7i76e what am I doing wrong
03 Jan 2021 15:56 - 03 Jan 2021 16:26 #193960 by PCW
Replied by PCW on topic 7i76e what am I doing wrong
in an editor
(you must run the editor as root to be able to write the interfaces file)
basically
cd /etc/network
sudo EDITOR interfaces
where EDITOR is gedit, mousepad, nano etc etc
Last edit: 03 Jan 2021 16:26 by PCW.
The following user(s) said Thank You: my1987toyota
  • my1987toyota
  • my1987toyota's Avatar Topic Author
  • Platinum Member
  • Platinum Member
03 Jan 2021 16:15 #193961 by my1987toyota
Replied by my1987toyota on topic 7i76e what am I doing wrong
looks I will have to get back to it later.
  • my1987toyota
  • Platinum Member
  • Platinum Member
03 Jan 2021 17:27 - 03 Jan 2021 17:36 #193966 by my1987toyota
I just installed linux mint 19.3 and I seem to have a connection now . I get a reply when I ping 10.10.10.10.
When I do the mesaflash --device 7i76e -- addr --10.10.10.10 --readhmid command in terminal I get the expected response . So now I know my board is ok.
This also means I have some weird conflict in Debian Buster correct?
Will I be better off just running Linux Mint instead?
Last edit: 03 Jan 2021 17:36 by my1987toyota.
03 Jan 2021 18:36 #193970 by tommylight
Replied by tommylight on topic 7i76e what am I doing wrong
Nope, it just means that Debian Buster 10 is the free version and does not include any kind of proprietary drives, hence newish network cards are not detected or are detected but not working.
Yes, always, and it looks better, but Debian will have better latency if using parallel port, is less hungry on the resources and works better on older PC's.
  • my1987toyota
  • Platinum Member
  • Platinum Member
03 Jan 2021 19:35 #193977 by my1987toyota
is there much benefit to using mint 20 over the 19.3 ?
03 Jan 2021 19:49 #193980 by PCW
tommylight: his Ethernet was detected:
2: eno1: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc pfifo_fast state UP group default qlen 1000
link/ether f8:b1:56:bc:20:0f brd ff:ff:ff:ff:ff:ff
inet6 fe80::fab1:56ff:febc:200f/64 scope link
valid_lft forever preferred_lft forever
But was never setup properly
(maybe because the Buster dist uses the very broken wicd rather than net manager)
  • my1987toyota
  • Platinum Member
  • Platinum Member
03 Jan 2021 20:49 #193987 by my1987toyota
I had replaced wicd with the
apt-get install network-manager network-manager-gnome
apt-get remove wicd wicd-gtk
as per instructions.
03 Jan 2021 21:30 #193991 by PCW
OK so Buster would have worked but there was still some host setup issue
  • my1987toyota
  • Platinum Member
  • Platinum Member
03 Jan 2021 21:47 #193994 by my1987toyota
it's always something. LOL. I have experienced it on multiple occasions that when something in Debian doesn't work when it should
it will work on Mint. I am pretty sure that can be chalked up to my lack of experience.
03 Jan 2021 22:02 #193997 by PCW
It is hard to tell what's going on when there maybe multiple issues
unless you have banged you head on them enough times before
I do agree Debian has a lot of sharp edges (I'm running Mint on my test hardware)
Moderators: PCW, jmelson
Time to create page: 0.398 seconds
