Mesa 7i95
- mittim
- Thank you received: 5
10 Oct 2021 18:15 - 10 Oct 2021 18:16 #222786
by mittim
Replied by mittim on topic Mesa 7i95
After defining my home sequence and joining y1 and y2, I only have to home once and the sequence starts
I will go deeper into HAL and INI the next days. Thanks for now, awesome forum!
Last edit: 10 Oct 2021 18:16 by mittim.
- mittim
14 Oct 2021 19:13 #223107
by mittim
I am currently trying to get my OUTPUTS and INPUTS working.
Trying to set "setp hm2_7i95.0.gpio.041.out TRUE" via the HAL-configurator shows the set value in the terminal but measuring the OUTPUT voltage is close to 0V. What am I doing wrong?
Component Pins:
Owner Type Dir Value Name
26 float IN 100 hm2_7i95.0.dpll.01.timer-us
26 float IN 100 hm2_7i95.0.dpll.02.timer-us
26 float IN 100 hm2_7i95.0.dpll.03.timer-us
26 float IN 100 hm2_7i95.0.dpll.04.timer-us
26 float IN 1 hm2_7i95.0.dpll.base-freq-khz
26 u32 OUT 0x0000002A hm2_7i95.0.dpll.ddsize
26 float OUT -11.08391 hm2_7i95.0.dpll.phase-error-us
26 u32 IN 0x00400000 hm2_7i95.0.dpll.plimit
26 u32 OUT 0x00000018 hm2_7i95.0.dpll.prescale
26 u32 IN 0x000007D0 hm2_7i95.0.dpll.time-const
26 s32 OUT 0 hm2_7i95.0.encoder.00.count
26 s32 OUT 0 hm2_7i95.0.encoder.00.count-latched
26 bit I/O FALSE hm2_7i95.0.encoder.00.index-enable
26 bit OUT TRUE hm2_7i95.0.encoder.00.input-a
26 bit OUT FALSE hm2_7i95.0.encoder.00.input-b
26 bit OUT TRUE hm2_7i95.0.encoder.00.input-index
26 float OUT 0 hm2_7i95.0.encoder.00.position
26 float OUT 0 hm2_7i95.0.encoder.00.position-latched
26 bit OUT FALSE hm2_7i95.0.encoder.00.quad-error
26 bit IN FALSE hm2_7i95.0.encoder.00.quad-error-enable
26 s32 OUT 1 hm2_7i95.0.encoder.00.rawcounts
26 s32 OUT 1 hm2_7i95.0.encoder.00.rawlatch
26 bit IN FALSE hm2_7i95.0.encoder.00.reset
26 float OUT 0 hm2_7i95.0.encoder.00.velocity
26 float OUT 0 hm2_7i95.0.encoder.00.velocity-rpm
26 bit IN FALSE hm2_7i95.0.encoder.hires-timestamp
26 u32 IN 0x007F2815 hm2_7i95.0.encoder.muxed-sample-frequency
26 s32 IN -1 hm2_7i95.0.encoder.timer-number
26 bit OUT FALSE hm2_7i95.0.gpio.000.in
26 bit OUT TRUE hm2_7i95.0.gpio.000.in_not
26 bit OUT FALSE hm2_7i95.0.gpio.001.in
26 bit OUT TRUE hm2_7i95.0.gpio.001.in_not
26 bit OUT FALSE hm2_7i95.0.gpio.002.in
26 bit OUT TRUE hm2_7i95.0.gpio.002.in_not
26 bit OUT FALSE hm2_7i95.0.gpio.003.in
26 bit OUT TRUE hm2_7i95.0.gpio.003.in_not
26 bit OUT FALSE hm2_7i95.0.gpio.004.in
26 bit OUT TRUE hm2_7i95.0.gpio.004.in_not
26 bit OUT FALSE hm2_7i95.0.gpio.005.in
26 bit OUT TRUE hm2_7i95.0.gpio.005.in_not
26 bit OUT FALSE hm2_7i95.0.gpio.006.in
26 bit OUT TRUE hm2_7i95.0.gpio.006.in_not
26 bit OUT FALSE hm2_7i95.0.gpio.007.in
26 bit OUT TRUE hm2_7i95.0.gpio.007.in_not
26 bit OUT FALSE hm2_7i95.0.gpio.008.in
26 bit OUT TRUE hm2_7i95.0.gpio.008.in_not
26 bit OUT FALSE hm2_7i95.0.gpio.009.in
26 bit OUT TRUE hm2_7i95.0.gpio.009.in_not
