Controller recommendations (other than mesa)
25 Aug 2026 10:13 #348996 by hansfbaier
Replied by hansfbaier on topic Controller recommendations (other than mesa)
Not true anymore. There is a very nice open hardware card, called rioctrl:
github.com/festlv/rioctrl-hw/tree/main/rioctrl-controller
I still have a number of those surplus from the last production run and can sell those.
I also designed Mesa-Style IO hats for it with
5 axes 4 encoder inputs, 8i/4o direct I/O and 16 out/32 in (shifted),
which I could sell, if anyone is interested.
27 Aug 2026 09:14 #349038 by timo
Just for curiosity: How much would one of those "surplus" cards cost?
Would it be manageable for someone who is only end user level?
Is it really easier to use than a MESA card?
(referring to the original complaint that the documentation and instructions were not sufficient)
Maybe in 2020 the complaint was more valid than it is today. Because some info and updates made it better since then.
28 Aug 2026 15:49 #349083 by tuxcnc
First of all, some users do not need LinuxCNC at all because they perform simple tasks for which GRBL/FluidNC is enough. LinuxCNC is just an unnecessary complication and additional cost for them. Secondly, the conversation about LinuxCNC should start with github.com/jzolee/HAL2UDP - the cheapest solution worth recommending (ESP32 + W5500 +OptoBOB or CNCshield), unfortunately with limited possibilities. Then there is riocore (recently active topic on the Forum). Later, Chinese cards compatible with 7i92 available on Aliexpress. And finally, the original MESA cards, unfortunately expensive and difficult to obtain in some countries, but widely praised. The most expensive and so far quite difficult to configure is Ethercat (I use it and I like it, but I don't recommend it to beginners).
28 Aug 2026 17:47 #349087 by tommylight
Replied by tommylight on topic Controller recommendations (other than mesa)
...the conversation about LinuxCNC should start with github.com/jzolee/HAL2UDP - the cheapest solution worth recommending (ESP32 + W5500 +OptoBOB or CNCshield), unfortunately with limited possibilities.
Correction, no need for OptoBOB nor cncshield, all new-ish china drives have their own optocouplers, so unless doing something out of the ordinary, there is no need for it.
Do not use those "arduino wires" to connect the ESP32 to W5500 though as it will cause a lot of grief, solder wires, short, 10-15cm max.
Here is such combo tested at 40kHz i think
www.youtube.com/shorts/55287Iaa4Y0
28 Aug 2026 18:13 #349089 by tuxcnc
ESP32 is 3.3V and it is too low for some drivers, but some will works.
Wires are wires, the problem may be with poor quality connectors. Some are good, some can be repaired, some are useless, it depends on which ones you get.
I agree, the wires to W5500 must be as short as possible.
28 Aug 2026 19:38 #349096 by tommylight
Sorry i forgot about this, mainly because i tested several drives and all worked fine.
28 Aug 2026 21:24 #349097 by rodw
This is a LinuxCNC forum, not a general CNC forum. we should not be discussing alternative CNC environments. Personally, I chose LinuxCNC because it can handle whatever I throw at it, accepting the learning curve because as I built different machines, I could keep using it.
With LinuxCNC, building with a parallel port gets you going with an old PC and a $10 BOB  is far superior and probably far cheaper to something like a grbl board and leaves you with an infinite upgrade path.
The following user(s) said Thank You: NWE
29 Aug 2026 03:47 #349112 by tuxcnc
I have several machines controlled by LinuxCNC and I think this is the optimal choice. I also have a CO2 laser controlled by Makerbase MKS32 with FluidNC installed, which I operate via WiFi from my laptop used for design. I can't imagine it, and no one will convince me to install an old PC with LPT and a monitor there. There are also people on the forum who ask how to use LinuxCNC where a PLC or even the cheapest microcontroller is enough. Yes, LinuxCNC is great and can do almost everything, but that's no reason to force it on everyone and everything.
29 Aug 2026 13:19 #349115 by timo
Do "old PCs" still have Parallel ports? :-).
29 Aug 2026 15:08 #349121 by tuxcnc
Some modern ones do.
There are PCI or PCIe to LPT cards too.
But this does not mean that a given computer is suitable for LinuxCNC because it has LPT port or LPT card.
There are other factors that determine this.
Moderators: PCW, jmelson
Time to create page: 1.578 seconds
