7c80 install on rpi 4
6 years 1 week ago #186637 by jimhurlburt
Replied by jimhurlburt on topic 7c80 install on rpi 4
I have it running. Steppers turn in a plausible fashion. No smoke.
Next thing I have to do involves some serious construction so it will take a while before the next post.
What I did that worked.
I created .hal and .ini files with pncconf on a 2.8 install, selecting the 7i96 board.
I then changed all instances of 7i96e to 7c80 in the hal file
I changed the line
loadrt hm2_ether ... (not certain about the spelling of ether but something along that line.
to
loadrt hm2_rpspi config=" num_encoders=0 num_pwmgens=0 num_stepgens=6"
Using mesaflash I loaded 7c80d.bit
Per pwc's advice, after a number if trys that didn't work.
I did a clean write to a sdcard of linuxcnc-2.8.0-pi4.zip from this site
I ran
git clone git://github.com/linuxcnc/linuxcnc.git linuxcnc-dev
sudo apt-get install build-essential autoconf
libpth-dev libglib2.0-dev libgtk2.0-dev tcl-dev
tk-dev bwidget libreadline-dev python-tk
python-dev libgl1-mesa-dev libglu1-mesa-dev
libxmu-dev libudev-dev libmodbus-dev
libboost-python-dev libboost-serialization-dev
libboost-thread-dev libusb-1.0-0-dev libtk-img
blt-dev tclx mesa-utils libreadline-gplv2-dev
intltool yapps2
I then ran dpkg-checkdeps and installed everything else it wanted.
After doing that, the rest of the build process from the "building linuxcnc from source" page worked and I had a version of 2.9 pre0 that runs.
It will load the hal and ini files, and after hooking up the stepper motors, they run in a plausible fashion.
At the moment, the steppers aren't driving anything. When I get the next step or three done and have the steppers making the machine move and have a bit of testing and tuning done I will post a followup for others that may be trying to do something similar.
Jim
The following user(s) said Thank You: rdtsc
5 years 10 months ago #191898 by jimhurlburt
Warning to others working on this setup -- The y
and y2 home switches do not work with the hal and
ini files attached. I haven't attempted to do the
x and z home switches.
I have a xyyz configuration running and am working
on home switches. The machine is a gantry setup
with a 4ft wide x axis and two motors on the y
axis.
Hal and Ini files attached.
I have the 7c80 powered by a 12V meanwell
powersupply. Linuxcnc 2.9.0 pre0 is running and I
can run gcode files in the sim setup w/o problems.
I have two home switches for the ends of the Y
axis hooked to tb1-2 and tb1-3 (input1, input2)
I have 12v+ hooked to tb2-1, home switches hooked
to tb1-2 & 3, thence to 12v-.
snippit from hal file
# --- HOME-X ---
net home-x <= hm2_7c80.0.gpio.000.in
# --- HOME-Y ---
net home-y <= hm2_7c80.0.gpio.001.in
# --- HOME-Y2 ---
net home-y2 <= hm2_7c80.0.gpio.002.in
# --- HOME-Z ---
net home-z <= hm2_7c80.0.gpio.003.in
net home-y => joint.1.home-sw-in
net home-y2 => joint.2.home-sw-in
When I put a voltmeter on my limit switches, I get
10.5 volts with the switch at rest, 0 when
activated. (Normally open switch)
Attempting to test the home switches, I home the x
axis (joint0) which does not have a home switch
enabled. Seems to work as expected.
Click on home for joint 1 (y axis) and joints 1 & 2
start moving on the DRO. Activating the home
switches manually has no effect that I can see.
On the dro, the joints continue to move.
I have attempted to use hal scope and so far can
see no response to moving the switches.
It seems likely that the problem is in the lines
above in the hal file.
Any notion of what I am doing wrong and how to
correct it? Other tests I might make to
troubleshoot?
Thanks in advance,
Jim Hurlburt
Bend, OR
5 years 10 months ago - 5 years 10 months ago #191902 by PCW
Replied by PCW on topic 7c80 install on rpi 4
The isolated inputs on a 7C80 would be
hm2_7c80.0.inmux.00.input-00
hm2_7c80.0.inmux.00.input-00-not
hm2_7c80.0.inmux.00.input-23
hm2_7c80.0.inmux.00.input-23-not
Last edit: 5 years 10 months ago by PCW.
5 years 10 months ago #191927 by jimhurlburt
That worked. How -- intuitive?
Where might I have found the necessary syntax and names besides asking you?
That gets me to the next step which is making the actual hardware move as it should. Will likely take a week or more, I have some construction, then a lot of adjusting to do.
Thanks very much for the quick answer,
Jim
5 years 10 months ago #191932 by PCW
man hostmot2
and
halcmd show all hm2
5 years 3 months ago #216128 by Borsti
Replied by Borsti on topic 7c80 install on rpi 4
Hi there,
       I decided to open the older post in favor of creating a new one on the same topic as 7C80 & RPI4 as the info is scare for that kind of configuration.
I'm retro-fitting currently a small table carving machine and decided to use RPI4 along with 7C80 due to space, but I'm running into issues with the configuration of PNCCONF as the board is not available and I have no idea how to do it, so I followed the previous posts from  jimhurlburt  and used the 7i76 as template, but how should I change the *.hal to reflect the I/O?
I understood that the syntax for:
  • Input is: hm2_7c80.0.inmux.00.input-00
  • Analog should be for Output the syntax - hm2_7c80.0.inmux.00.output-00 ?
  • How about the spindle output?
Thanks a lot for the help and if someone has a functional *.hal I would be very appreciated if I could get a copy for reference.
Moderators: PCW, jmelson
Time to create page: 0.500 seconds
