Mesa 7i95
6 years 10 months ago #153149 by PCW
The following user(s) said Thank You: Gnevko
6 years 9 months ago #155138 by 0x2102
Replied by 0x2102 on topic Mesa 7i95
Thanks Peter.
What would be the best source package for a custom 7i95 bitfile? I tried the current 7i92 / 7i80 sources but I keep getting a "Cannot find <dumbass8sqwsb> in library <work> when I try to compile even the included PIN layouts.
I could probably ask here but in the past I was able to make changes like PWMgen for StepGen in the PIN layout/ISE project file and compile a new custom bitfile.
If this should be too complicated I would need 1 PWMgen for the last StepGen on a standard 7i95. :)
6 years 9 months ago #155157 by PCW
Replied by PCW on topic Mesa 7i95
It looks like there are a couple issues:
1. The included hostmot2sp6.vhd file is stale
2. The project file uses hostmot2.vhd but should use hostmot2sp6.vhd
To fix issue 1, download hostmot2sp6.vhd from
freeby.mesanet.com/hostmot2sp6.vhd
To fix issue 2, click on the ahostmot2 part of the source tree, right click and
select remove then right click and select add source and enter hostmot2sp6.vhd
6 years 9 months ago #155162 by 0x2102
I download and used the latest 7i80.zip sources, but I am still getting the same error message with the included hostmot2sp6 and the one I downloaded.
In the seveni95 project file, ahosthot2 was already using hostmot2sp6.vhd
ERROR:HDLCompiler:104 - "/home/ise/Downloads/7i80/configs/hostmot2/source/hostmot2/sserialwab.vhd" Line 287: Cannot find <dumbass8sqwsb> in library <work>. Please ensure that the library was compiled, and that a library and a use clause are present in the VHDL file.
ERROR:HDLCompiler:854 - "/home/ise/Downloads/7i80/configs/hostmot2/source/hostmot2/sserialwab.vhd" Line 116: Unit <behavioral> ignored due to previous errors.
Thanks for looking into this.
6 years 9 months ago - 6 years 9 months ago #155165 by PCW
Looks like the zip files have not been updated
Try starting with
freeby.mesanet.com/hostmot2.zip
and doing the changes listed above
Last edit: 6 years 9 months ago by PCW. Reason: oops wrong file
6 years 9 months ago #155168 by 0x2102
Sorry, but still no go.
Same error right after Parsing entity <sserialwab>. Cannot find <dumbass8sqwsb> in library <work>.
I also tried a 7i97 and a 7i76e bitfile and they both worked, but not the 7i95.
Moderators: PCW, jmelson
Time to create page: 0.079 seconds
