Mesa 7i95
- myval
- Thank you received: 7
originally I did this
forum.linuxcnc.org/27-driver-boards/3559...ethernet-mesa-boards
but as mentioned in the first line in red do not mix well and I did since I forgot what I did few months ago.
all works as advertised (so far)
Thanks for your help, I will be back for more I am sure
- mittim
- Thank you received: 5
I have a setup with one of those chinese "PWM to 0-10V" modules.
edit:got it.
- Trab
Could it be that the ssr´s are on/closed when starting the board?Yes, the outputs are isolated switches (0 to 36V, 0 to 2A)
So you can use 5V or 12V or 24V or anything between 0 and 36V
Note that the outputs are not protected against shorted loads
so use a fused or current limited supply. Also the switches
are polarized (if you connect them backwards they will appear
to be always on)
I should add, you can use an Ohmmeter to test the outputs.
I think i saw a thread some where how to change it, but i can´t find it anymore.
- Thank you received: 5321
backwards (reverse polarity) they will appear to be stuck-on.
- myval
I need to pick your brain again.
Trying to use I/O 55, 56, 57 as outputs but they do not exist it says.
What am I missing?
26 bit OUT FALSE hm2_7i95.0.gpio.054.in
26 bit OUT TRUE hm2_7i95.0.gpio.054.in_not
26 bit IN FALSE hm2_7i95.0.gpio.054.out <== spindle-enable
26 bit OUT FALSE hm2_7i95.0.gpio.055.in
26 bit OUT TRUE hm2_7i95.0.gpio.055.in_not
26 bit OUT FALSE hm2_7i95.0.gpio.056.in
26 bit OUT TRUE hm2_7i95.0.gpio.056.in_not
26 bit OUT TRUE hm2_7i95.0.gpio.057.in
26 bit OUT FALSE hm2_7i95.0.gpio.057.in_not
26 bit IN FALSE hm2_7i95.0.gpio.057.out
Note that if you are using bare FPGA pins on the expansion connector
you should be careful what they are connected to, and at the minimum
add a 100 Ohm series resistor if they could accidentally contact frame
ground.
- myval
it works fine eg. gpio.54 but not with 56 and 55.
I have an opto coupler board on P1 with inline dropping resistors 1k5
Actually I have enabled PWM on IO 52, 53 would that have anything to do with this issue?
using the --readhmid option with mesaflash should show you what pins is
associated with what function
- myval
-- Expansion port
IOPortTag & x"00" & NullTag & x"00", -- I/O 41 PIN 1
IOPortTag & x"00" & NullTag & x"00", -- I/O 42 PIN 14
IOPortTag & x"00" & NullTag & x"00", -- I/O 43 PIN 2
IOPortTag & x"00" & NullTag & x"00", -- I/O 44 PIN 15
IOPortTag & x"00" & NullTag & x"00", -- I/O 45 PIN 3
IOPortTag & x"00" & NullTag & x"00", -- I/O 46 PIN 16
IOPortTag & x"00" & NullTag & x"00", -- I/O 47 PIN 4
IOPortTag & x"00" & NullTag & x"00", -- I/O 48 PIN 17
IOPortTag & x"00" & NullTag & x"00", -- I/O 49 PIN 5
IOPortTag & x"00" & NullTag & x"00", -- I/O 50 PIN 6
IOPortTag & x"00" & NullTag & x"00", -- I/O 51 PIN 7
IOPortTag & x"00" & PWMTag & PWMAOutPin, -- I/O 52 PIN 11
IOPortTag & x"00" & PWMTag & PWMBDirPin, -- I/O 53 PIN 12
IOPortTag & x"00" & NullTag & x"00", -- I/O 54 PIN 10
IOPortTag & x"00" & NullTag & x"00", -- I/O 55 PIN 8
IOPortTag & x"00" & NullTag & x"00", -- I/O 56 PIN 9
IOPortTag & x"00" & NullTag & x"00", -- I/O 57 PIN 13
I dont have it here on me so I can not try anything, I just wanted to pre-empt for tomorrow.
halcmd show param hm2_7i95.0.gpio
(in a terminal when LinuxCNC is running)
Should show all the GPIO parameters
