7i92+7i77 Not connect
12 Jul 2022 16:22 #247160 by JPL
Replied by JPL on topic 7i92+7i77 Not connect
I'm very curious here about why you say it does not connect?
What is different from the other lot that was connecting???
14 Jul 2022 09:52 - 14 Jul 2022 10:07 #247278 by SOLD
Replied by SOLD on topic 7i92+7i77 Not connect
I am moving in the Y axis. but the screen shows the Z axis
Axis X = hm2_7i92.0.encoder.00
Axis Y = hm2_7i92.0.encoder.01
AxisZ = hm2_7i92.0.encoder.02
[video]
[/ วิดีโอ]
Last edit: 14 Jul 2022 10:07 by SOLD.
14 Jul 2022 10:07 - 14 Jul 2022 10:17 #247279 by SOLD
When I change the configuration being still connected to the same motor cable
I am moving in the Y axis. But the screen shows the X and Y axis at the same time.
Axis X = hm2_7i92.0.encoder.03
Axis Y = hm2_7i92.0.encoder.02
AxisZ = hm2_7i92.0.encoder.04
***Please note that this internal wiring works, just replace the old 7i92.***
Last edit: 14 Jul 2022 10:17 by SOLD.
14 Jul 2022 10:09 - 14 Jul 2022 10:16 #247280 by SOLD
Video 2 doesn't show up
Last edit: 14 Jul 2022 10:16 by SOLD.
14 Jul 2022 14:29 #247292 by PCW
Replied by PCW on topic 7i92+7i77 Not connect
Sounds like either:
1. Wrong firmware
2. Bad cable
3. damaged 7I92
The following user(s) said Thank You: SOLD
14 Jul 2022 17:28 - 14 Jul 2022 17:38 #247304 by JPL
I also see on the video that line 74 appear to be wrong:
74 net x-index-enable joint.0.index-enable <==> hm2_7i92.0.encoder.03.  (remaining characters are not visible)
(First video since the other have different settings, which make me think that you should maybe focus on a single configuration as this is very confusing to help with many different configurations)
Last edit: 14 Jul 2022 17:38 by JPL.
15 Jul 2022 12:59 #247377 by SOLD
Please note that all configurations are available when I replace my old 7i92 by installing the same firmware.
15 Jul 2022 13:01 #247378 by SOLD
Sounds like either:
1. Wrong firmware
2. Bad cable
3. damaged 7I92
if it is damaged What should I do with all 5 pieces?
15 Jul 2022 13:54 #247382 by PCW
So you are saying that the encoders behave differently on the old 7I92 and the new 7I92
when you do _nothing_ but swap 7I92 cards?
15 Jul 2022 14:09 #247384 by PCW
Sounds like either:
1. Wrong firmware
2. Bad cable
3. damaged 7I92
I would request an RMA from Mesa, and return the cards for evaluation/repair/replacement
Moderators: PCW, jmelson
Time to create page: 0.235 seconds
