Configuration 7i92 and 7i77 - get error
30 Jan 2021 03:46 #197111 by PCW
Replied by PCW on topic Configuration 7i92 and 7i77 - get error
Do you have all power management turned off? (no C states > C1)
idle=poll in the kernel command line helps also (set with grub)
What are you ping times to the 7I92?
  • aleksamc
  • aleksamc's Avatar Topic Author
  • Platinum Member
  • Platinum Member
30 Jan 2021 04:29 - 30 Jan 2021 04:33 #197114 by aleksamc
Replied by aleksamc on topic Configuration 7i92 and 7i77 - get error
I will look for ping today I think, also I will add to ethernet interface settings
"hardware−irq−coalesce−rx−usecs 0" as in the hm2_eth manual
Now I read this manual for some additional help.
Also ethernet cable is very short, less than half of meter. And it also shielded to the ground. Phisicaly, ground is neutraled.
Power management, it disabled complitly in BIOS. I had very big latency delays when I bought this PC, more then 300k. After disabpling a lot of parameters in BIOS I got 30k. And after setting isolcpu=2,3, I got 15k and less.
PCW, I didn't understood, what does it mean "idle=poll", where to set it?
Also, how to disable IPV6, if I have it?
Last edit: 30 Jan 2021 04:33 by aleksamc.
30 Jan 2021 11:04 #197139 by tommylight
Replied by tommylight on topic Configuration 7i92 and 7i77 - get error
Idle=poll goes before or after the isolcpu in grub.
  • aleksamc
  • Platinum Member
  • Platinum Member
01 Feb 2021 12:40 - 01 Feb 2021 12:41 #197302 by aleksamc
I've check ping to mesa board and I got
rtt min/avg/max/mdev = 0.187/0.287/1.354/0.129 ms
In hal I increased watchdog time to 1300 000 (I thing I don't make here any mistake in zeros).
And it seems, everithing work fine.
Now I start to run servos and I wonder, I've connected them to ENA pins of mesa 7i77 board (it's near analog output). What HAL pin controls this pin? Where it's written in my hal address of this pin?
Last edit: 01 Feb 2021 12:41 by aleksamc.
  • aleksamc
  • Platinum Member
  • Platinum Member
01 Feb 2021 13:53 #197304 by aleksamc
After turning on I laso received remote error from 7i77 as (27) Over Current.
I don't understand why, I've connected only one relay. I use 7i77D
01 Feb 2021 14:14 #197305 by PCW
1.354 ms is pretty bad...
The first 5 analog enables (0 through 4) are controlled by the analogena pin
If you have an overcurrent warning, you may have the relay miswired
(flyback diode backwards?) or too large a relay without a flyback
  • aleksamc
  • Platinum Member
  • Platinum Member
01 Feb 2021 14:25 #197307 by aleksamc
I have flyback diods, maybe relays are a bit large, I will look.
What current should be on one output of the board?
01 Feb 2021 14:30 #197309 by PCW
350 ma is max
Are you sure your flyback diodes point the right way?
On a 7I77D:
+12/+24V to relay_coil-1 + diode cathode (band)
7I77D-Output to relay_coill-2 + diode anode
  • aleksamc
  • Platinum Member
  • Platinum Member
01 Feb 2021 16:33 #197313 by aleksamc
Yes, for diod connection I'm sure.
Relays are something bigger than I used previously. They are from refitting machine, they need 387mA.
Will they work? I think I need only 6 such relays.
  • aleksamc
  • Platinum Member
  • Platinum Member
02 Feb 2021 07:35 #197385 by aleksamc
I want to clearify, I need to write it in the same line as isolcpus, like this
<<<<.... = "isolcpus =2,3 idle=pool " >>>>?
Moderators: PCW, jmelson
Time to create page: 0.253 seconds
