Start 5i25 with a firmware 5i25_g540_enc
- Thank you received: 5310
08 Feb 2021 17:47 #198028
Replied by PCW on topic Start 5i25 with a firmware 5i25_g540_enc
If you see the hal pins hm2_5i25.0.encoder.NN.input-a and hm2_5i25.0.encoder.NN.input-b
changing then the encoder should work (+- any hal setup issues)
- Alexf2a
08 Feb 2021 18:19 #198038
by Alexf2a
Replied by Alexf2a on topic Start 5i25 with a firmware 5i25_g540_enc
I see the signal hm2 5i25.0.encoder.03.input-a on halscop, but on hal metr hm2 5i25.0.encoder.03.position, changes only occur by 0.005 and that's it. So with encoder 01 and 05. And encoder 00, 02, 04 work. The signal level for halscop from different encoders is the same. Only even encoders work
08 Feb 2021 19:04 #198046
sounds like you don't have the B inputs connected
- Alexf2a
08 Feb 2021 21:32 #198078
by Alexf2a
I forgot to write about B inputs. On Halmeter it is too.
C10 payments working - I start a system without 5i25 through 2 LPT with back coupling through sino-300 and everything works. I apply Hal of such system. It seems to me that there is an error in a firmware. I looked for at different forums but did not find that someone would use such firmware. But maybe I that not correctly I do that.
08 Feb 2021 21:38 #198079
Are you saying that:
and
both change but
hm2_5i25.0.encoder.NN.count
does not?
and
both change but
does not?
- Alexf2a
08 Feb 2021 22:07 - 08 Feb 2021 22:42 #198086
by Alexf2a
Yes quite so. Changes but only on 0.005
It occurs on encoder 01 and encoder 03 and encoder 05
the result changes from 0 to 0.005
Last edit: 08 Feb 2021 22:42 by Alexf2a.
09 Feb 2021 03:12 #198117
I suspect you have a wiring error.
I just tested the5i25_g540_enc firmware
and it works as expected
- Alexf2a
09 Feb 2021 05:23 - 09 Feb 2021 05:25 #198120
by Alexf2a
Many thanks for the help! I will look for at myself an error.
I did a firmware by the attached file.
Last edit: 09 Feb 2021 05:25 by Alexf2a.
Time to create page: 0.211 seconds
