Mesa 5i25 & 7i77 bios
- jeffie-3
18 Dec 2019 16:33 #152855
by jeffie-3
Mesa 5i25 & 7i77 bios was created by jeffie-3
How do I confirm what versions of the bios each card has?
Thank you,
Jeff
Thank you,
Jeff
- Thank you received: 5330
18 Dec 2019 17:39 - 18 Dec 2019 17:40 #152861
Replied by PCW on topic Mesa 5i25 & 7i77 bios
The 7I77 firmware versions (swrevisions) are available as hal parameters (14 = 0x0E is
current), the 5I25 firmware version is probably unimportant unless its is more than about 3-4 years old,
in which case it should be updated.
Last edit: 18 Dec 2019 17:40 by PCW.
The following user(s) said Thank You: jeffie-3
- Thank you received: 7488
18 Dec 2019 17:40 #152862
Replied by tommylight on topic Mesa 5i25 & 7i77 bios
mesaflash --device 5i25 --readhmid
- jeffie-3
18 Dec 2019 20:15 #152874
by jeffie-3
Replied by jeffie-3 on topic Mesa 5i25 & 7i77 bios
Where would I find hal parameters ?
- jeffie-3
18 Dec 2019 20:18 #152876
by jeffie-3
I opened a terminal window and typed in the command you gave me. It gave me mesaflash command not found.
I am new to linux.
I am new to linux.
18 Dec 2019 21:20 - 18 Dec 2019 21:21 #152883
if this is a standard LinuxCNC installation you might try
sudo apt-get install mesaflash
To read the parameters you start a Linuxcnc session and use the
"machine" --> "show hal configuration" --> "show" menus to navigate to something like
"parameters" --> hm2_5i25.0.7i77.0.swrevision
Last edit: 18 Dec 2019 21:21 by PCW.
- slckzbn
19 Dec 2019 08:10 #152901
by slckzbn
Replied by slckzbn on topic Mesa 5i25 & 7i77 bios
Thank you for your answer.
Now servo-motor is running (DTG X and Vel) but X always 0 and the servo-motor never stop.How can i solve this problem ?
Thank you for your interest.
19 Dec 2019 10:09 #152904
- barisduzenli
19 Dec 2019 12:51 #152906
by barisduzenli
Replied by barisduzenli on topic Mesa 5i25 & 7i77 bios
Hello
We could not get encoders data.
History;
1-) We wired 5i25 + 7i77 + 4 Delta Servos
- 5i25 works, 7i77 works and linuxcnc works
- we have disabled limitswitches' pins or ports (LMT SWT)
2-) At Axis GUI, we can drive servos basicly. We can turn clockwise or counter clockwise at fast speeds or Low speeds each of three axis by manuel click control.
But we have in trouble with two things now.
1-) At the beginning, the servos turns slowly in clockwise without any click or mdi commands. We could not achieve to stop them via mdi commands. When we press to home continues to turn.
2-) When we use mdi command to move a position for each axis independently. The servo related to axis starts to turn but not stops again. we can control the speed and direction of the servo via random mdi commands. But impossible to stop it.
We are in doubt with wirings that you can find in the attachments. Or something else that we do know.
History;
- barisduzenli
19 Dec 2019 13:04 #152907
by barisduzenli
Hello you can find my final wiring and jumper settings at the attached file.
We can achieve to turn servos but not to stop them. They are just turning via mdi commands. We can control speed and directions of each axis. But impossible to stop.
We thought that encoder data do not reach to 7i77. But we are not sure this is because of wiring or hal configuration.
Time to create page: 1.409 seconds
