computer / linuxcnc unable to detect mesanet 6i24 board
  • owhite
  • owhite's Avatar Topic Author
  • Junior Member
  • Junior Member
18 Apr 2020 21:53 - 18 Apr 2020 21:55 #164526 by owhite
Okay - that is very promising!
When I loadrt hostmot2 and hm2_pci then I get the output that is show below, AND it let me write a .bit file!
Thank you very much. Next stop is to try to making custom .bit files. I VERY much appreciate your time.
owen
$ sudo mesaflash --device 5i24 --readhmid
Configuration Name: HOSTMOT2
  BoardName : MESA5I24
  FPGA Size: 16 KGates
  FPGA Pins: 256
  Number of IO Ports: 3
  Width of one I/O port: 24
  Clock Low frequency: 33.3333 MHz
  Clock High frequency: 200.0000 MHz
  IDROM Type: 3
  Instance Stride 0: 4
  Instance Stride 1: 64
  Register Stride 0: 256
  Register Stride 1: 256
Modules in configuration:
  Module: WatchDog
  There are 1 of WatchDog in configuration
  Version: 0
  Registers: 3
  BaseAddress: 0C00
  ClockFrequency: 33.333 MHz
  Register Stride: 256 bytes
  Instance Stride: 4 bytes
  Module: IOPort
  There are 3 of IOPort in configuration
  Version: 0
  Registers: 5
  BaseAddress: 1000
  Module: LED
  There are 1 of LED in configuration
  Version: 0
  Registers: 1
  BaseAddress: 0200
Configuration pin-out:
IO Connections for P4
Pin#  I/O   Pri. func    Sec. func       Chan      Pin func        Pin Dir
 1      0   IOPort       None
 3      1   IOPort       None
 5      2   IOPort       None
 7      3   IOPort       None
 9      4   IOPort       None
11      5   IOPort       None
13      6   IOPort       None
15      7   IOPort       None
17      8   IOPort       None
19      9   IOPort       None
21     10   IOPort       None
23     11   IOPort       None
25     12   IOPort       None
27     13   IOPort       None
29     14   IOPort       None
31     15   IOPort       None
33     16   IOPort       None
35     17   IOPort       None
37     18   IOPort       None
39     19   IOPort       None
41     20   IOPort       None
43     21   IOPort       None
45     22   IOPort       None
47     23   IOPort       None
IO Connections for P3
 1     24   IOPort       None
 3     25   IOPort       None
 5     26   IOPort       None
 7     27   IOPort       None
 9     28   IOPort       None
11     29   IOPort       None
13     30   IOPort       None
15     31   IOPort       None
17     32   IOPort       None
19     33   IOPort       None
21     34   IOPort       None
23     35   IOPort       None
25     36   IOPort       None
27     37   IOPort       None
29     38   IOPort       None
31     39   IOPort       None
33     40   IOPort       None
35     41   IOPort       None
37     42   IOPort       None
39     43   IOPort       None
41     44   IOPort       None
43     45   IOPort       None
45     46   IOPort       None
47     47   IOPort       None
IO Connections for P2
 1     48   IOPort       None
 3     49   IOPort       None
 5     50   IOPort       None
 7     51   IOPort       None
 9     52   IOPort       None
11     53   IOPort       None
13     54   IOPort       None
15     55   IOPort       None
17     56   IOPort       None
19     57   IOPort       None
21     58   IOPort       None
23     59   IOPort       None
25     60   IOPort       None
27     61   IOPort       None
29     62   IOPort       None
31     63   IOPort       None
33     64   IOPort       None
35     65   IOPort       None
37     66   IOPort       None
39     67   IOPort       None
41     68   IOPort       None
43     69   IOPort       None
45     70   IOPort       None
47     71   IOPort       None
Last edit: 18 Apr 2020 21:55 by owhite.
  • owhite
  • Junior Member
  • Junior Member
18 Apr 2020 21:57 #164528 by owhite
One other item just for archival purposes.
lspci -v produced this output
02:00.0 DPIO module: Device 2718:5124 (rev 01)
	Subsystem: Device 2718:5124
	Flags: medium devsel, IRQ 16
	Memory at f7c00000 (32-bit, non-prefetchable) [size=64K]
18 Apr 2020 22:43 #164532 by PCW
Yeah looks like mesaflash should be taught to enable PCI cards that are disabled by the BIOS
Moderators: PCW, jmelson
Time to create page: 0.268 seconds
