7i84-via-7i44-via-7i93 Mesa configuration wizard
- lrak
- Thank you received: 22
20 Sep 2020 22:57 #182980
by lrak
Replied by lrak on topic 7i84-via-7i44-via-7i93 Mesa configuration wizard
No - the two 7i29s (with W3 alternated) are on P1 - 7i44 on P2
- Thank you received: 5325
20 Sep 2020 22:58 #182981
Replied by PCW on topic 7i84-via-7i44-via-7i93 Mesa configuration wizard
OK that's backwards
- lrak
20 Sep 2020 23:09 #182985
by lrak
Something I can fix in the configs or I need to figure out a way to pass a cable under the board?
- lrak
20 Sep 2020 23:11 #182986
by lrak
The configurator saw the 7i29s??
21 Sep 2020 00:13 #182994
The configurator only deals with its internal data, it doesn't look at the hardware
- lrak
21 Sep 2020 21:48 #183192
by lrak
OK - I swapped the cables - still have red lights on the 7i84s.
$ halcmd show all ; does not see anything other than the 7i93 lines
As for the pncconf - from what you said, it does not probe the hardware. Just creates a config template from user input.
In pncconf there is no option to select the 7i93_svss4_8d firmware type - only 4_4.
I tried adding sserial_port bit to hal - nothing changed.
loadrt hm2_eth board_ip="192.168.10.10" config=" num_encoders=4 num_pwmgens=4 num_stepgens=4 sserial_port_0=00000000"
What is the bare minimum that needs to be in the ini and hal files for linuxcnc to see the 7i84? An example hal might help.
21 Sep 2020 23:16 #183198
Do you have both A and B side VFIELD applied?
Minimum for detection is:
loadrt hostmot2
loadrt hm2_eth
loadrt hostmot2
loadrt hm2_eth
- lrak
22 Sep 2020 00:47 - 22 Sep 2020 00:50 #183211
by lrak
Yes - Both both A and B side VFIELD are applied. - verified once again via voltmeter.
Cables between 7i44 and 7i84 straight connection verified with cable tester.
The hal file starts off :
loadrt [KINS]KINEMATICS
loadrt hostmot2
setp hm2_7i93.0.pwmgen.pwm_frequency 20000
setp hm2_7i93.0.pwmgen.pdm_frequency 6000000
setp hm2_7i93.0.watchdog.timeout_ns 5000000
loadrt pid names=pid.x,pid.y,pid.z,pid.s
loadrt abs names=abs.spindle
loadrt lowpass names=lowpass.spindle
Last edit: 22 Sep 2020 00:50 by lrak.
22 Sep 2020 01:03 #183216
what does
mesaflash --device 7i93 --addr 192.168.10.10 --readhmid
report?
report?
- lrak
22 Sep 2020 01:15 #183219
by lrak
See attached
Time to create page: 0.917 seconds