26 bit OUT FALSE hm2_7i95.0.gpio.010.in
26 bit OUT TRUE hm2_7i95.0.gpio.010.in_not
26 bit OUT FALSE hm2_7i95.0.gpio.011.in
26 bit OUT TRUE hm2_7i95.0.gpio.011.in_not
26 bit OUT FALSE hm2_7i95.0.gpio.012.in
26 bit OUT TRUE hm2_7i95.0.gpio.012.in_not
26 bit IN FALSE hm2_7i95.0.gpio.012.out
26 bit OUT TRUE hm2_7i95.0.gpio.013.in
26 bit OUT FALSE hm2_7i95.0.gpio.013.in_not
26 bit IN FALSE hm2_7i95.0.gpio.013.out
26 bit OUT TRUE hm2_7i95.0.gpio.014.in
26 bit OUT FALSE hm2_7i95.0.gpio.014.in_not
26 bit IN FALSE hm2_7i95.0.gpio.014.out
26 bit OUT TRUE hm2_7i95.0.gpio.015.in
26 bit OUT FALSE hm2_7i95.0.gpio.015.in_not
26 bit IN FALSE hm2_7i95.0.gpio.015.out
26 bit OUT TRUE hm2_7i95.0.gpio.016.in
26 bit OUT FALSE hm2_7i95.0.gpio.016.in_not
26 bit IN FALSE hm2_7i95.0.gpio.016.out
26 bit OUT TRUE hm2_7i95.0.gpio.017.in
26 bit OUT FALSE hm2_7i95.0.gpio.017.in_not
26 bit IN FALSE hm2_7i95.0.gpio.017.out
26 bit OUT TRUE hm2_7i95.0.gpio.018.in
26 bit OUT FALSE hm2_7i95.0.gpio.018.in_not
26 bit OUT FALSE hm2_7i95.0.gpio.019.in
26 bit OUT TRUE hm2_7i95.0.gpio.019.in_not
26 bit OUT TRUE hm2_7i95.0.gpio.020.in
26 bit OUT FALSE hm2_7i95.0.gpio.020.in_not
26 bit OUT FALSE hm2_7i95.0.gpio.021.in
26 bit OUT TRUE hm2_7i95.0.gpio.021.in_not
26 bit IN FALSE hm2_7i95.0.gpio.021.out
26 bit OUT FALSE hm2_7i95.0.gpio.022.in
26 bit OUT TRUE hm2_7i95.0.gpio.022.in_not
26 bit IN FALSE hm2_7i95.0.gpio.022.out
26 bit OUT TRUE hm2_7i95.0.gpio.023.in
26 bit OUT FALSE hm2_7i95.0.gpio.023.in_not
26 bit IN FALSE hm2_7i95.0.gpio.023.out
26 bit OUT FALSE hm2_7i95.0.gpio.024.in
26 bit OUT TRUE hm2_7i95.0.gpio.024.in_not
26 bit IN FALSE hm2_7i95.0.gpio.024.out
26 bit OUT FALSE hm2_7i95.0.gpio.025.in
26 bit OUT TRUE hm2_7i95.0.gpio.025.in_not
26 bit IN FALSE hm2_7i95.0.gpio.025.out
26 bit OUT FALSE hm2_7i95.0.gpio.026.in
26 bit OUT TRUE hm2_7i95.0.gpio.026.in_not
26 bit IN FALSE hm2_7i95.0.gpio.026.out
26 bit OUT FALSE hm2_7i95.0.gpio.027.in
26 bit OUT TRUE hm2_7i95.0.gpio.027.in_not
26 bit OUT FALSE hm2_7i95.0.gpio.028.in
26 bit OUT TRUE hm2_7i95.0.gpio.028.in_not
26 bit OUT TRUE hm2_7i95.0.gpio.029.in
26 bit OUT FALSE hm2_7i95.0.gpio.029.in_not
26 bit OUT FALSE hm2_7i95.0.gpio.030.in
26 bit OUT TRUE hm2_7i95.0.gpio.030.in_not
26 bit OUT FALSE hm2_7i95.0.gpio.031.in
26 bit OUT TRUE hm2_7i95.0.gpio.031.in_not
26 bit OUT FALSE hm2_7i95.0.gpio.032.in
26 bit OUT TRUE hm2_7i95.0.gpio.032.in_not
26 bit OUT TRUE hm2_7i95.0.gpio.033.in
26 bit OUT FALSE hm2_7i95.0.gpio.033.in_not
26 bit OUT TRUE hm2_7i95.0.gpio.034.in
26 bit OUT FALSE hm2_7i95.0.gpio.034.in_not
26 bit OUT TRUE hm2_7i95.0.gpio.035.in
26 bit OUT FALSE hm2_7i95.0.gpio.035.in_not
26 bit OUT TRUE hm2_7i95.0.gpio.036.in
26 bit OUT FALSE hm2_7i95.0.gpio.036.in_not
26 bit OUT TRUE hm2_7i95.0.gpio.037.in
26 bit OUT FALSE hm2_7i95.0.gpio.037.in_not
26 bit OUT TRUE hm2_7i95.0.gpio.038.in
