[Resolved] adding control of the spindle with 7i96 tools
5 years 7 months ago #202833 by Ewok2
Many Thanks it works fine, the spindle is know control by linuxcnc...
The last question...
When I power up the CNC (Mesa card + all the electronics part) befor linuxcnc is start and connect to the Mesa, the spindle it turning to max...
Is there a way to set by default to stop in Mesa card?
5 years 7 months ago #202835 by RotarySMP
Do you have separate "spindle start FWD" and "Spindle start REV" wired into you VFD, or just the speed command? I like have the functions of speed and start separate.
You can see my wiring and HAL in the first posting of this thread...
forum.linuxcnc.org/26-turning/38280-pimp...e-mini-lathe?start=0
Mark
5 years 7 months ago #202838 by PCW
As RotarySMP says, the spindle should be controlled by FWD and REV not just the
analog voltage. That said, you can get the analog voltage to be 0 at start-up by
inverting the PWM pin and using the STEP4- pin rather than the STEP4+ pin.
To invert the PWM pin, you:
setp hm2_7i96.0.pwmgen.00.out0.invert_output true
5 years 7 months ago #202840 by Ewok2
I have already look a your wiring and hal fiel :-)
My spindle has the 0-10V input wire to the smal 0-10V / PMW card
the smal card is connected to the MESA card
And there is also 2 connectors when shortcuircuit that enable the spindle to run.
I have wire this 2 connectors to the Out0 +/- of the mesa.
But it seems that Mesa connect by default Out +/- when not control by the linuxCnC.
I was wondering if it was possible to set "Open" as default?
5 years 7 months ago #202841 by Ewok2
Thanks PCW, I will try. But as said just above I do not have a direction control on the spindle.
Only 0-10V for the seed
and a On / Off
5 years 7 months ago #202842 by PCW
OUT+ and OUT- are disconnected until explicitly enabled by LinuxCNC
Is it possible you have the OUT+ and OUT- polarity wrong?
(The outputs will appear to be stuck-on if reversed)
Moderators: PCW, jmelson
Time to create page: 0.246 seconds
