7i92+7i77 Not connect
02 Jul 2022 16:15 #246451 by PCW
Replied by PCW on topic 7i92+7i77 Not connect
I would update to the latest mesaflash (3.4.3), reflash the new 7I92s and try again
02 Jul 2022 17:35 #246454 by SOLD
Replied by SOLD on topic 7i92+7i77 Not connect
I don't understand for FW7i92s where can it be found.
02 Jul 2022 18:17 #246455 by PCW
mesaflash is here:
github.com/LinuxCNC/mesaflash
(build instructions at bottom of page)
7i92 firmware is here:
www.mesanet.com/software/parallel/7i92.zip
02 Jul 2022 19:30 #246457 by SOLD
Update mesaflash to 3.4.3 ok.
reflash the new 7I92 ok.
but not working Please help check the file.
File Name: test.txt
File Size:2 KB
File Name: dbname1.txt
File Size:5 KB
02 Jul 2022 19:56 #246461 by PCW
That looks correct, not sure what the issue could be
Do the encoders work?
12 Jul 2022 13:28 #247136 by SOLD
I'm just free for another test.
I don't know how to test the encoder.
12 Jul 2022 14:44 #247151 by PCW
Connect an encoder and see if it counts properly on all 6 7I77 encoder inputs
12 Jul 2022 15:56 - 12 Jul 2022 15:57 #247157 by SOLD
How can I see if this is correct when 7i92 is not connected to 7i77? or means setting from the Pncconf wizard
Last edit: 12 Jul 2022 15:57 by SOLD.
12 Jul 2022 16:00 #247158 by PCW
I would just comment out all the lines in hal with "7i77"
then you can launch linuxcnc and check the encoders
12 Jul 2022 16:12 #247159 by SOLD
Got it, I'll test it right now.
Moderators: PCW, jmelson
Time to create page: 0.103 seconds
