computer / linuxcnc unable to detect mesanet 6i24 board
18 Apr 2020 20:36 #164509 by PCW
Does the 6I24 configure itself at power up? (both red lights out)
  • owhite
  • owhite's Avatar Topic Author
  • Junior Member
  • Junior Member
18 Apr 2020 20:42 #164511 by owhite
no LEDs go on during the boot up sequence.
one flashes for ~200ms when the computer powers down.
18 Apr 2020 20:46 #164512 by PCW
Hmm you should get a red LED briefly at power up (not boot related)
  • owhite
  • Junior Member
  • Junior Member
18 Apr 2020 20:58 - 18 Apr 2020 20:59 #164515 by owhite
okay sorry I was looking for the lights flashing as it was booting up - but it DOES flash one red, one orange briefly exactly when I hit the power.
still no joy. I'm still getting the "Error: BootSector is invalid" however.
Last edit: 18 Apr 2020 20:59 by owhite.
18 Apr 2020 21:02 #164516 by PCW
Is the 6I24 jumpered for 33 MHz? (default to 5I24 firmware)
  • owhite
  • Junior Member
  • Junior Member
18 Apr 2020 21:08 #164517 by owhite
yes - I checked again. That's the default jumper settings as shown on page 8 of:
www.mesanet.com/pdf/parallel/6i24man.pdf
  • owhite
  • Junior Member
  • Junior Member
18 Apr 2020 21:28 #164520 by owhite
is it relevant that lspci -v is reporting:
02:00.0 DPIO module: Device 2718:5124 (rev 01)
           Subsystem: Device 2718:5124
           Flags: medium devsel, IRQ 11
           Memory at f7c00000 (32-bit, non-prefetchable) [disabled] [size=64K]
18 Apr 2020 21:33 #164523 by PCW
That looks OK except the "disabled"
What does
sudo mesaflash --device 5i24 --readhmid
report?
  • owhite
  • Junior Member
  • Junior Member
18 Apr 2020 21:39 #164524 by owhite
ERROR: no HOSTMOT2 firmware found. FFFFFFFF
Configuration Name:
  BoardName :
  FPGA Size: 0 KGates
  FPGA Pins: 0
  Number of IO Ports: 0
  Width of one I/O port: 0
  Clock Low frequency: 0.0000 MHz
  Clock High frequency: 0.0000 MHz
  IDROM Type: 0
  Instance Stride 0: 0
  Instance Stride 1: 0
  Register Stride 0: 0
  Register Stride 1: 0
Modules in configuration:
Configuration pin-out:
18 Apr 2020 21:43 #164525 by PCW
OK so its possibly a BIOS issue disabling the card for some reason
Does
halcmd -kf
halcmd: loadrt hostmot2
halcmd: loadrt hm2_pci
get any further?
(I know at one time the pci driver enabled disabled cards to work around BIOS issues)
Moderators: PCW, jmelson
Time to create page: 0.149 seconds
