Mesa 7i95
6 years 3 months ago #173858 by PCW
Replied by PCW on topic Mesa 7i95
if you get "hm2_7i95.0 error finishng read! iter=296736"
This likely means you have lost communications with the card
This might be a 7I95 5V power issue or a real time issue/dropped packets on the host
If its caused by a real time issues or other loss of communications from the
host, the red /init LED should be illuminated (showing a watchdog timeout)
if you lost (and regained) 7I95 power, the red LED will be off
BTW GPIO0 is stepgen0's step output
Not sure why the inmux pins are not showing up, but it may be related to either your hal file
or communication issues
The following user(s) said Thank You: trial31
6 years 3 months ago #173862 by trial31
Replied by trial31 on topic Mesa 7i95
thankyou for your help!
The red led (cr19) is always on and this error "hm2_7i95.0 error finishng read! iter=296736" appear only after some minutes, i close it and it continue working (at mean I think it is working...:dry: )
The voltage on board is 4.95v ....is that not enough?
Can you look at my files if they are wrong for inmux?
"BTW GPIO0 is stepgen0's step output"
then all my gpio rference are all wrong(good to know) ...i want to put inmux.00.input-00 but linuxcnc is not starting with inmux.00input-01 because they are not...
hal File
# Generated by PNCconf at Tue Jul 7 10:06:07 2020 # Using LinuxCNC version: UNAVAILABLE # If you make changes to this file, they will be # overwritten when you run PNCconf again loadrt [KINS]KINEMATICS loadrt [EMCMOT]EMCMOT servo_period_nsec=[EMCMOT]SERVO_PERIOD num_joints=[KINS]JOINTS loadrt hostmot2 loadrt hm2_eth board_ip="192.168.1.121" config=" num_encoders=6 num_pwmgens=0 num_stepgens=6 sserial_port_0=00xxxx" setp hm2_7i95.0.watchdog.timeout_ns 5000000 loadrt pid names=pid.x,pid.y,pid.y2,pid.z,pid.a,pid.s addf hm2_7i95.0.read servo-thread addf motion-command-handler servo-thread addf motion-controller servo-thread addf pid.x.do-pid-calcs servo-thread addf pid.y.do-pid-calcs servo-thread addf pid.y2.do-pid-calcs servo-thread addf pid.z.do-pid-calcs servo-thread addf pid.a.do-pid-calcs servo-thread addf pid.s.do-pid-calcs servo-thread addf hm2_7i95.0.write servo-thread # external output signals # --- SPINDLE-ENABLE --- net spindle-enable => hm2_7i95.0.ssr.00.out-00 # --- MACHINE-IS-ENABLED --- net machine-is-enabled => hm2_7i95.0.ssr.00.out-01 # external input signals # --- MIN-X --- net min-x <= hm2_7i95.0.gpio.000.in # --- MAX-X --- net max-x <= hm2_7i95.0.gpio.001.in # --- MIN-Y --- net min-y <= hm2_7i95.0.gpio.002.in # --- MAX-Y --- net max-y <= hm2_7i95.0.gpio.003.in # --- MIN-Z --- net min-z <= hm2_7i95.0.gpio.004.in # --- MAX-Z --- net max-z <= hm2_7i95.0.gpio.005.in # --- HOME-X --- net home-x <= hm2_7i95.0.gpio.006.in # --- HOME-Y --- net home-y <= hm2_7i95.0.gpio.007.in # --- HOME-Y2 --- net home-y2 <= hm2_7i95.0.gpio.008.in # --- HOME-Z --- net home-z <= hm2_7i95.0.gpio.009.in #******************* # AXIS X JOINT 0 #******************* setp pid.x.Pgain [JOINT_0]P setp pid.x.Igain [JOINT_0]I setp pid.x.Dgain [JOINT_0]D setp pid.x.bias [JOINT_0]BIAS setp pid.x.FF0 [JOINT_0]FF0 setp pid.x.FF1 [JOINT_0]FF1 setp pid.x.FF2 [JOINT_0]FF2 setp pid.x.deadband [JOINT_0]DEADBAND setp pid.x.maxoutput [JOINT_0]MAX_OUTPUT setp pid.x.error-previous-target true setp pid.x.maxerror .0005 net x-index-enable <=> pid.x.index-enable net x-enable => pid.x.enable net x-pos-cmd => pid.x.command net x-pos-fb => pid.x.feedback net x-output <= pid.x.output # Step Gen signals/setup setp hm2_7i95.0.stepgen.00.dirsetup [JOINT_0]DIRSETUP setp hm2_7i95.0.stepgen.00.dirhold [JOINT_0]DIRHOLD setp hm2_7i95.0.stepgen.00.steplen [JOINT_0]STEPLEN setp hm2_7i95.0.stepgen.00.stepspace [JOINT_0]STEPSPACE setp hm2_7i95.0.stepgen.00.position-scale [JOINT_0]STEP_SCALE setp hm2_7i95.0.stepgen.00.step_type 0 setp hm2_7i95.0.stepgen.00.control-type 1 setp hm2_7i95.0.stepgen.00.maxaccel [JOINT_0]STEPGEN_MAXACCEL setp hm2_7i95.0.stepgen.00.maxvel [JOINT_0]STEPGEN_MAXVEL # ---closedloop stepper signals--- net x-pos-cmd <= joint.0.motor-pos-cmd net x-vel-cmd <= joint.0.vel-cmd net x-output <= hm2_7i95.0.stepgen.00.velocity-cmd net x-pos-fb <= hm2_7i95.0.stepgen.00.position-fb net x-pos-fb => joint.0.motor-pos-fb net x-enable <= joint.0.amp-enable-out net x-enable => hm2_7i95.0.stepgen.00.enable # ---setup home / limit switch signals--- net home-x => joint.0.home-sw-in net min-x => joint.0.neg-lim-sw-in net max-x => joint.0.pos-lim-sw-in #******************* # AXIS Y JOINT 1 #******************* setp pid.y.Pgain [JOINT_1]P setp pid.y.Igain [JOINT_1]I setp pid.y.Dgain [JOINT_1]D setp pid.y.bias [JOINT_1]BIAS setp pid.y.FF0 [JOINT_1]FF0 setp pid.y.FF1 [JOINT_1]FF1 setp pid.y.FF2 [JOINT_1]FF2 setp pid.y.deadband [JOINT_1]DEADBAND setp pid.y.maxoutput [JOINT_1]MAX_OUTPUT setp pid.y.error-previous-target true setp pid.y.maxerror .0005 net y-index-enable <=> pid.y.index-enable net y-enable => pid.y.enable net y-pos-cmd => pid.y.command net y-pos-fb => pid.y.feedback net y-output <= pid.y.output # Step Gen signals/setup setp hm2_7i95.0.stepgen.01.dirsetup [JOINT_1]DIRSETUP setp hm2_7i95.0.stepgen.01.dirhold [JOINT_1]DIRHOLD setp hm2_7i95.0.stepgen.01.steplen [JOINT_1]STEPLEN setp hm2_7i95.0.stepgen.01.stepspace [JOINT_1]STEPSPACE setp hm2_7i95.0.stepgen.01.position-scale [JOINT_1]STEP_SCALE setp hm2_7i95.0.stepgen.01.step_type 0 setp hm2_7i95.0.stepgen.01.control-type 1 setp hm2_7i95.0.stepgen.01.maxaccel [JOINT_1]STEPGEN_MAXACCEL setp hm2_7i95.0.stepgen.01.maxvel [JOINT_1]STEPGEN_MAXVEL # ---closedloop stepper signals--- net y-pos-cmd <= joint.1.motor-pos-cmd net y-vel-cmd <= joint.1.vel-cmd net y-output <= hm2_7i95.0.stepgen.01.velocity-cmd net y-pos-fb <= hm2_7i95.0.stepgen.01.position-fb net y-pos-fb => joint.1.motor-pos-fb net y-enable <= joint.1.amp-enable-out net y-enable => hm2_7i95.0.stepgen.01.enable # ---setup home / limit switch signals--- net home-y => joint.1.home-sw-in net min-y => joint.1.neg-lim-sw-in net max-y => joint.1.pos-lim-sw-in #******************* # Tandem AXIS Y2 JOINT 2 #******************* setp pid.y2.Pgain [JOINT_2]P setp pid.y2.Igain [JOINT_2]I setp pid.y2.Dgain [JOINT_2]D setp pid.y2.bias [JOINT_2]BIAS setp pid.y2.FF0 [JOINT_2]FF0 setp pid.y2.FF1 [JOINT_2]FF1 setp pid.y2.FF2 [JOINT_2]FF2 setp pid.y2.deadband [JOINT_2]DEADBAND setp pid.y2.maxoutput [JOINT_2]MAX_OUTPUT setp pid.y2.error-previous-target true setp pid.y2.maxerror .0005 net y2-index-enable <=> pid.y2.index-enable net y2-enable => pid.y2.enable net y2-pos-cmd => pid.y2.command net y2-pos-fb => pid.y2.feedback net y2-output <= pid.y2.output # Step Gen signals/setup for tandem axis setp hm2_7i95.0.stepgen.02.dirsetup [JOINT_2]DIRSETUP setp hm2_7i95.0.stepgen.02.dirhold [JOINT_2]DIRHOLD setp hm2_7i95.0.stepgen.02.steplen [JOINT_2]STEPLEN setp hm2_7i95.0.stepgen.02.stepspace [JOINT_2]STEPSPACE setp hm2_7i95.0.stepgen.02.position-scale [JOINT_2]STEP_SCALE setp hm2_7i95.0.stepgen.02.step_type 0 setp hm2_7i95.0.stepgen.02.control-type 1 setp hm2_7i95.0.stepgen.02.maxaccel [JOINT_2]STEPGEN_MAXACCEL setp hm2_7i95.0.stepgen.02.maxvel [JOINT_2]STEPGEN_MAXVEL # ---closedloop stepper signals--- net y2-pos-cmd <= joint.2.motor-pos-cmd net y2-vel-cmd <= joint.2.vel-cmd net y2-output <= hm2_7i95.0.stepgen.02.velocity-cmd net y2-pos-fb <= hm2_7i95.0.stepgen.02.position-fb net y2-pos-fb => joint.2.motor-pos-fb net y2-enable <= joint.2.amp-enable-out net y2-enable => hm2_7i95.0.stepgen.02.enable # ---setup home / limit switch signals--- net home-y2 => joint.2.home-sw-in net y2-neg-limit => joint.2.neg-lim-sw-in net y2-pos-limit => joint.2.pos-lim-sw-in #******************* # AXIS Z JOINT 3 #******************* setp pid.z.Pgain [JOINT_3]P setp pid.z.Igain [JOINT_3]I setp pid.z.Dgain [JOINT_3]D setp pid.z.bias [JOINT_3]BIAS setp pid.z.FF0 [JOINT_3]FF0 setp pid.z.FF1 [JOINT_3]FF1 setp pid.z.FF2 [JOINT_3]FF2 setp pid.z.deadband [JOINT_3]DEADBAND setp pid.z.maxoutput [JOINT_3]MAX_OUTPUT setp pid.z.error-previous-target true setp pid.z.maxerror .0005 net z-index-enable <=> pid.z.index-enable net z-enable => pid.z.enable net z-pos-cmd => pid.z.command net z-pos-fb => pid.z.feedback net z-output <= pid.z.output # Step Gen signals/setup setp hm2_7i95.0.stepgen.03.dirsetup [JOINT_3]DIRSETUP setp hm2_7i95.0.stepgen.03.dirhold [JOINT_3]DIRHOLD setp hm2_7i95.0.stepgen.03.steplen [JOINT_3]STEPLEN setp hm2_7i95.0.stepgen.03.stepspace [JOINT_3]STEPSPACE setp hm2_7i95.0.stepgen.03.position-scale [JOINT_3]STEP_SCALE setp hm2_7i95.0.stepgen.03.step_type 0 setp hm2_7i95.0.stepgen.03.control-type 1 setp hm2_7i95.0.stepgen.03.maxaccel [JOINT_3]STEPGEN_MAXACCEL setp hm2_7i95.0.stepgen.03.maxvel [JOINT_3]STEPGEN_MAXVEL # ---closedloop stepper signals--- net z-pos-cmd <= joint.3.motor-pos-cmd net z-vel-cmd <= joint.3.vel-cmd net z-output <= hm2_7i95.0.stepgen.03.velocity-cmd net z-pos-fb <= hm2_7i95.0.stepgen.03.position-fb net z-pos-fb => joint.3.motor-pos-fb net z-enable <= joint.3.amp-enable-out net z-enable => hm2_7i95.0.stepgen.03.enable # ---setup home / limit switch signals--- net home-z => joint.3.home-sw-in net min-z => joint.3.neg-lim-sw-in net max-z => joint.3.pos-lim-sw-in #******************* # AXIS A JOINT 4 #******************* setp pid.a.Pgain [JOINT_4]P setp pid.a.Igain [JOINT_4]I setp pid.a.Dgain [JOINT_4]D setp pid.a.bias [JOINT_4]BIAS setp pid.a.FF0 [JOINT_4]FF0 setp pid.a.FF1 [JOINT_4]FF1 setp pid.a.FF2 [JOINT_4]FF2 setp pid.a.deadband [JOINT_4]DEADBAND setp pid.a.maxoutput [JOINT_4]MAX_OUTPUT setp pid.a.error-previous-target true setp pid.a.maxerror .0005 net a-index-enable <=> pid.a.index-enable net a-enable => pid.a.enable net a-pos-cmd => pid.a.command net a-pos-fb => pid.a.feedback net a-output <= pid.a.output # Step Gen signals/setup setp hm2_7i95.0.stepgen.04.dirsetup [JOINT_4]DIRSETUP setp hm2_7i95.0.stepgen.04.dirhold [JOINT_4]DIRHOLD setp hm2_7i95.0.stepgen.04.steplen [JOINT_4]STEPLEN setp hm2_7i95.0.stepgen.04.stepspace [JOINT_4]STEPSPACE setp hm2_7i95.0.stepgen.04.position-scale [JOINT_4]STEP_SCALE setp hm2_7i95.0.stepgen.04.step_type 0 setp hm2_7i95.0.stepgen.04.control-type 1 setp hm2_7i95.0.stepgen.04.maxaccel [JOINT_4]STEPGEN_MAXACCEL setp hm2_7i95.0.stepgen.04.maxvel [JOINT_4]STEPGEN_MAXVEL # ---closedloop stepper signals--- net a-pos-cmd <= joint.4.motor-pos-cmd net a-vel-cmd <= joint.4.vel-cmd net a-output <= hm2_7i95.0.stepgen.04.velocity-cmd #net a-pos-fb <= hm2_7i95.0.stepgen.04.position-fb net a-pos-fb => joint.4.motor-pos-fb net a-enable <= joint.4.amp-enable-out net a-enable => hm2_7i95.0.stepgen.04.enable # ---Encoder feedback signals/setup--- setp hm2_7i95.0.encoder.00.counter-mode 0 setp hm2_7i95.0.encoder.00.filter 1 setp hm2_7i95.0.encoder.00.index-invert 0 setp hm2_7i95.0.encoder.00.index-mask 0 setp hm2_7i95.0.encoder.00.index-mask-invert 0 setp hm2_7i95.0.encoder.00.scale [JOINT_4]ENCODER_SCALE net a-pos-fb <= hm2_7i95.0.encoder.00.position net a-vel-fb <= hm2_7i95.0.encoder.00.velocity net a-pos-fb => joint.4.motor-pos-fb net a-index-enable joint.4.index-enable <=> hm2_7i95.0.encoder.00.index-enable net a-pos-rawcounts <= hm2_7i95.0.encoder.00.rawcounts # ---setup home / limit switch signals--- net a-home-sw => joint.4.home-sw-in net a-neg-limit => joint.4.neg-lim-sw-in net a-pos-limit => joint.4.pos-lim-sw-in #******************* # SPINDLE #******************* setp pid.s.Pgain [SPINDLE_0]P setp pid.s.Igain [SPINDLE_0]I setp pid.s.Dgain [SPINDLE_0]D setp