26 bit OUT FALSE hm2_7i95.0.gpio.038.in_not
26 bit OUT TRUE hm2_7i95.0.gpio.039.in
26 bit OUT FALSE hm2_7i95.0.gpio.039.in_not
26 bit OUT TRUE hm2_7i95.0.gpio.040.in
26 bit OUT FALSE hm2_7i95.0.gpio.040.in_not
26 bit OUT TRUE hm2_7i95.0.gpio.041.in
26 bit OUT FALSE hm2_7i95.0.gpio.041.in_not
26 bit IN TRUE hm2_7i95.0.gpio.041.out
26 bit OUT TRUE hm2_7i95.0.gpio.042.in
26 bit OUT FALSE hm2_7i95.0.gpio.042.in_not
26 bit IN FALSE hm2_7i95.0.gpio.042.out
26 bit OUT TRUE hm2_7i95.0.gpio.043.in
26 bit OUT FALSE hm2_7i95.0.gpio.043.in_not
26 bit IN FALSE hm2_7i95.0.gpio.043.out
26 bit OUT TRUE hm2_7i95.0.gpio.044.in
26 bit OUT FALSE hm2_7i95.0.gpio.044.in_not
26 bit IN FALSE hm2_7i95.0.gpio.044.out
26 bit OUT TRUE hm2_7i95.0.gpio.045.in
26 bit OUT FALSE hm2_7i95.0.gpio.045.in_not
26 bit IN FALSE hm2_7i95.0.gpio.045.out
26 bit OUT TRUE hm2_7i95.0.gpio.046.in
26 bit OUT FALSE hm2_7i95.0.gpio.046.in_not
26 bit IN FALSE hm2_7i95.0.gpio.046.out
26 bit OUT TRUE hm2_7i95.0.gpio.047.in
26 bit OUT FALSE hm2_7i95.0.gpio.047.in_not
26 bit IN FALSE hm2_7i95.0.gpio.047.out
26 bit OUT TRUE hm2_7i95.0.gpio.048.in
26 bit OUT FALSE hm2_7i95.0.gpio.048.in_not
26 bit IN FALSE hm2_7i95.0.gpio.048.out
26 bit OUT TRUE hm2_7i95.0.gpio.049.in
26 bit OUT FALSE hm2_7i95.0.gpio.049.in_not
26 bit IN FALSE hm2_7i95.0.gpio.049.out
26 bit OUT TRUE hm2_7i95.0.gpio.050.in
26 bit OUT FALSE hm2_7i95.0.gpio.050.in_not
26 bit IN FALSE hm2_7i95.0.gpio.050.out
26 bit OUT TRUE hm2_7i95.0.gpio.051.in
26 bit OUT FALSE hm2_7i95.0.gpio.051.in_not
26 bit IN FALSE hm2_7i95.0.gpio.051.out
26 bit OUT TRUE hm2_7i95.0.gpio.052.in
26 bit OUT FALSE hm2_7i95.0.gpio.052.in_not
26 bit IN FALSE hm2_7i95.0.gpio.052.out
26 bit OUT TRUE hm2_7i95.0.gpio.053.in
26 bit OUT FALSE hm2_7i95.0.gpio.053.in_not
26 bit IN FALSE hm2_7i95.0.gpio.053.out
26 bit OUT TRUE hm2_7i95.0.gpio.054.in
26 bit OUT FALSE hm2_7i95.0.gpio.054.in_not
26 bit IN FALSE hm2_7i95.0.gpio.054.out
26 bit OUT TRUE hm2_7i95.0.gpio.055.in
26 bit OUT FALSE hm2_7i95.0.gpio.055.in_not
26 bit IN FALSE hm2_7i95.0.gpio.055.out
26 bit OUT TRUE hm2_7i95.0.gpio.056.in
26 bit OUT FALSE hm2_7i95.0.gpio.056.in_not
26 bit IN FALSE hm2_7i95.0.gpio.056.out
26 bit OUT TRUE hm2_7i95.0.gpio.057.in
26 bit OUT FALSE hm2_7i95.0.gpio.057.in_not
26 bit IN FALSE hm2_7i95.0.gpio.057.out
26 s32 OUT 0 hm2_7i95.0.inmux.00.enc0-count
26 s32 OUT 0 hm2_7i95.0.inmux.00.enc1-count
26 s32 OUT 0 hm2_7i95.0.inmux.00.enc2-count
26 s32 OUT 0 hm2_7i95.0.inmux.00.enc3-count
26 bit OUT FALSE hm2_7i95.0.inmux.00.input-00
26 bit OUT TRUE hm2_7i95.0.inmux.00.input-00-not
26 bit IN FALSE hm2_7i95.0.inmux.00.input-00-slow
26 bit OUT FALSE hm2_7i95.0.inmux.00.input-01
26 bit OUT TRUE hm2_7i95.0.inmux.00.input-01-not
26 bit IN FALSE hm2_7i95.0.inmux.00.input-01-slow
26 bit OUT FALSE hm2_7i95.0.inmux.00.input-02
26 bit OUT TRUE hm2_7i95.0.inmux.00.input-02-not
