7c80 install on rpi 4
4 years 9 months ago #230669 by strahlensauger
Replied by strahlensauger on topic 7c80 install on rpi 4
Do you habe a photo?
Sounds promising.
4 years 9 months ago #230687 by PHILCOAST
Replied by PHILCOAST on topic 7c80 install on rpi 4
The following user(s) said Thank You: strahlensauger
4 years 9 months ago #233213 by Boaschti
Replied by Boaschti on topic 7c80 install on rpi 4
Can you upload your .hal and .ini?
4 years 9 months ago - 4 years 9 months ago #233221 by PHILCOAST
most of the functions have been tested successfully but I still have some adjustments to make
File Name: test.hal
File Size:13 KB
File Name: test.ini
File Size:5 KB
Last edit: 4 years 9 months ago by PHILCOAST.
The following user(s) said Thank You: rdtsc
3 years 6 months ago #269556 by chernogorsky
Replied by chernogorsky on topic 7c80 install on rpi 4
I think its appropriate to continue in that topic (if not, I'll create a new one)
I have strange issue with 7c80,
Im configuring spindle. Spindleout works finally,
but I cant configure ENA/DIR isolated output
I configured them as
setp hm2_7c80.0.gpio.020.invert_output true
setp hm2_7c80.0.gpio.020.is_output true
setp hm2_7c80.0.gpio.021.invert_output true
setp hm2_7c80.0.gpio.021.is_output true
net spindle-cw => hm2_7c80.0.gpio.020.out
net spindle-ccw => hm2_7c80.0.gpio.021.out
I see that it works in a halmon once I enable it
But it does not enable the pins on a TB5
another point (not sure if it should be so) is that in the readhmid I see the following (no secondary function):
TB5-2 18 IOPort PWM 0 PWM (Out)
TB5-2 19 IOPort PWM 0 /Enable (Out)
TB5-5,6 20 IOPort None
TB5-7,8Internal 21 IOPort None
Any idea toward the error in my DNA ?
3 years 6 months ago #269557 by PCW
Replied by PCW on topic 7c80 install on rpi 4
The ENA/DIR or FWD/REV outputs are switches, not voltage outputs
so must be tested with a ohmmeter or switching a load.
Moderators: PCW, jmelson
Time to create page: 0.344 seconds
