Mesa 7i95
04 Nov 2021 16:39 #225241 by PCW
Replied by PCW on topic Mesa 7i95
If you worry about running out of pins, a 7I73 is a good front panel
interface. It may also simplify wiring, especially if the front
panel is some distance from the 7I95
The following user(s) said Thank You: Pro_El
04 Nov 2021 23:04 #225296 by myval
Replied by myval on topic Mesa 7i95
Yep, definitely bit of a distance to 7i95. Ordering it as we speak.
I think i will be bothering you a bit to get it going. She looks like a complex beast too.
10 Jan 2022 23:54 #231370 by Pro_El
Replied by Pro_El on topic Mesa 7i95
Hello PCW,
I need firmware for 7i95 with all 6 STEP/DIR to be replaced with PWM/DIR. I spend last 7i77 cards, and have only 7i95 at the moment and i need analog..
Thanks in advanced
11 Jan 2022 01:34 #231380 by PCW
File Name: 7i95_pwmd.zip
File Size:105 KB
21 Jan 2022 13:56 #232640 by Pro_El
Thank you for new firmware for PWM DIR, PCW
I plan to use the basic 7i95 hal and ini you give us for starting editing. Until now i used PncConf but now i am only unclear what i need to change by hand in this files who are made for step and dir to be working like PWM DIR
Or should i use basic7i97 files because i want to drive 7i95 with PWM DIR. What files should be mu starting point and what should i change in PWM sections in the Hal/INI .
Thanks again
21 Jan 2022 16:42 #232655 by PCW
You could use the7I97 files as a guide to editing in the PWM output
connections and setup into the 7I95 sample files
Note that if you are using PWM/DIR you should not enable the offset PWM
mode that the 7I97 uses.
01 Apr 2022 09:15 #238975 by chienMouille
Replied by chienMouille on topic Mesa 7i95
Sorry I'm totally new here and to all this.
I have a 7i95, which I so far managed to connect to and to jog my servos with, using a pnfconf for a 7i96 and replacing the board names instances.
I'm now trying to connect an MPG to the first counter on the isolated input pins.
I changed this in the HAL file:
# ---jogwheel signals to mesa encoder - x axis MPG---
net x-jog-count <= hm2_7i95.0.inm.00.enc0-count
It's throwing me an error at start up, saying the Pin doesn't exist.
What am i doing wrong?
thanks a lot!
01 Apr 2022 10:12 #238980 by chienMouille
ok, found it.
turns out the right spelling is inmux, so:
net x-jog-count <= hm2_7i95.0.inmux.00.enc0-count
31 Jan 2023 17:14 - 31 Jan 2023 17:15 #263372 by pingtomi
Replied by pingtomi on topic Mesa 7i95
Hi Guys,
Help me please I'm lost: 7i95 with LinuxCNC 2.10.0 works fine except input pins on TB5 (input 16-23)
If I connect the same wires to TB6 input 0-3 then I see in HAL monitor if the status of the port is changed, but if I connect same wires to TB5 pin 1-6 (simply use the same connector head just unplug it from TB6 and plug to TB5) then I can't see any status change not even in HAL monitor even pins are there.
I tried all inputs on TB5 and none of them worked, but all inputs are fine on TB6.
What could be wrong?
I simply load hm2 _eth without any specifications (num_stepgens=5, num_encoders=5"
I tried it with fresh install from scratch result is the same and card is brand new, never used / connected any wire to TB5 before so I ruled out hardware damage as corresponding LEDs indicated (correctly) the status change on the board.
Thank you!
Tamas
Last edit: 31 Jan 2023 17:15 by pingtomi.
31 Jan 2023 18:28 #263382 by PCW
Hardware damage is unlikely as the 7I95 isolated inputs well take up to 48V continuously
and even brief contact to 120VAC will not cause damage.
Is the 7I95 using standard firmware?
What does
halcmd show param hm2_7i95.0.inmux
show?
Moderators: PCW, jmelson
Time to create page: 0.322 seconds
