AMC drive J1 removal.
- Catch22
- Thank you received: 17
13 Apr 2020 16:38 #163882
by Catch22
Yup you are right, I actually bought 3 off of him and 2 don't work, but unfortunately for me I bought them a year ago and I tried getting ahold of him to let him know but no reply.
Replied by Catch22 on topic AMC drive J1 removal.
Let me guess, the drive with the clear tape on it is giving you trouble? I bought 2 off fleabay both had ugly clear packing tape on it as a "warranty " label. Was made to look like factory protectant covering to trick buyer into thinking it's new. Well, both of mine were duds. I was told if I removed the covering they would not refund. Seller T**-*i did make good on the return. So heads up, if this is from the same seller. Don't expect it to work.
- Catch22
13 Apr 2020 16:40 #163884
by Catch22
You are the man tommylight, it works now.
Thanks so much, you don't know how much I really appreciate it.
Thanks Mike
Is it a 2.7 Ohm or 2.7KOhm ?Ya I got in a bit of a hurry, and with the 2.7 ohm resistor I thought I would try and touch 5v to the inhibit, big mistake as it blew a bunch of fuses in the panel and I think it fried the drive also.
That is a huge difference.
2.7Ohm will not work, but the drive should be OK.
There is the +10V 3mA output on the drive, so that would work for the other wire.
Thanks Mike
- OT-CNC
- Thank you received: 75
13 Apr 2020 17:10 #163888
by OT-CNC
I'm sorry to hear that. I don't like dishonest sellers.
It was just my luck that the 1st one I tried setting up just worked poorly enough to make me think I was doing things wrong. It kept faulting out. I ended up wasting a lot of time fiddling with pot settings. Once I moved on to the 2nd one, which didn't turn on, it became obvious that the drives were damaged. One had blown components on the board.
In the future, I will always remove the cover and inspect the electronics on fleabay stuff. Regardless of weather the seller lists it as "new".
Also, set all pot/dipswitch settings to manufacturer recommendations then test the drive with a 1.5v battery on the analog control before hooking up to linuxcnc to prove that it can rotate motor cw/ccw. Just to rule out further problems.
Replied by OT-CNC on topic AMC drive J1 removal.
The following user(s) said Thank You: Catch22
- Thank you received: 7478
13 Apr 2020 17:31 #163891
Replied by tommylight on topic AMC drive J1 removal.
You are welcomed, always.
Thanks Mike
Time to create page: 0.600 seconds
