Configuration 7i92 and 7i77 - get error
- bevins
- Thank you received: 338
29 Jan 2021 12:15 #197047
by bevins
I am running 2.8.1-44
Replied by bevins on topic Configuration 7i92 and 7i77 - get error
Just loaded 7i92_7i77_7i74D firmware and I get:
7 s32 IN -1 hm2_7i92.0.encoder.timer-number
What LinuxCNC version are you running?
- bevins
29 Jan 2021 12:25 #197049
by bevins
Pin List for encoders:
Warning: Spoiler!
26 s32 OUT 0 hm2_7i92.0.encoder.00.count
26 s32 OUT 0 hm2_7i92.0.encoder.00.count-latched
26 bit I/O FALSE hm2_7i92.0.encoder.00.index-enable <=> x-index-enable
26 bit OUT FALSE hm2_7i92.0.encoder.00.input-a
26 bit OUT FALSE hm2_7i92.0.encoder.00.input-b
26 bit OUT TRUE hm2_7i92.0.encoder.00.input-index
26 bit IN FALSE hm2_7i92.0.encoder.00.latch-enable
26 bit IN FALSE hm2_7i92.0.encoder.00.latch-polarity
26 float OUT 0 hm2_7i92.0.encoder.00.position ==> x-pos-fb
26 float OUT 0 hm2_7i92.0.encoder.00.position-latched
26 bit OUT FALSE hm2_7i92.0.encoder.00.quad-error
26 bit IN FALSE hm2_7i92.0.encoder.00.quad-error-enable
26 s32 OUT 0 hm2_7i92.0.encoder.00.rawcounts ==> x-pos-rawcounts
26 s32 OUT 0 hm2_7i92.0.encoder.00.rawlatch
26 bit IN FALSE hm2_7i92.0.encoder.00.reset
26 float OUT 0 hm2_7i92.0.encoder.00.velocity ==> x-vel-fb
26 float OUT 0 hm2_7i92.0.encoder.00.velocity-rpm
26 s32 OUT 0 hm2_7i92.0.encoder.01.count
26 s32 OUT 0 hm2_7i92.0.encoder.01.count-latched
26 bit I/O FALSE hm2_7i92.0.encoder.01.index-enable <=> y-index-enable
26 bit OUT FALSE hm2_7i92.0.encoder.01.input-a
26 bit OUT FALSE hm2_7i92.0.encoder.01.input-b
26 bit OUT TRUE hm2_7i92.0.encoder.01.input-index
26 bit IN FALSE hm2_7i92.0.encoder.01.latch-enable
26 bit IN FALSE hm2_7i92.0.encoder.01.latch-polarity
26 float OUT 0 hm2_7i92.0.encoder.01.position ==> y-pos-fb
26 float OUT 0 hm2_7i92.0.encoder.01.position-latched
26 bit OUT FALSE hm2_7i92.0.encoder.01.quad-error
26 bit IN FALSE hm2_7i92.0.encoder.01.quad-error-enable
26 s32 OUT 0 hm2_7i92.0.encoder.01.rawcounts ==> y-pos-rawcounts
26 s32 OUT 0 hm2_7i92.0.encoder.01.rawlatch
26 bit IN FALSE hm2_7i92.0.encoder.01.reset
26 float OUT 0 hm2_7i92.0.encoder.01.velocity ==> y-vel-fb
26 float OUT 0 hm2_7i92.0.encoder.01.velocity-rpm
26 s32 OUT 0 hm2_7i92.0.encoder.02.count
26 s32 OUT 0 hm2_7i92.0.encoder.02.count-latched
26 bit I/O FALSE hm2_7i92.0.encoder.02.index-enable <=> z-index-enable
26 bit OUT FALSE hm2_7i92.0.encoder.02.input-a
26 bit OUT FALSE hm2_7i92.0.encoder.02.input-b
26 bit OUT TRUE hm2_7i92.0.encoder.02.input-index
26 bit IN FALSE hm2_7i92.0.encoder.02.latch-enable
26 bit IN FALSE hm2_7i92.0.encoder.02.latch-polarity
26 float OUT 0 hm2_7i92.0.encoder.02.position ==> z-pos-fb