pid.s.bias [SPINDLE_0]BIAS setp pid.s.FF0 [SPINDLE_0]FF0 setp pid.s.FF1 [SPINDLE_0]FF1 setp pid.s.FF2 [SPINDLE_0]FF2 setp pid.s.deadband [SPINDLE_0]DEADBAND setp pid.s.maxoutput [SPINDLE_0]MAX_OUTPUT setp pid.s.error-previous-target true net spindle-index-enable <=> pid.s.index-enable net spindle-enable => pid.s.enable net spindle-vel-cmd-rpm => pid.s.command net spindle-vel-fb-rpm => pid.s.feedback net spindle-output <= pid.s.output # ---setup spindle control signals--- net spindle-vel-cmd-rps <= spindle.0.speed-out-rps net spindle-vel-cmd-rps-abs <= spindle.0.speed-out-rps-abs net spindle-vel-cmd-rpm <= spindle.0.speed-out net spindle-vel-cmd-rpm-abs <= spindle.0.speed-out-abs net spindle-enable <= spindle.0.on net spindle-cw <= spindle.0.forward net spindle-ccw <= spindle.0.reverse net spindle-brake <= spindle.0.brake net spindle-revs => spindle.0.revs net spindle-at-speed => spindle.0.at-speed net spindle-vel-fb-rps => spindle.0.speed-in net spindle-index-enable <=> spindle.0.index-enable # ---Setup spindle at speed signals--- sets spindle-at-speed true #****************************** # connect miscellaneous signals #****************************** # ---HALUI signals--- net axis-select-x halui.axis.x.select net jog-x-pos halui.axis.x.plus net jog-x-neg halui.axis.x.minus net jog-x-analog halui.axis.x.analog net x-is-homed halui.joint.0.is-homed net axis-select-y halui.axis.y.select net jog-y-pos halui.axis.y.plus net jog-y-neg halui.axis.y.minus net jog-y-analog halui.axis.y.analog net y-is-homed halui.joint.1.is-homed net axis-select-z halui.axis.z.select net jog-z-pos halui.axis.z.plus net jog-z-neg halui.axis.z.minus net jog-z-analog halui.axis.z.analog net z-is-homed halui.joint.2.is-homed net axis-select-a halui.axis.a.select net jog-a-pos halui.axis.a.plus net jog-a-neg halui.axis.a.minus net jog-a-analog halui.axis.a.analog net a-is-homed halui.joint.3.is-homed net jog-selected-pos halui.axis.selected.plus net jog-selected-neg halui.axis.selected.minus net spindle-manual-cw halui.spindle.0.forward net spindle-manual-ccw halui.spindle.0.reverse net spindle-manual-stop halui.spindle.0.stop net machine-is-on halui.machine.is-on net jog-speed halui.axis.jog-speed net MDI-mode halui.mode.is-mdi # ---coolant signals--- net coolant-mist <= iocontrol.0.coolant-mist net coolant-flood <= iocontrol.0.coolant-flood # ---probe signal--- net probe-in => motion.probe-input # ---motion control signals--- net in-position <= motion.in-position net machine-is-enabled <= motion.motion-enabled # ---digital in / out signals--- # ---estop signals--- net estop-out <= iocontrol.0.user-enable-out net estop-out => iocontrol.0.emc-enable-in # ---manual tool change signals--- loadusr -W hal_manualtoolchange net tool-change-request iocontrol.0.tool-change => hal_manualtoolchange.change net tool-change-confirmed iocontrol.0.tool-changed <= hal_manualtoolchange.changed net tool-number iocontrol.0.tool-prep-number => hal_manualtoolchange.number net tool-prepare-loopback iocontrol.0.tool-prepare => iocontrol.0.tool-prepared
INI File
# Generated by PNCconf at Tue Jul 7 10:06:07 2020 # Using LinuxCNC version: UNAVAILABLE # If you make changes to this file, they will be # overwritten when you run PNCconf again [EMC] MACHINE = test2 DEBUG = 0 VERSION = 1.1 [DISPLAY] DISPLAY = axis POSITION_OFFSET = RELATIVE POSITION_FEEDBACK = ACTUAL MAX_FEED_OVERRIDE = 2.000000 MAX_SPINDLE_OVERRIDE = 1.000000 MIN_SPINDLE_OVERRIDE = 0.500000 INTRO_GRAPHIC = linuxcnc.gif INTRO_TIME = 5 PROGRAM_PREFIX = /home/cnc/linuxcnc/nc_files INCREMENTS = 5mm 1mm .5mm .1mm .05mm .01mm .005mm POSITION_FEEDBACK = ACTUAL DEFAULT_LINEAR_VELOCITY = 6.000000 MAX_LINEAR_VELOCITY = 25.000000 MIN_LINEAR_VELOCITY = 0.500000 DEFAULT_ANGULAR_VELOCITY = 12.000000 MAX_ANGULAR_VELOCITY = 180.000000 MIN_ANGULAR_VELOCITY = 1.666667 EDITOR = gedit GEOMETRY = xyz [FILTER] PROGRAM_EXTENSION = .png,.gif,.jpg Greyscale Depth Image PROGRAM_EXTENSION = .py Python Script png = image-to-gcode gif = image-to-gcode jpg = image-to-gcode py = python [TASK] TASK = milltask CYCLE_TIME = 0.010 [RS274NGC] PARAMETER_FILE = linuxcnc.var [EMCMOT] EMCMOT = motmod COMM_TIMEOUT = 1.0 SERVO_PERIOD = 1000000 [HMOT] # **** This is for info only **** CARD0=hm2_7i95.0 [HAL] HALUI = halui HALFILE = test2.hal HALFILE = custom.hal POSTGUI_HALFILE = postgui_call_list.hal SHUTDOWN = shutdown.hal [HALUI] [KINS] JOINTS = 5 KINEMATICS = trivkins coordinates=XYYZA kinstype=BOTH [TRAJ] COORDINATES = XYYZA MAX_ANGULAR_VELOCITY = 360.00 DEFAULT_ANGULAR_VELOCITY = 36.00 LINEAR_UNITS = mm ANGULAR_UNITS = degree DEFAULT_LINEAR_VELOCITY = 6.67 MAX_LINEAR_VELOCITY = 66.67 [EMCIO] EMCIO = io CYCLE_TIME = 0.100 TOOL_TABLE = tool.tbl #****************************************** [AXIS_X] MAX_VELOCITY = 66.6666666667 MAX_ACCELERATION = 750.0 MIN_LIMIT = -0.0 MAX_LIMIT = 540.0 [JOINT_0] TYPE = LINEAR HOME = 520.0 FERROR = 10.0 MIN_FERROR = 1.0 MAX_VELOCITY = 66.6666666667 MAX_ACCELERATION = 750.0 # The values below should be 25% larger than MAX_VELOCITY and MAX_ACCELERATION # If using BACKLASH compensation STEPGEN_MAXACCEL should be 100% larger. STEPGEN_MAXVEL = 83.33 STEPGEN_MAXACCEL = 937.50 P = 1000.0 I = 0.0 D = 0.0 FF0 = 0.0 FF1 = 1.0 FF2 = 0.0 BIAS = 0.0 DEADBAND = 0.0 MAX_OUTPUT = 0.0 # these are in nanoseconds DIRSETUP = 10000 DIRHOLD = 10000 STEPLEN = 5000 STEPSPACE = 5000 STEP_SCALE = 160.0 MIN_LIMIT = -0.0 MAX_LIMIT = 540.0 HOME_OFFSET = 550.000000 HOME_SEARCH_VEL = 1.000000 HOME_LATCH_VEL = 0.500000 HOME_FINAL_VEL = 0.000000 HOME_USE_INDEX = NO #****************************************** #****************************************** [AXIS_Y] MAX_VELOCITY = 66.6666666667 MAX_ACCELERATION = 750.0 MIN_LIMIT = -0.0 MAX_LIMIT = 950.0 [JOINT_1] TYPE = LINEAR HOME = 20.0 FERROR = 10.0 MIN_FERROR = 1.0 MAX_VELOCITY = 66.6666666667 MAX_ACCELERATION = 750.0 # The values below should be 25% larger than MAX_VELOCITY and MAX_ACCELERATION # If using BACKLASH compensation STEPGEN_MAXACCEL should be 100% larger. STEPGEN_MAXVEL = 83.33 STEPGEN_MAXACCEL = 937.50 P = 1000.0 I = 0.0 D = 0.0 FF0 = 0.0 FF1 = 1.0 FF2 = 0.0 BIAS = 0.0 DEADBAND = 0.0 MAX_OUTPUT = 0.0 # these are in nanoseconds DIRSETUP = 10000 DIRHOLD = 10000 STEPLEN = 5000 STEPSPACE = 5000 STEP_SCALE = 160.0 MIN_LIMIT = -0.0 MAX_LIMIT = 950.0 HOME_OFFSET = -10.000000 HOME_SEARCH_VEL = -1.000000 HOME_LATCH_VEL = -0.500000 HOME_FINAL_VEL = 0.000000 HOME_USE_INDEX = NO [JOINT_2] TYPE = LINEAR HOME = 20.0 FERROR = 10.0 MIN_FERROR = 1.0 MAX_VELOCITY = 66.6666666667 MAX_ACCELERATION = 750.0 # The values below should be 25% larger than MAX_VELOCITY and MAX_ACCELERATION # If using BACKLASH compensation STEPGEN_MAXACCEL should be 100% larger. STEPGEN_MAXVEL = 83.33 STEPGEN_MAXACCEL = 937.50 P = 1000.0 I = 0.0 D = 0.0 FF0 = 0.0 FF1 = 1.0 FF2 = 0.0 BIAS = 0.0 DEADBAND = 0.0 MAX_OUTPUT = 0.0 # these are in nanoseconds DIRSETUP = 10000 DIRHOLD = 10000 STEPLEN = 5000 STEPSPACE = 5000 STEP_SCALE = 160.0 MIN_LIMIT = -0.0 MAX_LIMIT = 950.0 HOME_OFFSET = -10.000000 HOME_SEARCH_VEL = -1.000000 HOME_LATCH_VEL = -0.500000 HOME_FINAL_VEL = 0.000000 HOME_USE_INDEX = NO #****************************************** #****************************************** [AXIS_Z] MAX_VELOCITY = 50.0 MAX_ACCELERATION = 750.0 MIN_LIMIT = -0.0 MAX_LIMIT = 250.0 [JOINT_3] TYPE = LINEAR HOME = 30.0 FERROR = 10.0 MIN_FERROR = 1.0 MAX_VELOCITY = 50.0 MAX_ACCELERATION = 750.0 # The values below should be 25% larger than MAX_VELOCITY and MAX_ACCELERATION # If using BACKLASH compensation STEPGEN_MAXACCEL should be 100% larger. STEPGEN_MAXVEL = 62.50 STEPGEN_MAXACCEL = 937.50 P = 1000.0 I = 0.0 D = 0.0 FF0 = 0.0 FF1 = 1.0 FF2 = 0.0 BIAS = 0.0 DEADBAND = 0.0 MAX_OUTPUT = 0.0 # these are in nanoseconds DIRSETUP = 10000 DIRHOLD = 10000 STEPLEN = 5000 STEPSPACE = 5000 STEP_SCALE = 160.0 MIN_LIMIT = -0.0 MAX_LIMIT = 250.0 HOME_OFFSET = 50.000000 HOME_SEARCH_VEL = 1.000000 HOME_LATCH_VEL = -0.500000 HOME_FINAL_VEL = 0.000000 HOME_USE_INDEX = NO #****************************************** #****************************************** [AXIS_A] MAX_VELOCITY = 360.0 MAX_ACCELERATION = 1200.0 MIN_LIMIT = -9999.0 MAX_LIMIT = 9999.0 [JOINT_4] TYPE = ANGULAR HOME = 0.0 FERROR = 0.5 MIN_FERROR = 0.05 MAX_VELOCITY = 360.0 MAX_ACCELERATION = 1200.0 # The values below should be 25% larger than MAX_VELOCITY and MAX_ACCELERATION # If using BACKLASH compensation STEPGEN_MAXACCEL should be 100% larger. STEPGEN_MAXVEL = 450.00 STEPGEN_MAXACCEL = 1500.00 P = 1000.0 I = 0.0 D = 0.0 FF0 = 0.0 FF1 = 1.0 FF2 = 0.0 BIAS = 0.0 DEADBAND = 0.0 MAX_OUTPUT = 0.0 ENCODER_SCALE = 5.6889 # these are in nanoseconds DIRSETUP = 10000 DIRHOLD = 10000 STEPLEN = 5000 STEPSPACE = 5000 STEP_SCALE = 4.4444 MIN_LIMIT = -9999.0 MAX_LIMIT = 9999.0 HOME_OFFSET = 0.0 #****************************************** [SPINDLE_0] P = 0.0 I = 0.0 D = 0.0 FF0 = 1.0 FF1 = 0.0 FF2 = 0.0 BIAS = 0.0 DEADBAND = 0.0 MAX_OUTPUT = 2000.0
6 years 3 months ago #173865 by trial31
Now with "halcmd show pin hm*" I see all pin correctly.....it look like after cleening error "hm2_7i95.0 error finishng read! iter=296736" it is changing the pin list.....i will make some test about it...
Component Pins: Owner Type Dir Value Name 26 float IN 100 hm2_7i95.0.dpll.01.timer-us 26 float IN 100 hm2_7i95.0.dpll.02.timer-us 26 float IN 100 hm2_7i95.0.dpll.03.timer-us 26 float IN 100 hm2_7i95.0.dpll.04.timer-us 26 float IN 1 hm2_7i95.0.dpll.base-freq-khz 26 u32 OUT 0x0000002A hm2_7i95.0.dpll.ddsize 26 float OUT -0.06875279 hm2_7i95.0.dpll.phase-error-us 26 u32 IN 0x00400000 hm2_7i95.0.dpll.plimit 26 u32 OUT 0x00000018 hm2_7i95.0.dpll.prescale 26 u32 IN 0x000007D0 hm2_7i95.0.dpll.time-const 26 s32 OUT 0 hm2_7i95.0.encoder.00.count 26 s32 OUT 0 hm2_7i95.0.encoder.00.count-latched 26 bit I/O FALSE hm2_7i95.0.encoder.00.index-enable <=> a-index-enable 26 bit OUT FALSE hm2_7i95.0.encoder.00.input-a 26 bit OUT FALSE hm2_7i95.0.encoder.00.input-b 26 bit OUT TRUE hm2_7i95.0.encoder.00.input-index 26 bit IN FALSE hm2_7i95.0.encoder.00.latch-enable 26 bit IN FALSE hm2_7i95.0.encoder.00.latch-polarity 26 float OUT 0 hm2_7i95.0.encoder.00.position ==> a-pos-fb 26 float OUT 0 hm2_7i95.0.encoder.00.position-latched 26 bit OUT FALSE hm2_7i95.0.encoder.00.quad-error 26 bit IN FALSE hm2_7i95.0.encoder.00.quad-error-enable 26 s32 OUT 0 hm2_7i95.0.encoder.00.rawcounts ==> a-pos-rawcounts 26 s32 OUT 0 hm2_7i95.0.encoder.00.rawlatch 26 bit IN FALSE hm2_7i95.0.encoder.00.reset 26 float OUT 0 hm2_7i95.0.encoder.00.velocity ==> a-vel-fb 26 float OUT 0 hm2_7i95.0.encoder.00.velocity-rpm 26 s32 OUT 0 hm2_7i95.0.encoder.01.count 26 s32 OUT 0 hm2_7i95.0.encoder.01.count-latched 26 bit I/O FALSE hm2_7i95.0.encoder.01.index-enable 26 bit OUT FALSE hm2_7i95.0.encoder.01.input-a 26 bit OUT FALSE hm2_7i95.0.encoder.01.input-b 26 bit OUT TRUE hm2_7i95.0.encoder.01.input-index 26 bit IN FALSE hm2_7i95.0.encoder.01.latch-enable 26 bit IN FALSE hm2_7i95.0.encoder.01.latch-polarity 26 float OUT 0 hm2_7i95.0.encoder.01.position 26 float OUT 0 hm2_7i95.0.encoder.01.position-latched 26 bit OUT FALSE hm2_7i95.0.encoder.01.quad-error 26 bit IN FALSE hm2_7i95.0.encoder.01.quad-error-enable 26 s32 OUT 0 hm2_7i95.0.encoder.01.rawcounts 26 s32 OUT 0 hm2_7i95.0.encoder.01.rawlatch 26 bit IN FALSE hm2_7i95.0.encoder.01.reset 26 float OUT 0 hm2_7i95.0.encoder.01.velocity 26 float OUT 0 hm2_7i95.0.encoder.01.velocity-rpm 26 s32 OUT 0 hm2_7i95.0.encoder.02.count 26 s32 OUT 0 