26 bit IN FALSE hm2_7i95.0.inmux.00.input-02-slow
26 bit OUT FALSE hm2_7i95.0.inmux.00.input-03
26 bit OUT TRUE hm2_7i95.0.inmux.00.input-03-not
26 bit IN FALSE hm2_7i95.0.inmux.00.input-03-slow
26 bit OUT FALSE hm2_7i95.0.inmux.00.input-04
26 bit OUT TRUE hm2_7i95.0.inmux.00.input-04-not
26 bit IN FALSE hm2_7i95.0.inmux.00.input-04-slow
26 bit OUT FALSE hm2_7i95.0.inmux.00.input-05
26 bit OUT TRUE hm2_7i95.0.inmux.00.input-05-not
26 bit IN FALSE hm2_7i95.0.inmux.00.input-05-slow
26 bit OUT FALSE hm2_7i95.0.inmux.00.input-06
26 bit OUT TRUE hm2_7i95.0.inmux.00.input-06-not
26 bit IN FALSE hm2_7i95.0.inmux.00.input-06-slow
26 bit OUT FALSE hm2_7i95.0.inmux.00.input-07
26 bit OUT TRUE hm2_7i95.0.inmux.00.input-07-not
26 bit IN FALSE hm2_7i95.0.inmux.00.input-07-slow
26 bit OUT FALSE hm2_7i95.0.inmux.00.input-08
26 bit OUT TRUE hm2_7i95.0.inmux.00.input-08-not
26 bit IN FALSE hm2_7i95.0.inmux.00.input-08-slow
26 bit OUT FALSE hm2_7i95.0.inmux.00.input-09
26 bit OUT TRUE hm2_7i95.0.inmux.00.input-09-not
26 bit IN FALSE hm2_7i95.0.inmux.00.input-09-slow
26 bit OUT FALSE hm2_7i95.0.inmux.00.input-10
26 bit OUT TRUE hm2_7i95.0.inmux.00.input-10-not
26 bit IN FALSE hm2_7i95.0.inmux.00.input-10-slow
26 bit OUT FALSE hm2_7i95.0.inmux.00.input-11
26 bit OUT TRUE hm2_7i95.0.inmux.00.input-11-not
26 bit IN FALSE hm2_7i95.0.inmux.00.input-11-slow
26 bit OUT FALSE hm2_7i95.0.inmux.00.input-12
26 bit OUT TRUE hm2_7i95.0.inmux.00.input-12-not
26 bit IN FALSE hm2_7i95.0.inmux.00.input-12-slow
26 bit OUT FALSE hm2_7i95.0.inmux.00.input-13
26 bit OUT TRUE hm2_7i95.0.inmux.00.input-13-not
26 bit IN FALSE hm2_7i95.0.inmux.00.input-13-slow
26 bit OUT FALSE hm2_7i95.0.inmux.00.input-14
26 bit OUT TRUE hm2_7i95.0.inmux.00.input-14-not
26 bit IN FALSE hm2_7i95.0.inmux.00.input-14-slow
26 bit OUT FALSE hm2_7i95.0.inmux.00.input-15
26 bit OUT TRUE hm2_7i95.0.inmux.00.input-15-not
26 bit IN FALSE hm2_7i95.0.inmux.00.input-15-slow
26 bit OUT FALSE hm2_7i95.0.inmux.00.input-16
26 bit OUT TRUE hm2_7i95.0.inmux.00.input-16-not
26 bit IN FALSE hm2_7i95.0.inmux.00.input-16-slow
26 bit OUT FALSE hm2_7i95.0.inmux.00.input-17
26 bit OUT TRUE hm2_7i95.0.inmux.00.input-17-not
26 bit IN FALSE hm2_7i95.0.inmux.00.input-17-slow
26 bit OUT FALSE hm2_7i95.0.inmux.00.input-18
26 bit OUT TRUE hm2_7i95.0.inmux.00.input-18-not
26 bit IN FALSE hm2_7i95.0.inmux.00.input-18-slow
26 bit OUT FALSE hm2_7i95.0.inmux.00.input-19
26 bit OUT TRUE hm2_7i95.0.inmux.00.input-19-not
26 bit IN FALSE hm2_7i95.0.inmux.00.input-19-slow
26 bit OUT FALSE hm2_7i95.0.inmux.00.input-20
26 bit OUT TRUE hm2_7i95.0.inmux.00.input-20-not
26 bit IN FALSE hm2_7i95.0.inmux.00.input-20-slow
26 bit OUT FALSE hm2_7i95.0.inmux.00.input-21
26 bit OUT TRUE hm2_7i95.0.inmux.00.input-21-not
26 bit IN FALSE hm2_7i95.0.inmux.00.input-21-slow
26 bit OUT FALSE hm2_7i95.0.inmux.00.input-22
