Need some wiring help with board...
6 years 6 months ago #163428 by Catch22
Awesome, thanks I will do that tomorrow.
6 years 6 months ago #163431 by jj80909
For AMC (Advanced Motion Controls) servo amps, you can easily invert the inhibit signal by removing a shunt soldered to the amplifier board (J1).
With J1 removed, you can wire directly to the Mesa enable - no relay(s) needed.
Jim
The following user(s) said Thank You: Catch22
6 years 6 months ago #163432 by Catch22
And if I do remove the shunt, and wire directly to enable on the 7i77 where do I wire that to the drive. Inhibit in ?
6 years 6 months ago #163490 by tommylight
6 years 6 months ago #163504 by Catch22
I can't seem to find the J1 on this board anywhere, and I'm using a magnifying glass, or is it on the underside of the board?
6 years 6 months ago #163505 by Catch22
Could I try and use 2.7k 1/2 watt resistor, that's all I have here right now?
Moderators: PCW, jmelson
Time to create page: 0.476 seconds