hm2_7i95.0.encoder.02.count-latched 26 bit I/O FALSE hm2_7i95.0.encoder.02.index-enable 26 bit OUT FALSE hm2_7i95.0.encoder.02.input-a 26 bit OUT FALSE hm2_7i95.0.encoder.02.input-b 26 bit OUT TRUE hm2_7i95.0.encoder.02.input-index 26 bit IN FALSE hm2_7i95.0.encoder.02.latch-enable 26 bit IN FALSE hm2_7i95.0.encoder.02.latch-polarity 26 float OUT 0 hm2_7i95.0.encoder.02.position 26 float OUT 0 hm2_7i95.0.encoder.02.position-latched 26 bit OUT FALSE hm2_7i95.0.encoder.02.quad-error 26 bit IN FALSE hm2_7i95.0.encoder.02.quad-error-enable 26 s32 OUT 0 hm2_7i95.0.encoder.02.rawcounts 26 s32 OUT 0 hm2_7i95.0.encoder.02.rawlatch 26 bit IN FALSE hm2_7i95.0.encoder.02.reset 26 float OUT 0 hm2_7i95.0.encoder.02.velocity 26 float OUT 0 hm2_7i95.0.encoder.02.velocity-rpm 26 s32 OUT 0 hm2_7i95.0.encoder.03.count 26 s32 OUT 0 hm2_7i95.0.encoder.03.count-latched 26 bit I/O FALSE hm2_7i95.0.encoder.03.index-enable 26 bit OUT FALSE hm2_7i95.0.encoder.03.input-a 26 bit OUT FALSE hm2_7i95.0.encoder.03.input-b 26 bit OUT TRUE hm2_7i95.0.encoder.03.input-index 26 bit IN FALSE hm2_7i95.0.encoder.03.latch-enable 26 bit IN FALSE hm2_7i95.0.encoder.03.latch-polarity 26 float OUT 0 hm2_7i95.0.encoder.03.position 26 float OUT 0 hm2_7i95.0.encoder.03.position-latched 26 bit OUT FALSE hm2_7i95.0.encoder.03.quad-error 26 bit IN FALSE hm2_7i95.0.encoder.03.quad-error-enable 26 s32 OUT 0 hm2_7i95.0.encoder.03.rawcounts 26 s32 OUT 0 hm2_7i95.0.encoder.03.rawlatch 26 bit IN FALSE hm2_7i95.0.encoder.03.reset 26 float OUT 0 hm2_7i95.0.encoder.03.velocity 26 float OUT 0 hm2_7i95.0.encoder.03.velocity-rpm 26 s32 OUT 0 hm2_7i95.0.encoder.04.count 26 s32 OUT 0 hm2_7i95.0.encoder.04.count-latched 26 bit I/O FALSE hm2_7i95.0.encoder.04.index-enable 26 bit OUT FALSE hm2_7i95.0.encoder.04.input-a 26 bit OUT FALSE hm2_7i95.0.encoder.04.input-b 26 bit OUT TRUE hm2_7i95.0.encoder.04.input-index 26 bit IN FALSE hm2_7i95.0.encoder.04.latch-enable 26 bit IN FALSE hm2_7i95.0.encoder.04.latch-polarity 26 float OUT 0 hm2_7i95.0.encoder.04.position 26 float OUT 0 hm2_7i95.0.encoder.04.position-latched 26 bit OUT FALSE hm2_7i95.0.encoder.04.quad-error 26 bit IN FALSE hm2_7i95.0.encoder.04.quad-error-enable 26 s32 OUT 0 hm2_7i95.0.encoder.04.rawcounts 26 s32 OUT 0 hm2_7i95.0.encoder.04.rawlatch 26 bit IN FALSE hm2_7i95.0.encoder.04.reset 26 float OUT 0 hm2_7i95.0.encoder.04.velocity 26 float OUT 0 hm2_7i95.0.encoder.04.velocity-rpm 26 s32 OUT 0 hm2_7i95.0.encoder.05.count 26 s32 OUT 0 hm2_7i95.0.encoder.05.count-latched 26 bit I/O FALSE hm2_7i95.0.encoder.05.index-enable 26 bit OUT FALSE hm2_7i95.0.encoder.05.input-a 26 bit OUT FALSE hm2_7i95.0.encoder.05.input-b 26 bit OUT TRUE hm2_7i95.0.encoder.05.input-index 26 bit IN FALSE hm2_7i95.0.encoder.05.latch-enable 26 bit IN FALSE hm2_7i95.0.encoder.05.latch-polarity 26 float OUT 0 hm2_7i95.0.encoder.05.position 26 float OUT 0 hm2_7i95.0.encoder.05.position-latched 26 bit OUT FALSE hm2_7i95.0.encoder.05.quad-error 26 bit IN FALSE hm2_7i95.0.encoder.05.quad-error-enable 26 s32 OUT 0 hm2_7i95.0.encoder.05.rawcounts 26 s32 OUT 0 hm2_7i95.0.encoder.05.rawlatch 26 bit IN FALSE hm2_7i95.0.encoder.05.reset 26 float OUT 0 hm2_7i95.0.encoder.05.velocity 26 float OUT 0 hm2_7i95.0.encoder.05.velocity-rpm 26 bit IN FALSE hm2_7i95.0.encoder.hires-timestamp 26 u32 IN 0x007F2815 hm2_7i95.0.encoder.muxed-sample-frequency 26 s32 IN -1 hm2_7i95.0.encoder.timer-number 26 bit OUT FALSE hm2_7i95.0.gpio.000.in ==> min-x 26 bit OUT TRUE hm2_7i95.0.gpio.000.in_not 26 bit OUT FALSE hm2_7i95.0.gpio.001.in ==> max-x 26 bit OUT TRUE hm2_7i95.0.gpio.001.in_not 26 bit OUT FALSE hm2_7i95.0.gpio.002.in ==> min-y 26 bit OUT TRUE hm2_7i95.0.gpio.002.in_not 26 bit OUT FALSE hm2_7i95.0.gpio.003.in ==> max-y 26 bit OUT TRUE hm2_7i95.0.gpio.003.in_not 26 bit OUT FALSE hm2_7i95.0.gpio.004.in ==> min-z 26 bit OUT TRUE hm2_7i95.0.gpio.004.in_not 26 bit OUT FALSE hm2_7i95.0.gpio.005.in ==> max-z 26 bit OUT TRUE hm2_7i95.0.gpio.005.in_not 26 bit OUT FALSE hm2_7i95.0.gpio.006.in ==> home-x 26 bit OUT TRUE hm2_7i95.0.gpio.006.in_not 26 bit OUT FALSE hm2_7i95.0.gpio.007.in ==> home-y 26 bit OUT TRUE hm2_7i95.0.gpio.007.in_not 26 bit OUT FALSE hm2_7i95.0.gpio.008.in ==> home-y2 26 bit OUT TRUE hm2_7i95.0.gpio.008.in_not 26 bit OUT FALSE hm2_7i95.0.gpio.009.in ==> home-z 26 bit OUT TRUE hm2_7i95.0.gpio.009.in_not 26 bit OUT FALSE hm2_7i95.0.gpio.010.in 26 bit OUT TRUE hm2_7i95.0.gpio.010.in_not 26 bit OUT FALSE hm2_7i95.0.gpio.011.in 26 bit OUT TRUE hm2_7i95.0.gpio.011.in_not 26 bit OUT TRUE hm2_7i95.0.gpio.012.in 26 bit OUT FALSE hm2_7i95.0.gpio.012.in_not 26 bit IN FALSE hm2_7i95.0.gpio.012.out 26 bit OUT TRUE hm2_7i95.0.gpio.013.in 26 bit OUT FALSE hm2_7i95.0.gpio.013.in_not 26 bit IN FALSE hm2_7i95.0.gpio.013.out 26 bit OUT TRUE hm2_7i95.0.gpio.014.in 26 bit OUT FALSE hm2_7i95.0.gpio.014.in_not 26 bit IN FALSE hm2_7i95.0.gpio.014.out 26 bit OUT TRUE hm2_7i95.0.gpio.015.in 26 bit OUT FALSE hm2_7i95.0.gpio.015.in_not 26 bit IN FALSE hm2_7i95.0.gpio.015.out 26 bit OUT TRUE hm2_7i95.0.gpio.016.in 26 bit OUT FALSE hm2_7i95.0.gpio.016.in_not 26 bit IN FALSE hm2_7i95.0.gpio.016.out 26 bit OUT TRUE hm2_7i95.0.gpio.017.in 26 bit OUT FALSE hm2_7i95.0.gpio.017.in_not 26 bit IN FALSE hm2_7i95.0.gpio.017.out 26 bit OUT FALSE hm2_7i95.0.gpio.018.in 26 bit OUT TRUE hm2_7i95.0.gpio.018.in_not 26 bit OUT FALSE hm2_7i95.0.gpio.019.in 26 bit OUT TRUE hm2_7i95.0.gpio.019.in_not 26 bit OUT FALSE hm2_7i95.0.gpio.020.in 26 bit OUT TRUE hm2_7i95.0.gpio.020.in_not 26 bit OUT FALSE hm2_7i95.0.gpio.021.in 26 bit OUT TRUE hm2_7i95.0.gpio.021.in_not 26 bit OUT FALSE hm2_7i95.0.gpio.022.in 26 bit OUT TRUE hm2_7i95.0.gpio.022.in_not 26 bit OUT FALSE hm2_7i95.0.gpio.023.in 26 bit OUT TRUE