7i84-via-7i44-via-7i93 Mesa configuration wizard
- Thank you received: 5325
22 Sep 2020 02:33 #183233
Replied by PCW on topic 7i84-via-7i44-via-7i93 Mesa configuration wizard
OK so that's clearly the wrong firmware
Did you flash the 7I93 card with 7i93_svss4_8d.bit?
The following user(s) said Thank You: lrak
- lrak
- Thank you received: 22
22 Sep 2020 05:39 #183256
by lrak
Replied by lrak on topic 7i84-via-7i44-via-7i93 Mesa configuration wizard
$ mesaflash --addr 192.168.10.10 --device 7i93 --verify 7i93_svss4_8d.bit
Checking file... OK
File type: BIT file
Boot sector OK
Verifying EEPROM sectors starting from 0x100000...
|VVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVV
Board configuration verified successfully.Please Log in or Create an account to join the conversation.
22 Sep 2020 14:48 - 22 Sep 2020 15:17 #183313
Do you get the same --readhmid results if you power cycle the card now?
Edit, I rebuilt the bitfile:
In case there was an issue with the bitfile in the distribution
Last edit: 22 Sep 2020 15:17 by PCW.
- lrak
22 Sep 2020 17:52 #183326
by lrak
That fixed things..
I now have 7i84 lines from
halcmd show all
but not 7i29 lines - I think that makes sense?
This might help you - the archive the bad file was from had this file size and date -
6461914 2020-08-16 23:03
halcmd show all
Time to create page: 0.204 seconds