26 bit OUT TRUE hm2_7i95.0.inmux.00.input-22-not
26 bit IN FALSE hm2_7i95.0.inmux.00.input-22-slow
26 bit OUT FALSE hm2_7i95.0.inmux.00.input-23
26 bit OUT TRUE hm2_7i95.0.inmux.00.input-23-not
26 bit IN FALSE hm2_7i95.0.inmux.00.input-23-slow
26 bit OUT FALSE hm2_7i95.0.inmux.00.raw-input-00
26 bit OUT TRUE hm2_7i95.0.inmux.00.raw-input-00-not
26 bit OUT FALSE hm2_7i95.0.inmux.00.raw-input-01
26 bit OUT TRUE hm2_7i95.0.inmux.00.raw-input-01-not
26 bit OUT FALSE hm2_7i95.0.inmux.00.raw-input-02
26 bit OUT TRUE hm2_7i95.0.inmux.00.raw-input-02-not
26 bit OUT FALSE hm2_7i95.0.inmux.00.raw-input-03
26 bit OUT TRUE hm2_7i95.0.inmux.00.raw-input-03-not
26 bit OUT FALSE hm2_7i95.0.inmux.00.raw-input-04
26 bit OUT TRUE hm2_7i95.0.inmux.00.raw-input-04-not
26 bit OUT FALSE hm2_7i95.0.inmux.00.raw-input-05
26 bit OUT TRUE hm2_7i95.0.inmux.00.raw-input-05-not
26 bit OUT FALSE hm2_7i95.0.inmux.00.raw-input-06
26 bit OUT TRUE hm2_7i95.0.inmux.00.raw-input-06-not
26 bit OUT FALSE hm2_7i95.0.inmux.00.raw-input-07
26 bit OUT TRUE hm2_7i95.0.inmux.00.raw-input-07-not
26 bit OUT FALSE hm2_7i95.0.inmux.00.raw-input-08
26 bit OUT TRUE hm2_7i95.0.inmux.00.raw-input-08-not
26 bit OUT FALSE hm2_7i95.0.inmux.00.raw-input-09
26 bit OUT TRUE hm2_7i95.0.inmux.00.raw-input-09-not
26 bit OUT FALSE hm2_7i95.0.inmux.00.raw-input-10
26 bit OUT TRUE hm2_7i95.0.inmux.00.raw-input-10-not
26 bit OUT FALSE hm2_7i95.0.inmux.00.raw-input-11
26 bit OUT TRUE hm2_7i95.0.inmux.00.raw-input-11-not
26 bit OUT FALSE hm2_7i95.0.inmux.00.raw-input-12
26 bit OUT TRUE hm2_7i95.0.inmux.00.raw-input-12-not
26 bit OUT FALSE hm2_7i95.0.inmux.00.raw-input-13
26 bit OUT TRUE hm2_7i95.0.inmux.00.raw-input-13-not
26 bit OUT FALSE hm2_7i95.0.inmux.00.raw-input-14
26 bit OUT TRUE hm2_7i95.0.inmux.00.raw-input-14-not
26 bit OUT FALSE hm2_7i95.0.inmux.00.raw-input-15
26 bit OUT TRUE hm2_7i95.0.inmux.00.raw-input-15-not
26 bit OUT FALSE hm2_7i95.0.inmux.00.raw-input-16
26 bit OUT TRUE hm2_7i95.0.inmux.00.raw-input-16-not
26 bit OUT FALSE hm2_7i95.0.inmux.00.raw-input-17
26 bit OUT TRUE hm2_7i95.0.inmux.00.raw-input-17-not
26 bit OUT FALSE hm2_7i95.0.inmux.00.raw-input-18
26 bit OUT TRUE hm2_7i95.0.inmux.00.raw-input-18-not
26 bit OUT FALSE hm2_7i95.0.inmux.00.raw-input-19
26 bit OUT TRUE hm2_7i95.0.inmux.00.raw-input-19-not
26 bit OUT FALSE hm2_7i95.0.inmux.00.raw-input-20
26 bit OUT TRUE hm2_7i95.0.inmux.00.raw-input-20-not
26 bit OUT FALSE hm2_7i95.0.inmux.00.raw-input-21
26 bit OUT TRUE hm2_7i95.0.inmux.00.raw-input-21-not
26 bit OUT FALSE hm2_7i95.0.inmux.00.raw-input-22
26 bit OUT TRUE hm2_7i95.0.inmux.00.raw-input-22-not
26 bit OUT FALSE hm2_7i95.0.inmux.00.raw-input-23
26 bit OUT TRUE hm2_7i95.0.inmux.00.raw-input-23-not
26 bit IN FALSE hm2_7i95.0.led.CR01
26 bit IN FALSE hm2_7i95.0.led.CR02
26 bit IN FALSE hm2_7i95.0.led.CR03
26 bit IN FALSE hm2_7i95.0.led.CR04