hm2_7i95.0.gpio.023.in_not 26 bit OUT FALSE hm2_7i95.0.gpio.024.in 26 bit OUT TRUE hm2_7i95.0.gpio.024.in_not 26 bit OUT FALSE hm2_7i95.0.gpio.025.in 26 bit OUT TRUE hm2_7i95.0.gpio.025.in_not 26 bit OUT FALSE hm2_7i95.0.gpio.026.in 26 bit OUT TRUE hm2_7i95.0.gpio.026.in_not 26 bit OUT TRUE hm2_7i95.0.gpio.027.in 26 bit OUT FALSE hm2_7i95.0.gpio.027.in_not 26 bit OUT TRUE hm2_7i95.0.gpio.028.in 26 bit OUT FALSE hm2_7i95.0.gpio.028.in_not 26 bit OUT TRUE hm2_7i95.0.gpio.029.in 26 bit OUT FALSE hm2_7i95.0.gpio.029.in_not 26 bit OUT TRUE hm2_7i95.0.gpio.030.in 26 bit OUT FALSE hm2_7i95.0.gpio.030.in_not 26 bit OUT FALSE hm2_7i95.0.gpio.031.in 26 bit OUT TRUE hm2_7i95.0.gpio.031.in_not 26 bit OUT TRUE hm2_7i95.0.gpio.032.in 26 bit OUT FALSE hm2_7i95.0.gpio.032.in_not 26 bit OUT TRUE hm2_7i95.0.gpio.033.in 26 bit OUT FALSE hm2_7i95.0.gpio.033.in_not 26 bit OUT FALSE hm2_7i95.0.gpio.034.in 26 bit OUT TRUE hm2_7i95.0.gpio.034.in_not 26 bit OUT FALSE hm2_7i95.0.gpio.035.in 26 bit OUT TRUE hm2_7i95.0.gpio.035.in_not 26 bit OUT FALSE hm2_7i95.0.gpio.036.in 26 bit OUT TRUE hm2_7i95.0.gpio.036.in_not 26 bit OUT FALSE hm2_7i95.0.gpio.037.in 26 bit OUT TRUE hm2_7i95.0.gpio.037.in_not 26 bit OUT FALSE hm2_7i95.0.gpio.038.in 26 bit OUT TRUE hm2_7i95.0.gpio.038.in_not 26 bit OUT FALSE hm2_7i95.0.gpio.039.in 26 bit OUT TRUE hm2_7i95.0.gpio.039.in_not 26 bit OUT FALSE hm2_7i95.0.gpio.040.in 26 bit OUT TRUE hm2_7i95.0.gpio.040.in_not 26 bit OUT TRUE hm2_7i95.0.gpio.041.in 26 bit OUT FALSE hm2_7i95.0.gpio.041.in_not 26 bit IN FALSE hm2_7i95.0.gpio.041.out 26 bit OUT TRUE hm2_7i95.0.gpio.042.in 26 bit OUT FALSE hm2_7i95.0.gpio.042.in_not 26 bit IN FALSE hm2_7i95.0.gpio.042.out 26 bit OUT TRUE hm2_7i95.0.gpio.043.in 26 bit OUT FALSE hm2_7i95.0.gpio.043.in_not 26 bit IN FALSE hm2_7i95.0.gpio.043.out 26 bit OUT TRUE hm2_7i95.0.gpio.044.in 26 bit OUT FALSE hm2_7i95.0.gpio.044.in_not 26 bit IN FALSE hm2_7i95.0.gpio.044.out 26 bit OUT TRUE hm2_7i95.0.gpio.045.in 26 bit OUT FALSE hm2_7i95.0.gpio.045.in_not 26 bit IN FALSE hm2_7i95.0.gpio.045.out 26 bit OUT TRUE hm2_7i95.0.gpio.046.in 26 bit OUT FALSE hm2_7i95.0.gpio.046.in_not 26 bit IN FALSE hm2_7i95.0.gpio.046.out 26 bit OUT TRUE hm2_7i95.0.gpio.047.in 26 bit OUT FALSE hm2_7i95.0.gpio.047.in_not 26 bit IN FALSE hm2_7i95.0.gpio.047.out 26 bit OUT TRUE hm2_7i95.0.gpio.048.in 26 bit OUT FALSE hm2_7i95.0.gpio.048.in_not 26 bit IN FALSE hm2_7i95.0.gpio.048.out 26 bit OUT TRUE hm2_7i95.0.gpio.049.in 26 bit OUT FALSE hm2_7i95.0.gpio.049.in_not 26 bit IN FALSE hm2_7i95.0.gpio.049.out 26 bit OUT TRUE hm2_7i95.0.gpio.050.in 26 bit OUT FALSE hm2_7i95.0.gpio.050.in_not 26 bit IN FALSE hm2_7i95.0.gpio.050.out 26 bit OUT TRUE hm2_7i95.0.gpio.051.in 26 bit OUT FALSE hm2_7i95.0.gpio.051.in_not 26 bit IN FALSE hm2_7i95.0.gpio.051.out 26 bit OUT TRUE hm2_7i95.0.gpio.052.in 26 bit OUT FALSE hm2_7i95.0.gpio.052.in_not 26 bit IN FALSE hm2_7i95.0.gpio.052.out 26 bit OUT TRUE hm2_7i95.0.gpio.053.in 26 bit OUT FALSE hm2_7i95.0.gpio.053.in_not 26 bit IN FALSE hm2_7i95.0.gpio.053.out 26 bit OUT TRUE hm2_7i95.0.gpio.054.in 26 bit OUT FALSE hm2_7i95.0.gpio.054.in_not 26 bit IN FALSE hm2_7i95.0.gpio.054.out 26 bit OUT TRUE hm2_7i95.0.gpio.055.in 26 bit OUT FALSE hm2_7i95.0.gpio.055.in_not 26 bit IN FALSE hm2_7i95.0.gpio.055.out 26 bit OUT TRUE hm2_7i95.0.gpio.056.in 26 bit OUT FALSE hm2_7i95.0.gpio.056.in_not 26 bit IN FALSE hm2_7i95.0.gpio.056.out 26 bit OUT TRUE hm2_7i95.0.gpio.057.in 26 bit OUT FALSE hm2_7i95.0.gpio.057.in_not 26 bit IN FALSE hm2_7i95.0.gpio.057.out 26 s32 OUT 0 hm2_7i95.0.inmux.00.enc0-count 26 s32 OUT 0 hm2_7i95.0.inmux.00.enc1-count 26 s32 OUT 0 hm2_7i95.0.inmux.00.enc2-count 26 s32 OUT 0 hm2_7i95.0.inmux.00.enc3-count 26 bit OUT FALSE hm2_7i95.0.inmux.00.input-00 26 bit OUT TRUE hm2_7i95.0.inmux.00.input-00-not 26 bit IN FALSE hm2_7i95.0.inmux.00.input-00-slow 26 bit OUT FALSE hm2_7i95.0.inmux.00.input-01 26 bit OUT TRUE hm2_7i95.0.inmux.00.input-01-not 26 bit IN FALSE hm2_7i95.0.inmux.00.input-01-slow 26 bit OUT FALSE hm2_7i95.0.inmux.00.input-02 26 bit OUT TRUE hm2_7i95.0.inmux.00.input-02-not 26 bit IN FALSE hm2_7i95.0.inmux.00.input-02-slow 26 bit OUT FALSE hm2_7i95.0.inmux.00.input-03 26 bit OUT TRUE hm2_7i95.0.inmux.00.input-03-not 26 bit IN FALSE hm2_7i95.0.inmux.00.input-03-slow 26 bit OUT FALSE hm2_7i95.0.inmux.00.input-04 26 bit OUT TRUE hm2_7i95.0.inmux.00.input-04-not 26 bit IN FALSE hm2_7i95.0.inmux.00.input-04-slow 26 bit OUT FALSE hm2_7i95.0.inmux.00.input-05 26 bit OUT TRUE hm2_7i95.0.inmux.00.input-05-not 26 bit IN FALSE hm2_7i95.0.inmux.00.input-05-slow 26 bit OUT FALSE hm2_7i95.0.inmux.00.input-06 26 bit OUT TRUE hm2_7i95.0.inmux.00.input-06-not 26 bit IN FALSE hm2_7i95.0.inmux.00.input-06-slow 26 bit OUT FALSE hm2_7i95.0.inmux.00.input-07 26 bit OUT TRUE hm2_7i95.0.inmux.00.input-07-not 26 bit IN FALSE hm2_7i95.0.inmux.00.input-07-slow 26 bit OUT FALSE hm2_7i95.0.inmux.00.input-08 26 bit OUT TRUE hm2_7i95.0.inmux.00.input-08-not 26 bit IN FALSE hm2_7i95.0.inmux.00.input-08-slow 26 bit OUT FALSE hm2_7i95.0.inmux.00.input-09 26 bit OUT TRUE hm2_7i95.0.inmux.00.input-09-not 26 bit IN FALSE hm2_7i95.0.inmux.00.input-09-slow 26 bit OUT FALSE hm2_7i95.0.inmux.00.input-10 26 bit OUT TRUE hm2_7i95.0.inmux.00.input-10-not 26 bit IN FALSE hm2_7i95.0.inmux.00.input-10-slow 26 bit OUT FALSE hm2_7i95.0.inmux.00.input-11 26 bit OUT TRUE hm2_7i95.0.inmux.00.input-11-not 26 bit IN FALSE hm2_7i95.0.inmux.00.input-11-slow 26 bit OUT FALSE hm2_7i95.0.inmux.00.input-12 26 bit OUT TRUE hm2_7i95.0.inmux.00.input-12-not 26 bit IN FALSE hm2_7i95.0.inmux.00.input-12-slow 26 bit OUT FALSE hm2_7i95.0.inmux.00.input-13 26 bit OUT TRUE hm2_7i95.0.inmux.00.input-13-not 26 bit IN FALSE