26 float OUT 0 hm2_7i92.0.encoder.02.position-latched
26 bit OUT FALSE hm2_7i92.0.encoder.02.quad-error
26 bit IN FALSE hm2_7i92.0.encoder.02.quad-error-enable
26 s32 OUT 0 hm2_7i92.0.encoder.02.rawcounts ==> z-pos-rawcounts
26 s32 OUT 0 hm2_7i92.0.encoder.02.rawlatch
26 bit IN FALSE hm2_7i92.0.encoder.02.reset
26 float OUT 0 hm2_7i92.0.encoder.02.velocity ==> z-vel-fb
26 float OUT 0 hm2_7i92.0.encoder.02.velocity-rpm
26 s32 OUT 0 hm2_7i92.0.encoder.03.count
26 s32 OUT 0 hm2_7i92.0.encoder.03.count-latched
26 bit I/O FALSE hm2_7i92.0.encoder.03.index-enable
26 bit OUT FALSE hm2_7i92.0.encoder.03.input-a
26 bit OUT TRUE hm2_7i92.0.encoder.03.input-b
26 bit OUT FALSE hm2_7i92.0.encoder.03.input-index
26 bit IN FALSE hm2_7i92.0.encoder.03.latch-enable
26 bit IN FALSE hm2_7i92.0.encoder.03.latch-polarity
26 float OUT 0 hm2_7i92.0.encoder.03.position
26 float OUT 0 hm2_7i92.0.encoder.03.position-latched
26 bit OUT FALSE hm2_7i92.0.encoder.03.quad-error
26 bit IN FALSE hm2_7i92.0.encoder.03.quad-error-enable
26 s32 OUT 65535 hm2_7i92.0.encoder.03.rawcounts
26 s32 OUT 65535 hm2_7i92.0.encoder.03.rawlatch
26 bit IN FALSE hm2_7i92.0.encoder.03.reset
26 float OUT 0 hm2_7i92.0.encoder.03.velocity
26 float OUT 0 hm2_7i92.0.encoder.03.velocity-rpm
26 s32 OUT 0 hm2_7i92.0.encoder.04.count
26 s32 OUT 0 hm2_7i92.0.encoder.04.count-latched
26 bit I/O FALSE hm2_7i92.0.encoder.04.index-enable
26 bit OUT FALSE hm2_7i92.0.encoder.04.input-a
26 bit OUT TRUE hm2_7i92.0.encoder.04.input-b
26 bit OUT TRUE hm2_7i92.0.encoder.04.input-index
26 bit IN FALSE hm2_7i92.0.encoder.04.latch-enable
26 bit IN FALSE hm2_7i92.0.encoder.04.latch-polarity
26 float OUT 0 hm2_7i92.0.encoder.04.position
26 float OUT 0 hm2_7i92.0.encoder.04.position-latched
26 bit OUT FALSE hm2_7i92.0.encoder.04.quad-error
26 bit IN FALSE hm2_7i92.0.encoder.04.quad-error-enable
26 s32 OUT 65535 hm2_7i92.0.encoder.04.rawcounts
26 s32 OUT 65535 hm2_7i92.0.encoder.04.rawlatch
26 bit IN FALSE hm2_7i92.0.encoder.04.reset
26 float OUT 0 hm2_7i92.0.encoder.04.velocity
26 float OUT 0 hm2_7i92.0.encoder.04.velocity-rpm
26 s32 OUT 0 hm2_7i92.0.encoder.05.count
26 s32 OUT 0 hm2_7i92.0.encoder.05.count-latched
26 bit I/O FALSE hm2_7i92.0.encoder.05.index-enable
26 bit OUT FALSE hm2_7i92.0.encoder.05.input-a
26 bit OUT FALSE hm2_7i92.0.encoder.05.input-b
26 bit OUT TRUE hm2_7i92.0.encoder.05.input-index
26 bit IN FALSE hm2_7i92.0.encoder.05.latch-enable
26 bit IN FALSE hm2_7i92.0.encoder.05.latch-polarity
26 float OUT 0 hm2_7i92.0.encoder.05.position
26 float OUT 0 hm2_7i92.0.encoder.05.position-latched
26 bit OUT FALSE hm2_7i92.0.encoder.05.quad-error
26 bit IN FALSE hm2_7i92.0.encoder.05.quad-error-enable
