
Sad to hear but I've just realized that 7i95 does not have enough inputs for my project because I need at least +24 inputs so +/- 8 (which do not work now) do not matters and to be honest I don't prefer to return my card because I'm afraid it would required long time due to global supply chain issues, delivery times between EU and US, etc so I'm wondering would be an additional 7i70 good solution? Will it work together with 7i95 if I connect them through the serial interface?
Thank you.
Tamas
04 Feb 2023 19:34 #263701 by tommylight
Replied by tommylight on topic Mesa 7i95
Yes, it should work.
Might want to check Mesa 7i84, it is the same SSerial card but has 32 inputs and 16 outputs.
Moderators: PCW, jmelson