hm2_7i95.0.inmux.00.input-13-slow 26 bit OUT FALSE hm2_7i95.0.inmux.00.input-14 26 bit OUT TRUE hm2_7i95.0.inmux.00.input-14-not 26 bit IN FALSE hm2_7i95.0.inmux.00.input-14-slow 26 bit OUT FALSE hm2_7i95.0.inmux.00.input-15 26 bit OUT TRUE hm2_7i95.0.inmux.00.input-15-not 26 bit IN FALSE hm2_7i95.0.inmux.00.input-15-slow 26 bit OUT FALSE hm2_7i95.0.inmux.00.input-16 26 bit OUT TRUE hm2_7i95.0.inmux.00.input-16-not 26 bit IN FALSE hm2_7i95.0.inmux.00.input-16-slow 26 bit OUT FALSE hm2_7i95.0.inmux.00.input-17 26 bit OUT TRUE hm2_7i95.0.inmux.00.input-17-not 26 bit IN FALSE hm2_7i95.0.inmux.00.input-17-slow 26 bit OUT FALSE hm2_7i95.0.inmux.00.input-18 26 bit OUT TRUE hm2_7i95.0.inmux.00.input-18-not 26 bit IN FALSE hm2_7i95.0.inmux.00.input-18-slow 26 bit OUT FALSE hm2_7i95.0.inmux.00.input-19 26 bit OUT TRUE hm2_7i95.0.inmux.00.input-19-not 26 bit IN FALSE hm2_7i95.0.inmux.00.input-19-slow 26 bit OUT FALSE hm2_7i95.0.inmux.00.input-20 26 bit OUT TRUE hm2_7i95.0.inmux.00.input-20-not 26 bit IN FALSE hm2_7i95.0.inmux.00.input-20-slow 26 bit OUT FALSE hm2_7i95.0.inmux.00.input-21 26 bit OUT TRUE hm2_7i95.0.inmux.00.input-21-not 26 bit IN FALSE hm2_7i95.0.inmux.00.input-21-slow 26 bit OUT FALSE hm2_7i95.0.inmux.00.input-22 26 bit OUT TRUE hm2_7i95.0.inmux.00.input-22-not 26 bit IN FALSE hm2_7i95.0.inmux.00.input-22-slow 26 bit OUT FALSE hm2_7i95.0.inmux.00.input-23 26 bit OUT TRUE hm2_7i95.0.inmux.00.input-23-not 26 bit IN FALSE hm2_7i95.0.inmux.00.input-23-slow 26 bit OUT FALSE hm2_7i95.0.inmux.00.raw-input-00 26 bit OUT TRUE hm2_7i95.0.inmux.00.raw-input-00-not 26 bit OUT FALSE hm2_7i95.0.inmux.00.raw-input-01 26 bit OUT TRUE hm2_7i95.0.inmux.00.raw-input-01-not 26 bit OUT FALSE hm2_7i95.0.inmux.00.raw-input-02 26 bit OUT TRUE hm2_7i95.0.inmux.00.raw-input-02-not 26 bit OUT FALSE hm2_7i95.0.inmux.00.raw-input-03 26 bit OUT TRUE hm2_7i95.0.inmux.00.raw-input-03-not 26 bit OUT FALSE hm2_7i95.0.inmux.00.raw-input-04 26 bit OUT TRUE hm2_7i95.0.inmux.00.raw-input-04-not 26 bit OUT FALSE hm2_7i95.0.inmux.00.raw-input-05 26 bit OUT TRUE hm2_7i95.0.inmux.00.raw-input-05-not 26 bit OUT FALSE hm2_7i95.0.inmux.00.raw-input-06 26 bit OUT TRUE hm2_7i95.0.inmux.00.raw-input-06-not 26 bit OUT FALSE hm2_7i95.0.inmux.00.raw-input-07 26 bit OUT TRUE hm2_7i95.0.inmux.00.raw-input-07-not 26 bit OUT FALSE hm2_7i95.0.inmux.00.raw-input-08 26 bit OUT TRUE hm2_7i95.0.inmux.00.raw-input-08-not 26 bit OUT FALSE hm2_7i95.0.inmux.00.raw-input-09 26 bit OUT TRUE hm2_7i95.0.inmux.00.raw-input-09-not 26 bit OUT FALSE hm2_7i95.0.inmux.00.raw-input-10 26 bit OUT TRUE hm2_7i95.0.inmux.00.raw-input-10-not 26 bit OUT FALSE hm2_7i95.0.inmux.00.raw-input-11 26 bit OUT TRUE hm2_7i95.0.inmux.00.raw-input-11-not 26 bit OUT FALSE hm2_7i95.0.inmux.00.raw-input-12 26 bit OUT TRUE hm2_7i95.0.inmux.00.raw-input-12-not 26 bit OUT FALSE hm2_7i95.0.inmux.00.raw-input-13 26 bit OUT TRUE hm2_7i95.0.inmux.00.raw-input-13-not 26 bit OUT FALSE hm2_7i95.0.inmux.00.raw-input-14 26 bit OUT TRUE hm2_7i95.0.inmux.00.raw-input-14-not 26 bit OUT FALSE hm2_7i95.0.inmux.00.raw-input-15 26 bit OUT TRUE hm2_7i95.0.inmux.00.raw-input-15-not 26 bit OUT FALSE hm2_7i95.0.inmux.00.raw-input-16 26 bit OUT TRUE hm2_7i95.0.inmux.00.raw-input-16-not 26 bit OUT FALSE hm2_7i95.0.inmux.00.raw-input-17 26 bit OUT TRUE hm2_7i95.0.inmux.00.raw-input-17-not 26 bit OUT FALSE hm2_7i95.0.inmux.00.raw-input-18 26 bit OUT TRUE hm2_7i95.0.inmux.00.raw-input-18-not 26 bit OUT FALSE hm2_7i95.0.inmux.00.raw-input-19 26 bit OUT TRUE hm2_7i95.0.inmux.00.raw-input-19-not 26 bit OUT FALSE hm2_7i95.0.inmux.00.raw-input-20 26 bit OUT TRUE hm2_7i95.0.inmux.00.raw-input-20-not 26 bit OUT FALSE hm2_7i95.0.inmux.00.raw-input-21 26 bit OUT TRUE hm2_7i95.0.inmux.00.raw-input-21-not 26 bit OUT FALSE hm2_7i95.0.inmux.00.raw-input-22 26 bit OUT TRUE hm2_7i95.0.inmux.00.raw-input-22-not 26 bit OUT FALSE hm2_7i95.0.inmux.00.raw-input-23 26 bit OUT TRUE hm2_7i95.0.inmux.00.raw-input-23-not 26 bit IN FALSE hm2_7i95.0.led.CR01 26 bit IN FALSE hm2_7i95.0.led.CR02 26 bit IN FALSE hm2_7i95.0.led.CR03 26 bit IN FALSE hm2_7i95.0.led.CR04 26 bit OUT TRUE hm2_7i95.0.packet-error 26 bit OUT TRUE hm2_7i95.0.packet-error-exceeded 26 s32 OUT 10 hm2_7i95.0.packet-error-level 26 s32 OUT 0 hm2_7i95.0.read-request.time 26 s32 OUT 350 hm2_7i95.0.read.time 26 bit IN FALSE hm2_7i95.0.ssr.00.out-00 <== spindle-enable 26 bit IN TRUE hm2_7i95.0.ssr.00.out-01 <== machine-is-enabled 26 bit IN FALSE hm2_7i95.0.ssr.00.out-02 26 bit IN FALSE hm2_7i95.0.ssr.00.out-03 26 bit IN FALSE hm2_7i95.0.ssr.00.out-04 26 bit IN FALSE hm2_7i95.0.ssr.00.out-05 26 u32 IN 0x000F4240 hm2_7i95.0.ssr.00.rate 26 bit IN TRUE hm2_7i95.0.stepgen.00.control-type 26 s32 OUT 0 hm2_7i95.0.stepgen.00.counts 26 float OUT 0 hm2_7i95.0.stepgen.00.dbg_err_at_match 26 float OUT 0 hm2_7i95.0.stepgen.00.dbg_ff_vel 26 float OUT 0 hm2_7i95.0.stepgen.00.dbg_pos_minus_prev_cmd 26 float OUT 0 hm2_7i95.0.stepgen.00.dbg_s_to_match 26 s32 OUT 0 hm2_7i95.0.stepgen.00.dbg_step_rate 26 float OUT 0 hm2_7i95.0.stepgen.00.dbg_vel_error 26 bit IN TRUE hm2_7i95.0.stepgen.00.enable <== x-enable 26 float IN 0 hm2_7i95.0.stepgen.00.position-cmd 26 float OUT 0 hm2_7i95.0.stepgen.00.position-fb ==> x-pos-fb 26 float IN 0 hm2_7i95.0.stepgen.00.velocity-cmd <== x-output 26 float OUT 0 hm2_7i95.0.stepgen.00.velocity-fb 26 bit IN TRUE hm2_7i95.0.stepgen.01.control-type 26 s32 OUT 0 hm2_7i95.0.stepgen.01.counts 26 float OUT 0 hm2_7i95.0.stepgen.01.dbg_err_at_match 26 float OUT 0 hm2_7i95.0.stepgen.01.dbg_ff_vel 26 float OUT 0 hm2_7i95.0.stepgen.01.dbg_pos_minus_prev_cmd 26 float OUT 0 hm2_7i95.0.stepgen.01.dbg_s_to_match 26 s32 OUT 0 hm2_7i95.0.stepgen.01.dbg_step_rate 26 float OUT 0 hm2_7i95.0.stepgen.01.dbg_vel_error 