7i96 Error finishing read.
- Thank you received: 7491
25 Mar 2022 11:39 - 25 Mar 2022 11:40 #238325
Replied by tommylight on topic 7i96 Error finishing read.
Yes it is, the servo and read tmax are over 2 million !
You can set the servo period to 2.5 million, but it will drop to 400 iterations per second, still usable.
Last edit: 25 Mar 2022 11:40 by tommylight. Reason: typo
- billykid
- Thank you received: 83
12 Nov 2022 09:45 #256493
by billykid
Replied by billykid on topic 7i96 Error finishing read.
After a long time I replaced the m93c46-rmn3tp / k ethernet chip at 7i80db now it works perfectly. out of curiosity I tried to read it with a programmer at room temperature and it was not detected. heated a little with hot air and here it is working! thanks PCW !!
- Thank you received: 4152
12 Nov 2022 10:21 #256496
As of today I think this is a Debian specific issue as I have got Linuxcnc working on Arch Linux and have not got any errors and ping times to the mesa ard have halved. I'll keep people in the loop on the other thread or the arch linux thread linked to on the thread above.
Replied by rodw on topic 7i96 Error finishing read.
Thanks for the update. Aside from your hardware issues, it seems the error finishing read is due to a yet unexplained issue with Debian kernels with Debian Bullseye and above (kernel 5.10 and higher) and realtek NICs (but it has been reported as affecting other NIC's. There is more discussion here forum.linuxcnc.org/27-driver-boards/4691...error-finishing-readAfter a long time I replaced the m93c46-rmn3tp / k ethernet chip at 7i80db now it works perfectly. out of curiosity I tried to read it with a programmer at room temperature and it was not detected. heated a little with hot air and here it is working! thanks PCW !!
- billykid
12 Nov 2022 15:36 #256508
by billykid
The hardware problem is solved but it is very slow I had to put the servo at 500hz ... horrible. for now I don't need it, I replaced it with the 5i23 and I'm happy with the choice. I will follow the other discussion to see if there are any improvements.
Time to create page: 0.095 seconds