26 bit OUT FALSE hm2_7i95.0.packet-error
26 bit OUT FALSE hm2_7i95.0.packet-error-exceeded
26 s32 OUT 0 hm2_7i95.0.packet-error-level
26 s32 OUT 0 hm2_7i95.0.read-request.time
26 s32 OUT 836184 hm2_7i95.0.read.time
26 bit IN FALSE hm2_7i95.0.ssr.00.out-00
26 bit IN FALSE hm2_7i95.0.ssr.00.out-01
26 bit IN FALSE hm2_7i95.0.ssr.00.out-02
26 bit IN FALSE hm2_7i95.0.ssr.00.out-03
26 bit IN FALSE hm2_7i95.0.ssr.00.out-04
26 bit IN FALSE hm2_7i95.0.ssr.00.out-05
26 u32 IN 0x000F4240 hm2_7i95.0.ssr.00.rate
26 bit IN TRUE hm2_7i95.0.stepgen.00.control-type
26 s32 OUT 3999 hm2_7i95.0.stepgen.00.counts
26 float OUT 0 hm2_7i95.0.stepgen.00.dbg_err_at_match
26 float OUT 0 hm2_7i95.0.stepgen.00.dbg_ff_vel
26 float OUT 0 hm2_7i95.0.stepgen.00.dbg_pos_minus_prev_cmd
26 float OUT 0 hm2_7i95.0.stepgen.00.dbg_s_to_match
26 s32 OUT 0 hm2_7i95.0.stepgen.00.dbg_step_rate
26 float OUT 0 hm2_7i95.0.stepgen.00.dbg_vel_error
26 bit IN TRUE hm2_7i95.0.stepgen.00.enable <== x-enable
26 float IN 0 hm2_7i95.0.stepgen.00.position-cmd
26 float OUT 5 hm2_7i95.0.stepgen.00.position-fb ==> x-pos-fb
26 bit IN FALSE hm2_7i95.0.stepgen.00.position-reset
26 float IN 0 hm2_7i95.0.stepgen.00.velocity-cmd <== x-output
26 float OUT 0 hm2_7i95.0.stepgen.00.velocity-fb
26 bit IN TRUE hm2_7i95.0.stepgen.01.control-type
26 s32 OUT 0 hm2_7i95.0.stepgen.01.counts
26 float OUT 0 hm2_7i95.0.stepgen.01.dbg_err_at_match
26 float OUT 0 hm2_7i95.0.stepgen.01.dbg_ff_vel
26 float OUT 0 hm2_7i95.0.stepgen.01.dbg_pos_minus_prev_cmd
26 float OUT 0 hm2_7i95.0.stepgen.01.dbg_s_to_match
26 s32 OUT 0 hm2_7i95.0.stepgen.01.dbg_step_rate
26 float OUT 0 hm2_7i95.0.stepgen.01.dbg_vel_error
26 bit IN TRUE hm2_7i95.0.stepgen.01.enable <== y-enable
26 float IN 0 hm2_7i95.0.stepgen.01.position-cmd
26 float OUT 0 hm2_7i95.0.stepgen.01.position-fb ==> y-pos-fb
26 bit IN FALSE hm2_7i95.0.stepgen.01.position-reset
26 float IN 0 hm2_7i95.0.stepgen.01.velocity-cmd <== y-output
26 float OUT 0 hm2_7i95.0.stepgen.01.velocity-fb
26 bit IN TRUE hm2_7i95.0.stepgen.02.control-type
26 s32 OUT 0 hm2_7i95.0.stepgen.02.counts
26 float OUT 0 hm2_7i95.0.stepgen.02.dbg_err_at_match
26 float OUT 0 hm2_7i95.0.stepgen.02.dbg_ff_vel
26 float OUT 0 hm2_7i95.0.stepgen.02.dbg_pos_minus_prev_cmd
26 float OUT 0 hm2_7i95.0.stepgen.02.dbg_s_to_match
26 s32 OUT 0 hm2_7i95.0.stepgen.02.dbg_step_rate
26 float OUT 0 hm2_7i95.0.stepgen.02.dbg_vel_error
26 bit IN TRUE hm2_7i95.0.stepgen.02.enable <== y2-enable
26 float IN 0 hm2_7i95.0.stepgen.02.position-cmd
26 float OUT 0 hm2_7i95.0.stepgen.02.position-fb ==> y2-pos-fb
26 bit IN FALSE hm2_7i95.0.stepgen.02.position-reset
26 float IN 0 hm2_7i95.0.stepgen.02.velocity-cmd <== y2-output
26 float OUT 0 hm2_7i95.0.stepgen.02.velocity-fb
26 bit IN TRUE hm2_7i95.0.stepgen.03.control-type
26 s32 OUT 0 hm2_7i95.0.stepgen.03.counts
26 float OUT 0 hm2_7i95.0.stepgen.03.dbg_err_at_match