26 s32 OUT 0 hm2_7i92.0.encoder.05.rawcounts
26 s32 OUT 0 hm2_7i92.0.encoder.05.rawlatch
26 bit IN FALSE hm2_7i92.0.encoder.05.reset
26 float OUT 0 hm2_7i92.0.encoder.05.velocity
26 float OUT 0 hm2_7i92.0.encoder.05.velocity-rpm
26 bit IN FALSE hm2_7i92.0.encoder.hires-timestamp
26 u32 IN 0x007F2815 hm2_7i92.0.encoder.muxed-sample-frequency
26 bit OUT TRUE hm2_7i92.0.gpio.000.inPlease Log in or Create an account to join the conversation.
- Thank you received: 5336
29 Jan 2021 17:15 #197075
Replied by PCW on topic Configuration 7i92 and 7i77 - get error
I suspect you are using non-dpll firmware
what does:
mesaflash --device 7i92 --addr 10.10.10.10 -- readhmid
report?
what does:
report?
29 Jan 2021 17:34 - 29 Jan 2021 17:35 #197080
No, adding DPLL retiming will make the average delay between reading the encoders and writing the analog out
slightly longer (by 50 usec in the example)
It's expected that "setp hm2_7i92.0.stepgen.timer-number 1" would cause an error if you
dont have any step generators in your configuration. This is presumably a pncconf bug.
I am 99% sure I also don't have that and have been # out setp hm2_7i92.0.stepgen.timer-number 1 since it was creating errors. That could explain my 5ms delay from encoder response, or part of it.
Last edit: 29 Jan 2021 17:35 by PCW.
- bevins
29 Jan 2021 17:46 - 29 Jan 2021 17:48 #197082
by bevins
DPLL module is there
what does:
report?
Warning: Spoiler!
Configuration Name: HOSTMOT2
BoardName : MESA7I92
FPGA Size: 9 KGates
FPGA Pins: 144
Number of IO Ports: 2
Width of one I/O port: 17
Clock Low frequency: 100.0000 MHz
Clock High frequency: 200.0000 MHz
IDROM Type: 3
Instance Stride 0: 4
Instance Stride 1: 64
Register Stride 0: 256
Register Stride 1: 256
Modules in configuration:
Module: DPLL
There are 1 of DPLL in configuration
Version: 0
Registers: 7
BaseAddress: 7000
ClockFrequency: 100.000 MHz
Register Stride: 256 bytes
Instance Stride: 4 bytes
Module: WatchDog
There are 1 of WatchDog in configuration
Version: 0
Registers: 3
BaseAddress: 0C00
Module: IOPort
There are 2 of IOPort in configuration
Version: 0
Registers: 5
BaseAddress: 1000
Module: MuxedQCount
There are 6 of MuxedQCount in configuration
Version: 3
Registers: 5
BaseAddress: 3600
Module: MuxedQCountSel
There are 1 of MuxedQCountSel in configuration
Version: 0
Registers: 0
BaseAddress: 0000
Module: SSerial
There are 2 of SSerial in configuration
Version: 0
Registers: 6
BaseAddress: 5B00
Instance Stride: 64 bytes
Module: LED
There are 1 of LED in configuration
Version: 0
Registers: 1
BaseAddress: 0200
Configuration pin-out:
IO Connections for P2
Pin# I/O Pri. func Sec. func Chan Pin func Pin Dir
1 0 IOPort SSerial 0 TXEn2 (Out)