26 bit IN TRUE hm2_7i95.0.stepgen.01.enable <== y-enable 26 float IN 0 hm2_7i95.0.stepgen.01.position-cmd 26 float OUT 0 hm2_7i95.0.stepgen.01.position-fb ==> y-pos-fb 26 float IN 0 hm2_7i95.0.stepgen.01.velocity-cmd <== y-output 26 float OUT 0 hm2_7i95.0.stepgen.01.velocity-fb 26 bit IN TRUE hm2_7i95.0.stepgen.02.control-type 26 s32 OUT 0 hm2_7i95.0.stepgen.02.counts 26 float OUT 0 hm2_7i95.0.stepgen.02.dbg_err_at_match 26 float OUT 0 hm2_7i95.0.stepgen.02.dbg_ff_vel 26 float OUT 0 hm2_7i95.0.stepgen.02.dbg_pos_minus_prev_cmd 26 float OUT 0 hm2_7i95.0.stepgen.02.dbg_s_to_match 26 s32 OUT 0 hm2_7i95.0.stepgen.02.dbg_step_rate 26 float OUT 0 hm2_7i95.0.stepgen.02.dbg_vel_error 26 bit IN TRUE hm2_7i95.0.stepgen.02.enable <== y2-enable 26 float IN 0 hm2_7i95.0.stepgen.02.position-cmd 26 float OUT 0 hm2_7i95.0.stepgen.02.position-fb ==> y2-pos-fb 26 float IN 0 hm2_7i95.0.stepgen.02.velocity-cmd <== y2-output 26 float OUT 0 hm2_7i95.0.stepgen.02.velocity-fb 26 bit IN TRUE hm2_7i95.0.stepgen.03.control-type 26 s32 OUT 0 hm2_7i95.0.stepgen.03.counts 26 float OUT 0 hm2_7i95.0.stepgen.03.dbg_err_at_match 26 float OUT 0 hm2_7i95.0.stepgen.03.dbg_ff_vel 26 float OUT 0 hm2_7i95.0.stepgen.03.dbg_pos_minus_prev_cmd 26 float OUT 0 hm2_7i95.0.stepgen.03.dbg_s_to_match 26 s32 OUT 0 hm2_7i95.0.stepgen.03.dbg_step_rate 26 float OUT 0 hm2_7i95.0.stepgen.03.dbg_vel_error 26 bit IN TRUE hm2_7i95.0.stepgen.03.enable <== z-enable 26 float IN 0 hm2_7i95.0.stepgen.03.position-cmd 26 float OUT 0 hm2_7i95.0.stepgen.03.position-fb ==> z-pos-fb 26 float IN 0 hm2_7i95.0.stepgen.03.velocity-cmd <== z-output 26 float OUT 0 hm2_7i95.0.stepgen.03.velocity-fb 26 bit IN TRUE hm2_7i95.0.stepgen.04.control-type 26 s32 OUT 0 hm2_7i95.0.stepgen.04.counts 26 float OUT 0 hm2_7i95.0.stepgen.04.dbg_err_at_match 26 float OUT 0 hm2_7i95.0.stepgen.04.dbg_ff_vel 26 float OUT 0 hm2_7i95.0.stepgen.04.dbg_pos_minus_prev_cmd 26 float OUT 0 hm2_7i95.0.stepgen.04.dbg_s_to_match 26 s32 OUT 0 hm2_7i95.0.stepgen.04.dbg_step_rate 26 float OUT 0 hm2_7i95.0.stepgen.04.dbg_vel_error 26 bit IN TRUE hm2_7i95.0.stepgen.04.enable <== a-enable 26 float IN 0 hm2_7i95.0.stepgen.04.position-cmd 26 float OUT 0 hm2_7i95.0.stepgen.04.position-fb 26 float IN 0 hm2_7i95.0.stepgen.04.velocity-cmd <== a-output 26 float OUT 0 hm2_7i95.0.stepgen.04.velocity-fb 26 bit IN FALSE hm2_7i95.0.stepgen.05.control-type 26 s32 OUT 0 hm2_7i95.0.stepgen.05.counts 26 float OUT 0 hm2_7i95.0.stepgen.05.dbg_err_at_match 26 float OUT 0 hm2_7i95.0.stepgen.05.dbg_ff_vel 26 float OUT 0 hm2_7i95.0.stepgen.05.dbg_pos_minus_prev_cmd 26 float OUT 0 hm2_7i95.0.stepgen.05.dbg_s_to_match 26 s32 OUT 0 hm2_7i95.0.stepgen.05.dbg_step_rate 26 float OUT 0 hm2_7i95.0.stepgen.05.dbg_vel_error 26 bit IN FALSE hm2_7i95.0.stepgen.05.enable 26 float IN 0 hm2_7i95.0.stepgen.05.position-cmd 26 float OUT 0 hm2_7i95.0.stepgen.05.position-fb 26 float IN 0 hm2_7i95.0.stepgen.05.velocity-cmd 26 float OUT 0 hm2_7i95.0.stepgen.05.velocity-fb 26 s32 IN -1 hm2_7i95.0.stepgen.timer-number 26 bit I/O FALSE hm2_7i95.0.watchdog.has_bit 26 s32 OUT 259 hm2_7i95.0.write.time
6 years 3 months ago #173871 by trial31
Sorry but I'm quite confused...now LinuxCnc is not starting anymore..
is like the Hal file is wrong but is not changed...
that's the error:
hm2/hm2_7i95.0: Low Level init 0.15
board fails HM2 registration
taked from:
Print file information: RUN_IN_PLACE=no LINUXCNC_DIR= LINUXCNC_BIN_DIR=/usr/bin LINUXCNC_TCL_DIR=/usr/lib/tcltk/linuxcnc LINUXCNC_SCRIPT_DIR= LINUXCNC_RTLIB_DIR=/usr/lib/linuxcnc/modules LINUXCNC_CONFIG_DIR= LINUXCNC_LANG_DIR=/usr/lib/tcltk/linuxcnc/msgs INIVAR=inivar HALCMD=halcmd LINUXCNC_EMCSH=/usr/bin/wish8.6 LINUXCNC - 2.9.0~pre0 Machine configuration directory is '/home/cnc/linuxcnc/configs/test2' Machine configuration file is 'test2.ini' INIFILE=/home/cnc/linuxcnc/configs/test2/test2.ini VERSION=1.1 PARAMETER_FILE=linuxcnc.var TASK=milltask HALUI=halui DISPLAY=axis COORDINATES=XYYZA KINEMATICS=trivkins coordinates=XYYZA kinstype=BOTH Starting LinuxCNC... Starting LinuxCNC server program: linuxcncsvr Loading Real Time OS, RTAPI, and HAL_LIB modules Starting LinuxCNC IO program: io Starting HAL User Interface program: halui Found file(REL): ./test2.hal Shutting down and cleaning up LinuxCNC... Running HAL shutdown script trivkins: coordinates:XYYZA Joint 0 ==> Axis X Joint 1 ==> Axis Y Joint 2 ==> Axis Y Joint 3 ==> Axis Z Joint 4 ==> Axis A hm2: loading Mesa HostMot2 driver version 0.15 hm2_eth: loading Mesa AnyIO HostMot2 ethernet driver version 0.2 hm2_eth: 192.168.1.121: INFO: Hardware address (MAC): 00:60:1b:15:00:0d hm2_eth: discovered 7I95 hm2/hm2_7i95.0: Low Level init 0.15 board fails HM2 registration hm2_eth: in hm2_eth_reset hm2: unloading Removing HAL_LIB, RTAPI, and Real Time OS modules Removing NML shared memory segments Debug file information: Note: Using POSIX realtime hm2/hm2_7i95.0: error reading Pin Descriptor 48 (at 0x0680) hm2_eth: rtapi_app_main: Input/output error (-5) ./test2.hal:9: waitpid failed /usr/bin/rtapi_app hm2_eth ./test2.hal:9: /usr/bin/rtapi_app exited without becoming ready ./test2.hal:9: insmod for hm2_eth failed, returned -1 6858 Stopping realtime threads Unloading hal components Note: Using POSIX realtime
I checked again the power supply is 4.95v (a standard PC power supply with 5v 15A) and is nothing connected to the mesa card..only ethernet cable and 0/5v power..
any help is welcome...
6 years 3 months ago #173875 by PCW
Sounds like there is a very basic communication error (dropped packets):
Can you ping the card reliably?
6 years 3 months ago #173880 by trial31
Yes, ping is in range 0.120-0.140ms max 0.150ms
Moderators: PCW, jmelson
Time to create page: 0.411 seconds