26 float OUT 0 hm2_7i95.0.stepgen.03.dbg_ff_vel
26 float OUT 0 hm2_7i95.0.stepgen.03.dbg_pos_minus_prev_cmd
26 float OUT 0 hm2_7i95.0.stepgen.03.dbg_s_to_match
26 s32 OUT 0 hm2_7i95.0.stepgen.03.dbg_step_rate
26 float OUT 0 hm2_7i95.0.stepgen.03.dbg_vel_error
26 bit IN TRUE hm2_7i95.0.stepgen.03.enable <== z-enable
26 float IN 0 hm2_7i95.0.stepgen.03.position-cmd
26 float OUT 0 hm2_7i95.0.stepgen.03.position-fb ==> z-pos-fb
26 bit IN FALSE hm2_7i95.0.stepgen.03.position-reset
26 float IN 0 hm2_7i95.0.stepgen.03.velocity-cmd <== z-output
26 float OUT 0 hm2_7i95.0.stepgen.03.velocity-fb
26 bit IN TRUE hm2_7i95.0.stepgen.04.control-type
26 s32 OUT 118322 hm2_7i95.0.stepgen.04.counts
26 float OUT 0 hm2_7i95.0.stepgen.04.dbg_err_at_match
26 float OUT 0 hm2_7i95.0.stepgen.04.dbg_ff_vel
26 float OUT 0 hm2_7i95.0.stepgen.04.dbg_pos_minus_prev_cmd
26 float OUT 0 hm2_7i95.0.stepgen.04.dbg_s_to_match
26 s32 OUT 0 hm2_7i95.0.stepgen.04.dbg_step_rate
26 float OUT 0 hm2_7i95.0.stepgen.04.dbg_vel_error
26 bit IN TRUE hm2_7i95.0.stepgen.04.enable <== a-enable
26 float IN 0 hm2_7i95.0.stepgen.04.position-cmd
26 float OUT 8.21683 hm2_7i95.0.stepgen.04.position-fb ==> a-pos-fb
26 bit IN FALSE hm2_7i95.0.stepgen.04.position-reset
26 float IN 0 hm2_7i95.0.stepgen.04.velocity-cmd <== a-output
26 float OUT 0 hm2_7i95.0.stepgen.04.velocity-fb
26 bit IN TRUE hm2_7i95.0.stepgen.05.control-type
26 s32 OUT 0 hm2_7i95.0.stepgen.05.counts
26 float OUT 0 hm2_7i95.0.stepgen.05.dbg_err_at_match
26 float OUT 0 hm2_7i95.0.stepgen.05.dbg_ff_vel
26 float OUT 0 hm2_7i95.0.stepgen.05.dbg_pos_minus_prev_cmd
26 float OUT 0 hm2_7i95.0.stepgen.05.dbg_s_to_match
26 s32 OUT 0 hm2_7i95.0.stepgen.05.dbg_step_rate
26 float OUT 0 hm2_7i95.0.stepgen.05.dbg_vel_error
26 bit IN TRUE hm2_7i95.0.stepgen.05.enable <== c-enable
26 float IN 0 hm2_7i95.0.stepgen.05.position-cmd
26 float OUT 0 hm2_7i95.0.stepgen.05.position-fb ==> c-pos-fb
26 bit IN FALSE hm2_7i95.0.stepgen.05.position-reset
26 float IN 0 hm2_7i95.0.stepgen.05.velocity-cmd <== c-output
26 float OUT 0 hm2_7i95.0.stepgen.05.velocity-fb
26 s32 IN -1 hm2_7i95.0.stepgen.timer-number
26 bit I/O FALSE hm2_7i95.0.watchdog.has_bit
26 s32 OUT 43992 hm2_7i95.0.write.time
- Thank you received: 5331
14 Oct 2021 19:28 #223108
Replied by PCW on topic Mesa 7i95
7I95 inputs are:
hm2_7i95.0.inmux.00.input-00 through hm2_7i95.0.inmux.00.input-23
and
hm2_7i95.0.inmux.00.input-00-not through hm2_7i95.0.inmux.00.input-23-not
7I95 outputs are:
hm2_7i95.0.ssr.00.out-00 through hm2_7i95.0.ssr.00.out-05
and
7I95 outputs are:
- mittim
14 Oct 2021 19:40 - 14 Oct 2021 19:48 #223109
by mittim
output LEDS are now lighting up, but still measuring 0V. Dumb question, but do I have to apply an additional voltage, rather than the 5V to get an output? That would mean the outputs on the 7i95 are just switches?