14 1 IOPort SSerial 0 TXData2 (Out)
2 2 IOPort SSerial 0 RXData2 (In)
15 3 IOPort SSerial 0 TXData1 (Out)
3 4 IOPort SSerial 0 RXData1 (In)
16 5 IOPort SSerial 0 TXData0 (Out)
4 6 IOPort SSerial 0 RXData0 (In)
17 7 IOPort MuxedQCountSel 0 MuxSel0 (Out)
5 8 IOPort MuxedQCount 0 MuxQ-A (In)
6 9 IOPort MuxedQCount 0 MuxQ-B (In)
7 10 IOPort MuxedQCount 0 MuxQ-IDX (In)
8 11 IOPort MuxedQCount 1 MuxQ-A (In)
9 12 IOPort MuxedQCount 1 MuxQ-B (In)
10 13 IOPort MuxedQCount 1 MuxQ-IDX (In)
11 14 IOPort MuxedQCount 2 MuxQ-A (In)
12 15 IOPort MuxedQCount 2 MuxQ-B (In)
13 16 IOPort MuxedQCount 2 MuxQ-IDX (In)
IO Connections for P1
1 17 IOPort SSerial 1 RXData0 (In)
14 18 IOPort SSerial 1 RXData1 (In)
2 19 IOPort SSerial 1 RXData2 (In)
15 20 IOPort SSerial 1 RXData3 (In)
3 21 IOPort SSerial 1 TXData0 (Out)
16 22 IOPort SSerial 1 TXData1 (Out)
4 23 IOPort SSerial 1 TXData2 (Out)
17 24 IOPort SSerial 1 TXData3 (Out)
5 25 IOPort SSerial 1 RXData4 (In)
6 26 IOPort SSerial 1 RXData5 (In)
7 27 IOPort None
8 28 IOPort None
9 29 IOPort SSerial 1 TXData4 (Out)
10 30 IOPort SSerial 1 TXData5 (Out)
11 31 IOPort None
12 32 IOPort None
13 33 IOPort None
Last edit: 29 Jan 2021 17:48 by bevins.
29 Jan 2021 21:25 #197091
OK well that's fairly mysterious, I just built 2.8.1 and the pin is there:
I had been checking with master but 2.8.1 works for me
Can you check the bitfile checksum?
$ md5sum 7i92_7i77_7i74D.bit
9adaf5281f07f798d9fa87580f63e6c2 7i92_7i77_7i74D.bit
- bevins
29 Jan 2021 22:19 - 29 Jan 2021 22:19 #197095
by bevins
Ill check it after supper but i got the 7i92 zip file from freeby.mesanet site. I compiled mesaflash from github and got the 7i92.zip from your site.
Maybe the zip file dont have the correct files in it? Can you send the bit and pin files?
Last edit: 29 Jan 2021 22:19 by bevins.
- bevins
29 Jan 2021 22:35 #197096
by bevins
Thats bizarre. The checksum works out.
Is it a config on the loadrt line?
29 Jan 2021 23:01 #197097
Not unless the config line disabled the DPLL
- aleksamc
- Thank you received: 67
30 Jan 2021 03:18 - 30 Jan 2021 03:20 #197110
by aleksamc
Replied by aleksamc on topic Configuration 7i92 and 7i77 - get error
I changed stepgen to encoder:
and graphical interface starts.
But I get another error:
I use Intel J1900 fanless PC.
In BIOS I previously disablem all parameters that could make delay and also made isolcpu=2,3 that gives me very good latency (10k to 15k).
hm2_7i92.0.encoder.timer-numberBut I get another error:
hm2_7i92.9: Watchdog has bit! (set the has-bit to False to resume)
hm2_7i92.0: Error after doit cleanI use Intel J1900 fanless PC.
Last edit: 30 Jan 2021 03:20 by aleksamc.
Time to create page: 0.133 seconds
