[Resolved] adding control of the spindle with 7i96 tools
5 years 7 months ago #201176 by RotarySMP
I put up my HAL and wiring diagram in the first post of my mini -lathe thread.
forum.linuxcnc.org/26-turning/38280-pimp...e-mini-lathe?start=0
Mark
5 years 7 months ago #201281 by Ewok2
Thanks for the files.
Did you use the 7i96 Configuration Tool from JohnT to produce the ini and hal files ?
Did you connect the ON/OFF off the Spindle to an Outpus directly?
5 years 7 months ago #201295 by RotarySMP
Did you look at the schematics I posted? I am running a VFD, so the VFD enable, start and direction are all controlled directly by the 7i96, and the analog speed input is a PWM output from the 7i96, changed to a 0-10V analog signal by that little widget, and then input to the VFD.
Mark
5 years 7 months ago #202817 by Ewok2
Hello RotarySMP
I have received my small board to convert PWM to 0-10V.
It look likes yours.
It has also a 5V / 24V PMW selector.
Did the Mesa card Output send 5V or 24V ?
5 years 7 months ago #202818 by RotarySMP
The PWM output is on +5v.
Mark
5 years 7 months ago #202819 by Ewok2
Moderators: PCW, jmelson
Time to create page: 0.386 seconds