Just read in the datasheet that the outputs are "OUTPUT SWITCHED VOLTAGE" between 0 and 36V. Am I correct with that? Don´t want to damage my valuable outputs
Last edit: 14 Oct 2021 19:48 by mittim.
14 Oct 2021 19:57 - 14 Oct 2021 20:12 #223111
Yes, the outputs are isolated switches (0 to 36V, 0 to 2A)
So you can use 5V or 12V or 24V or anything between 0 and 36V
Note that the outputs are not protected against shorted loads
so use a fused or current limited supply. Also the switches
are polarized (if you connect them backwards they will appear
to be always on)
I should add, you can use an Ohmmeter to test the outputs.
to be always on)
Last edit: 14 Oct 2021 20:12 by PCW.
The following user(s) said Thank You: mittim
- myval
- Thank you received: 7
16 Oct 2021 14:00 #223296
by myval
Replied by myval on topic Mesa 7i95
I have one more VFD question.
The problem I have found is that the VFD needs 0-100KHz signal to drive the speed but duty have to be 30% +-2%.
The manual does not state this duty requirement, I have wasted couple of days working out why the hack it does not do what it is supposed to do.
If I drive it with STEPGEN as suggested by PCW it only works at really narrow frequency range when stepgen pulses are about 30% duty.
Now the question is, is there any way to change STEPLEN and STEPSPACE on the fly dependent on the output frequency?
Or is there any other way to generate frequency 0-100KHz with 30% duty?
Joe
Joe
16 Oct 2021 16:45 - 16 Oct 2021 18:58 #223305
Its a bit bizzarre that it will not take a 50% duty cycle.
(which you can get by setting the stepgen into quadrature mode)
There should be a way get a constant 30% duty cycle
by enabling the stepgens table mode and having a 10 length table
with 3 on bits and 7 off bits but I cant seem to get it to work ATM
I'll take a look at what's needed when I have a chance.
EDIT
figured it out, its my fault as usual. I managed to break table
mode in master when I added stepgen index and reset.
I will fix this ASAP
When master is fixed or if you are running 2.8.x you would set
the stepgen table length to 10:
setp hm2_7i95.0.stepgen.NN.step_type 10
and then set the step table data to 3 on bits (and 7 off)
setp hm2_7i95.0.stepgen.NN.table-data-0 0x00010101
Note that the PWM frequency will be the set rate divided by the table length
so you will need to set the velocity 10x higher than before
EDIT
Last edit: 16 Oct 2021 18:58 by PCW.
- myval
16 Oct 2021 18:45 #223313
by myval
Tel me about it bizarre to say the least. I did test it as best as I could and bellow 28% it dropped off and above 33% dropped off too.
I was just thinking if 7i95 can run stepgen in step type 3? If it can it is worth trying I guess that would give me on one phase 33% and that might be about good enough.
with what you have suggested how do I enable the table mode?
16 Oct 2021 18:57 - 16 Oct 2021 19:02 #223316
If you are running 2.8.x, my instructions above should work and give 30.0% duty cycle
if you are running master (2.9.x) I need to push a tiny patch before it will work
Last edit: 16 Oct 2021 19:02 by PCW.
- myval
16 Oct 2021 19:33 #223319
by myval
I am running 2.9 but if it is easier I will go to 2.8 no problem
Time to create page: 0.183 seconds
