- Thank you received: 67
Configuration 7i92 and 7i77 - get error
- aleksamc
I have configured in PncConf 7i92M and 7i77 board.
And I have problem with first start after configuration.
I get error
I add hal and ini files
What problem could be?
1) I suspect: I made configuration for 2 7i77 boards but run only one board.
2) My PC is "industrial" and has 2 ethernet interfaces, I add also their configuration:
3) PncConf creates wrong configuration for 2.8.1 board, but previously I made configuration for 5i25 boards and doesn't have such problem.
If I run "ip link show", I get such result as in ip.txt file
- bevins
- Thank you received: 338
aleksamc wrote: To 7i92 written 7i77x2D.bit file.
I get errorCode:my_cnc.hal:22: parameter ot pin 'hm2_7i92.0.stepgen.timer-number' not found
For starters, delete or comment out the two lines below near the top of your hal file.
setp hm2_7i92.0.dpll.01.timer-us -50
setp hm2_7i92.0.stepgen.timer-number 1
- Thank you received: 5334
For a 7I77 you probably want:
setp hm2_7i92.0.encoder.timer-number 1
- bevins
PCW wrote: Looks like a pncconf bug
Get errors when I do that with a 7i77
- bevins
PCW wrote: You need to have the DPLL in the FPGA configuration, 7I92_7i77x2D should have it
I am running 7i92_7i77_7i74D firmware
